How much current goes through me when I touch 120VAC?
  • fzabkar
    • Mar 2009
    • 772
    Re: How much current goes through me when I touch 120VAC?
    Originally posted by Spork Schivago
    Did you lose consciousness?
    No, just some pride. :-)
    • fzabkar
      • Mar 2009
      • 772
      Originally posted by stj
      probably not as dangerous as the 10-20KV i got hit with from a CRT, but that was residual so hardly any current!
      My boss (a mad Irishman) demonstrated a TV's protection circuitry by grabbing hold of a CRT anode and then switching on the TV. The TV's PSU hiccuped and he remained unharmed. I think you will find that the ABL current limit is typically set at 1mA which is probably not enough to kill you.
      • Spork Schivago
        • Mar 2012
        • 4734
        • United States of America
        #63
        Originally posted by budm
        The AC house wring in the US are fed with power transformer 240V with center tap, the center tap is connected to earth ground, the safety GND wire is also connected to the center tap, the neutral wire is also bonded to the SAFETY GND. The The Voltage between L1, L2 is 240 and it is usually used for electric stove, Dryer, etc.
        http://hyperphysics.phy-astr.gsu.edu...ic/hsehld.html
        http://www.esgroundingsolutions.com/...he-main-panel/
        I think both sides on my breaker are connected together Budm. I'm attaching some pictures. In the picture you attached, they show normally 240V is getting 120V from each side of the panel. None of my 240V lines are like that at all. All of them get it from the same side. I've attached some pictures for you to see of that too. I'm going to read the links you linked to.
        If my two sides of the breaker box are separated, should I try to run all the 240V's like it's ran in that picture you attached? Where one hot is on one side of the breaker panel, the other hot is on the other side or don't it really matter? I'd think it probably wouldn't matter so much because I'm not drawing super crazy amounts of current or anything. So it really shouldn't matter, right?
        -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
        • Spork Schivago
          • Mar 2012
          • 4734
          #64
          The first picture is a bit blurry but shows where the hot lines from the second picture go. The third picture shows how I think they're connected, at the bottom there. I think the panel is just a big U. Then the last picture there, that's one of the 240V breakers. I should have put black electrical tape on the white HOT closer to the actual circuit breaker. You can see it here a few inches back. I was trying to keep it up to code.
            There are two buss bar one for L1, one for L2 coming down in the middle section that you cannot easily see in the pictures.
            http://www.bobvila.com/articles/wiri.../#.Vzo2DvlVhBc
            BTW:https://www.badcaps.net/forum/attach...7&d=1463430832, those 3 incoming power wires do not look good, it looks like they are running hot.
            Those terminal should be check and tightened once a year by qualify electrician, those are aluminum incoming wires.
            http://www.hankeyandbrown.com/electrical
            http://www.fluke.com/fluke/uses/comu...el_overheating
            http://www.circuitbreakersblog.com/tag/overheating/
              • 31199
              lol - he wont do that on most tv's
              the safety is not a current limit - it's an overvoltage cutout.
              usually set to cut the power at about 22KV
              unless it's a really big tube - then it could be over 25KV
              • desert-rat
                • Mar 2014
                • 4103
                I had a guy that worked with 400hz stuff tell me that being shocked by it feels different than 60hz.
                On a side note,my dad went back to the 25hz days. He said it was hard to read with a bulb on 25hz as you could see it pulse,or flicker.
                  • 31199
                  probably true, that's the rough framerate of cinema projectors.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #69
                    Thank you. How do I find a qualified electrician? The electrician who wired this house, I don't think he was qualified. I think we got scammed, hook line and sinker. Is there someway to make sure they're actually qualified and know what they claim they know?
                    So, from that article, it shows 240 is 120V from one bus and a 120V from another bus. But then they talk, further down on the page, about how 120V is just a double pole breaker (which seems to imply it's 120V's from the same bus). The giant bars that the breakers hook into are the buses. I have two hot buses, right? I think I finally understand. I thought because my double pole breaker was 2 breakers on the same side, ecah breaker was connected to the same bus. But from what you're saying, I'm guessing left side bus crossses over to the right side and vice-versa every other breaker, right? So I can hook up double pole breakers and get the 240V that I need...
                      http://www.thisoldhouse.com/toh/arti...213817,00.html
                      http://electrical.about.com/od/panel...e-Breakers.htm
                        • 31199
                        u.s. electrical standards are clearly bullshit.
