Confusion about distilled/deionized water for circuit board cleaning
  • caphair
    • Nov 2011
    • 1249
    I've been reading up on distilled and deionized water and I've come across conflicting information.
    If compared to regular tap water there are little to no minerals, why are they used to clean circuit boards? Is it because they're "hungry" for ions so they actually strip away any corrosion caused by mineral deposits?
    That's my take on it and it got me wondering if that then makes distilled/di water corrosive if it's accidentally used on electronics when not intended to as a cleaning agent?
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Re: Confusion about distilled/deionized water for circuit board cleaning
    Water is known as the universal solvent because of it's molecular shape. Oxygen in the middle and two hydrogen on the outside. That doesn't make it a problem except for salt and sugar. Why you use it is distilled water has no minerals to leave behind when it evaporates. Just like using any ultra pure solvents.
    sigpicThe Sky Is Falling
    • caphair
      • Nov 2011
      • 1249
      I came across this on a site which tells about the uses for deionised water
      "Ultrasonic cleaning tanks – deionised water is extremely active cleaner and will pull ions from any surrounding metal, including stainless steel. As deionised water contains no ions of its own, it will always look to draw from its immediate surroundings and even the atmosphere"
      • caphair
        • Nov 2011
        • 1249
        So it makes it sound like the water is "stripping" the metals clean, thus my confusion
        • Longbow
          • Jun 2011
          • 623
          More to the point is that you do not want to place any circuit board in water unless you are faced with certain death if you don't try something. Spills of corrosive liquids can sometimes be removed by careful brushing in warm water, IF the spill is very recent. But odds are not in your favor. Placing the board in an ultrasonic cleaner is insanity. Are you going to put your reputation on the line by doing something like that? I wouldn't.
          Ultrasonic cleaning is for jewelry.
          Is it plugged in?
          • caphair
            • Nov 2011
            • 1249
            I've never done it but I've read about others doing so to clean water damage corrosion or flux etc.
            That's what got me investigating why distilled water was often mentioned in this process
            • rhomanski
              nowhere man
              • 5157
              • U S of A
              Well, I used to use an ultrasonic cleaner quite a bit in a laboratory years ago for circuit boards. It used trichlorotriflouroethane instead of water. Ha, spell checks got nothin' for that one. Anyway, you could use distilled water as well I suppose. With our cleaner you had to be careful because it would ruin some plastics. Any connectors you used you had to sacrifice one by dipping it in there before trusting the board to it.
              • caphair
                • Nov 2011
                • 1249
                So distilled water is used because it doesn't leave a residue behind? It has nothing to do with it cleaning contaminants because it "strips" them away due to its "hunger" for ions? Here's another excerpt from another site
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  As your excerpt says ultra pure is used in the semi conductor business because it leaves no contamination. If your looking to strip things, it's best to use something specific instead of water. The chemical we used was meant mostly for flux. It dissolved flux very well. Water would not. Yes water can strip steal, it's called rust. Those sites are being disingenuous. We used to use freon to clean tape residue in tape recorders. It removed the brown residue very well. In the days of digital tape you had to keep the heads clean. I never lost a tape because I cleaned the path before each use. I watched more lazy people chew up several tapes from a dirty tape path.
                  I've got a glass bottle here I got in the mid eighties. I use it on cassette deck heads. Works great. Trichlorotriflouroethane. Works great on tape paths, much better than alcohol.
                    • 31052
                    freon is best - too bad it's banned by environuts because of lies made by the usg.
                    • rhomanski
                      nowhere man
                      • 5157
                      • U S of A
                      It's still used in some ways. Trichlorotriflouroethane or freon 113 is used by the military for cleaning stuff. Freon is also used to pressurize waveguides in high power imaging radar systems. It keeps down the arcing in the waveguide. It's just illegal in your new car and refrigerator and AC system. If it was designed for the old freons you can still use it if you can find it.
                        • 31052
                        have you seen the price? even 20years ago it was priced like liquid silver!
                        • caphair
                          • Nov 2011
                          • 1249
                          I'm still confused why distilled water is used as a final wash of circuit board manufacturing. Does it strip flux etc or?
                          • rhomanski
                            nowhere man
                            • 5157
                            • U S of A
                            No, not really. It's cheaper, leaves no residue, and just gives a physical flush of all solder particles, dust, dirt, and grime. At least I would guess. I'm not an engineer. I don't work for the manufacturer. Just an old soldering iron jockey.
                              • 31052
                              pcb manufacturing uses water-based and soluable fluxes.
                              • caphair
                                • Nov 2011
                                • 1249
                                Ah now it makes sense. So why do people use distilled water for water damaged boards? I can't see how it'd be a strong solvent for removing corrosion
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  distilled water won't add additional salts to a water damaged board, that's about it...
                                  It will wash ionic compounds created or left there where other solvents would leave behind.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    When you deionized water I would say that you lower the pH of water which makes it acidic which makes it corrosive to metals, but the mineral ion content is out of the water. Distilling takes other contaminates out of water. With that said when I worked on sub-micro particle analyzers our Chemist use to triple distill the water and deionize it. First she used sulfuric acid to clean the cuvettes. She then use triple distilled/deionized water to rinse out the cuvettes 25 times. She then filled the cuvette with the triple distilled/deionized water and then she put a 40nM sample into the cuvette using a filter to block out any larger particles than 40nM. She cap the cuvette and sealed the cap with tape. This was then put into a refrigerator. This sample had to be used for measurement with-in 3 days before the sample was no good as it would acquirer bacteria in it which would render it useless.
                                      • 31052
                                      most boards arent really "water" damaged,
                                      it's milk, coffee, coke, piss, beer - the list is long.
                                      your flushing the sticky mess off the board with the water.
                                      • rhomanski
                                        nowhere man
                                        • 5157
                                        • U S of A
                                        Ha Ha Ha, that's funny. One night after a drunken party at college, I woke up in the top bunk and heard water hitting the floor. I rolled over and there was my roommate peeing on my other roommate in the dark. He woke up and started yelling. I rolled back over. They were both dicks anyway. Maybe the beer from the keg would cut the smell of pee?
                                        • Techie_hobby1
                                          Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
                                          by Techie_hobby1
                                          Need some help please with a few components on this small board so that I can troubleshoot the circuit.
                                          The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
                                          J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
                                          J2 - to DC Output
                                          J3 is Battery cell connector
                                          however I am struggling to identify if:
                                          Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....
                                          07-24-2025, 12:43 PM
                                          20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                          by sam_sam_sam
                                          I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                          At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                          Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                          04-09-2023, 08:04 PM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • Tarot Superstars
                                          Short Circuit tester
                                          by Tarot Superstars
                                          Hello.
                                          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                          Link
                                          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                          https://www.youtube.com/watch?v=0eixDdCpiO4
                                          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                          09-25-2023, 09:11 AM
                                        • Alimash
                                          op amp circuit function?
                                          by Alimash
                                          I am repairing a ups which doesn't turn on ,it has the following ICs:
                                          SG3525 used to drive inverter mosfets.
                                          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                          A LM358 and TL074 for control mechanism and of course the uController.
                                          The SG3525 is shutting down every time the ups is turned on.
                                          I want your help to know the function of LM358 and TL074 in the system.
                                          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                          07-31-2025, 07:45 AM
