Swapping chip on hot tub motherboard.
  • blufx
    • Oct 2014
    • 10
    • usa
    Hey guys,
    I'm replacing the motherboard on the hot tub. The board I bought is identical except for the controller chip. I'm not well equipped and don't want to damage the chip, or the other board. Rather than attempt de-soldering both chips from the boards, I was thinking about shearing the legs on the chip I want to use close the board, then shear them close to the chip itself on the other one. Make sure everything is clean, and solder the legs to legs. Is there any reason this won't work? The chip with the white label is the one I need to put on the other board.
    Looking back, when I said I wanted to be somebody, I should've been a lot more specific
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Swapping chip on hot tub motherboard.
    If everything else is identical, it's possible the chips was changed for a compatible one and the code/function is the same.
    Your method is not one I'd do for fear of damaging the chip through either vibration or heat when you solder the legs.
    • R_J
      • 9535
      It might work but too much heat on the pins that are left in the board and they will start moving around as the solder melts
      • blufx
        • Oct 2014
        • 10
        • usa
        My tub has a single two speed pump. The other tub had two single speed pumps. Exactly the same board with different cycle instructions.
        Thanks for your reply. I intend to reply to R_J also, but later. I'm tired.
          • 31029
          what's wrong with the old board?
          • blufx
            • Oct 2014
            • 10
            • usa
            The relays are corroded. It was subjected to weather for years.
            • blufx
              • Oct 2014
              • 10
              • usa
              I'm trying to dream up a method of holding all in place. I might have to resort to some redneck engineering. I'm picturing only a couple or few seconds per leg solder time.
              Because nobody likes my piggyback idea, I'm also thinking of a way to apply an upward pull on the chip while I warm it on the opposite side with a heat gun.
                • 31029
                it would be safer to replace the relays than risk the microcontroller.
                • blufx
                  • Oct 2014
                  • 10
                  • usa
                  Thank you, but I'm going to disagree. There are six relays very heavily soldered in place.
                    • 31029
                    nothing a desoldering pump or good braid wont lift.
                    • blufx
                      • Oct 2014
                      • 10
                      • usa
                      Thanks, but I'm going to stick with replacing the chip on a board that I know works.
                      • R_J
                        • 9535
                        Take it to an electronic repair shop and have them swap the ic's, should be easy only 18 pins.
                          You may want to install good IC socket in the board you want to use that removed IC in case the removed IC is not good or damaged during removal.
                          • blufx
                            • Oct 2014
                            • 10
                            • usa
                            I want to thank everyone for their input and advice. I scrapped my piggyback idea and devised a spring loaded puller to aid me while heating the other side. I mounted it in a hobby vice where I could view it edgewise. I started applying heat and in no time started watching the legs slowly sink into the board. The last couple of legs got bent a little because it wasn't pulled straight up, but no big deal. My redneck chip puller might look a little crude, but I only spent ten minutes making it, and it worked!
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              Good job, I like your puller.
                                • Jul 2011
                                • 6039
                                I will have to keep this in mind when I need to pull out a IC chip like that thanks for sharing your idea
                                • Longbow
                                  • Jun 2011
                                  • 623
                                  I must have missed something here. I see that the manufacturer has about 10 different versions of this controller board, and it doesn't seem productive to start guessing at what each one does or does not do. Did I miss the part about why this controller chip is thought to be faulty? Working or not, I wouldn't expect rusty relays to operate even with correct coil voltages. Are the relays getting proper coil voltages to turn on? Given the purpose of the board, the heavy duty motor and heater relays and related circuits are the place to start. Car with flat tyre: change the oil dipstick.
                                  Is it plugged in?
                                    • 31029
                                    you could just buy a chip-puller.
                                    they are like an oversize pair of tweezers with the ends turned in at 90'
                                    http://www.ebay.co.uk/itm/281224550607
                                    • blufx
                                      • Oct 2014
                                      • 10
                                      • usa
                                      Why? those are generally used to pull a chip from a socket. I'd be willing to bet they would be too thick to get under the IC I was removing. I had to search for something thin enough to get under it and still be strong enough for the job. Plus, I didn't have to wait ten days for it to be delivered.
                                        • 31029
                                        i meant for other people.
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • DynaxSC
                                          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                          by DynaxSC
                                          Hi
                                          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                          08-04-2025, 12:20 PM
                                        • gusto
                                          How do I remove the chip from the board
                                          by gusto
                                          I am new to hot air soldering. I need to remove one chip from the board. I have a hot air solder and I set the temperature to 350°C. I slowly started heating the chip, but the solder didn't melt. I heated it for about 5 minutes, but the solder still wouldn't melt. I increased the temperature to 450˚C and still nothing. After a while, the board started to change color, but the solder still didn't melt.
                                          Fortunately, I'm testing it on old network switches to see how it works.
                                          What am I doing wrong?
                                          I've seen a lot of videos on youtube and everyone got the solder melted and the...
                                          10-08-2024, 10:55 AM