                        in europe those incoming terminals would have to have 2 clamp-screws to be legal.
                        we dont trust only one to hold the wire on high current circuits.
                        can you show us what's on the other end of the large wires.
                        if they go to a sealed meter then the power company may need to replace them.
                          Can we see pictures of Euro circuit breaker panel you have in your house to see how it is done?
                            • 31199
                            not really, the meter & master-fuse have covers on them with company seals fitted so we cant run a meter-bypass wire!
                            also, all the bussbars and breaker terminals are covered by a panel.
                            i will try to get pictures of the actual components unfitted.
                            here is a description of how a domestic system is usually rigged,
                            first the cable from the street goes into a master 100A fuse,
                            that feeds the meter and sometimes a timeswitch. (to switch between different rates at different times - it feeds back to the meter)
                            the meter then goes to the master switch - 2 pole.
                            the master switch feeds the bussbar(s) feeding the breakers.
                            and the breakers then go to the individual wires that feed everything.
                            sockets are wired on a ring btw - look it up.
                            ok.
                            this is why i cant foto it.
                            they are shielded like this:
                            that is no longer legal btw, AFAIK all new installs must use metal boxes.
                            some junction boxes.
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              #74
                              My box is generally sheielded as well, I just removed the sheilding so I could work on it. I'm pretty certain this box isn't up to code. I don't think my dad hired a certified master electrician. I think the guy was an idiot and just saw how his house was wired and wired it how he thought was right.
                              I'm pretty sure code says the electrical lines in the attic, they need to be so far away from the scuttle, not directly over it. Also, they shouldn't just be dangling in the air like they are. They should either be stabled to the rafters, drilled through the rafters or in conduit. We're in the country, I have no idea how this passed inspection when the house was being built...one girl came, three times during the build phase. That was it.
                              I'd like to get a qualified electrician in to check everything out and make sure everything's good. I'm sure that'll cost some money. There where wires (ground / neutral) that weren't even hooked up in the box. There were wires in the outlets that weren't hooked up. I guess they could have come out.
                              Also, the wires that go into the outlet, they got some bare metal showing. If I were to do it, I would have stripped them jus right, so no bare metal was showing. I don't think that has much to do with code there, but still, I think a real professional would have done a much better job and probably charged much more than 10$ an hour....
                                • 31199
                                that's below minimum wage here!!!
                                a certified electrician would probably cost 50-70us$ an hour.
                                • fzabkar
                                  • Mar 2009
                                  • 772
                                  It was an old Philips set (from the 1980s ?). I think I may be wrong about the ABL, though. The load on the EHT would definitely have caused the video amps to shut off, but I also heard the main PSU hiccup. So perhaps it was the current draw on the primary side of the FBT (from the B+ rail) that caused the PSU to go into overload protection. It would only require a few mA at 25kV to load the PSU.
                                  • 25kV x 4mA = 100W
                                  I wouldn't be game enough to try, though.
                                  • kaboom
                                    "Oh, Grouchy!"
                                    • Jan 2011
                                    • 2507
                                    One thing to do if from a dead-start. It's a bit different if you grab it after the aquadag cap has charged!
                                    "pokemon go... to hell!"
                                    EOL it...
                                    All style and no substance.
                                    guilty,guilty,guilty,guilty!
                                    guilty of being cheap-made!
                                    • trepachka
                                      Converting HP EliteBook 840 G7 non-touch to touch if possible
                                      by trepachka
                                      I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
                                      The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
                                      I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
                                      04-27-2024, 11:15 PM
                                    • Prott
                                      Surface Pro 4/5 - no touch after LCD change
                                      by Prott
                                      I have a question that's driving me a bit nuts recently.
                                      Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
                                      - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
                                      - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
                                      01-25-2023, 12:42 PM
                                      Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                      by sam_sam_sam
                                      I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                      I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                      I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                      02-04-2025, 08:08 PM
                                      Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
                                      The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
                                      All AP21X2SG-13 AP21X2MPG-13 devices are available...
                                      10-23-2024, 03:33 AM
                                    • DynaxSC
                                      Extreme High Current & Low Voltage Short Killer ??
                                      by DynaxSC
                                      Hi Folks
                                      I'm looking for a extreme high current short killer solution for a reasonable cost.
                                      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                      After taking off the socket, the shorts dissappear again.
                                      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                      10-15-2024, 10:13 AM
