UPS Battery Charging - Are My Batteries Boiling?
  • Lojix
    Tech Enthusiast
    • Mar 2015
    • 24
    I have just put 2x 7.2Ah 12v sealed lead acid batteries into one of my UPS's after servicing them (they were recovered from old equipment and were badly drained). I refilled the cells, charged them up and they test okay. The UPS is an 'Opti-UPS 1000C', 24v (2x12v) after connecting it up, I can hear the batteries bubbling as they take the charge current and measure at 28.5v on my DMM.
    Question is... Does this seem okay? When charging the batteries, it's always said leave the cells uncapped to let the gas escape and avoid pressurising the cells and causing the battery to explode. However this is not possible in a UPS and I have never noticed the batteries bubbling in any of my UPS's prior to this.
    I'm having visualisations of a battery exploding and covering me in sulphuric acid!
    Tech Enthusiast - Lojix Net
    Intel Core i7 3770K | GIGABYTE Z68XP-UD4 | 32GB RAM | Ge-Force 660Ti/OC | Kingston Hyper-X 240GB SSD| Seagate Barracuda 2TB 7200 RPM​
    Web Browsing Powered By Firefox
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8709
    Re: UPS Battery Charging - Are My Batteries Boiling?
    Recovering those SLAs seems very unlikely, of the ones that I have, even after watering them, they just don't have the capacity like they used to. There's no need to uncap as they are design to release pressure automatically. At 28.5V if your 2 batteries are gassing, if they don't stop gassing relatively quickly, they are likely tired and won't run the UPS for long (or at all).
    • Lojix
      Tech Enthusiast
      • Mar 2015
      • 24
      Thanks for clarifying. Based on that information I might move the one sitting under my desk connected to my PC. Breathing even trace amounts of sulphur couldn't be great... and yes, I agree about the capacity loss after recovering SLA batteries. Their initial charge can take 3 or even 4 days at low current and the voltage doesn't seem to climb much at all for a long time. But I seem to have a surprising ratio of recoverables. Although I've noticed the more sulphated the plates are, the more it affects their holding capacity, but most are still definitely at a usable level.
      • japlytic
        • Oct 2005
        • 2086
        In a book of electronic circuits, I saw a circuit for a temperature compensated SLA battery charger, and the description of the circuit highlighted that the charging characteristics of SLA batteries are strongly linked to ambient temperature, with temperature compensation being desirable to prevent overcharging and undercharging.
        I think temperature compensation for SLA battery charging is highly desirable in UPS units to help maximize battery life - would you agree?
        • Lojix
          Tech Enthusiast
          • Mar 2015
          • 24
          I agree completely and via use of a thermistor, doesn't seem to be that difficult to incorporate into the system. I'm not sure to what degree temperature compensation is built into the charge cycle of UPS's (if at all). I'm putting it down to cost over effectiveness on the manufacturers' part... One thing for sure is that 'effectively' charging SLA batteries is a whole lot more involved than one might first think and considering its a fundamental function of a UPS, they don't seem to do a great job at it!
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8709
            Actually though sulfuric acid is dangerous and will eat through organic materials, I'd much rather be around it than say, ricin or plutonium or something...
            The only risk for these batteries is the explosion risk if you don't vent any hydrogen produced by the gassing.
            Most of the dead SLAs I get end up with internal shorts or high self discharge and thus useless... and I still should get a new set of batteries for my 1000VA UPS that's just sitting there empty after the last set of batteries died.
            I wouldn't say charging the batteries is a fundamental function of a UPS - it's to keep the connected devices running. Charging is only a recovery function after it has done its job...
            • Lojix
              Tech Enthusiast
              • Mar 2015
              • 24
              Good point. Based on that comparison I'd have to agree.. Although in my experience the average home office is generally not as likely to contain Ricin or Plutonium.
              Storing a box underneath you at your desk that carries a risk of explosion, albeit slim to unlikely, is still a risk that deserves a little caution and respect in my opinion.
              It goes without saying that the primary function of an Uninterruptible Power Supply, is to keep the supply of power uninterrupted. However I would find little use for a UPS which did not incorporate some type of recovery function in the system. Inefficiency and the sheer cost of replacing batteries would be just the first of many points not worth mentioning.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                if the charger is a 3 stage type it may hold around 14.4 for several hours.it waits for the current to drop to a preset value and switches to float.those batteries may just be junk and will never drop thus boiling them.one only needs to slightly moisten the separators.no free liquid needed or desired.most of that type are not worth doing anything to unless fairly new.they are usually goners.
                • Lojix
                  Tech Enthusiast
                  • Mar 2015
                  • 24
                  Really?! This is the first I have received this advice. Is this due to contained pressure/equilibrium or other another reason? ...I'm guessing it's ideal for the chemical reaction?
                  Probably like many others, I've been following the misconception that they should be filled to just cover the plates.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8709
                    Charging batteries at (cells)*2.4 volts per cell CC to CV, is the "quick cyclic" charge voltage. This has the problem of possibly slowly splitting water but charges the fastest safely. Ideally float voltage is more like 2.3 volts per cell (and both these numbers are dependent on temperature). I would think most UPS are two stage charging, which may not be the best for battery longevity but has the fastest recovery time and cheap design cost.
                    The AGM cells should not have free liquid in them at all - it's also called "starved electrolyte" for a reason - it's not totally saturated. The age old idea to cover the plates is for flooded (i.e. no glass mat) cells only. The chemistry between the two is the same, just that you don't need as much electrolyte as the mat holds the electrolyte by the plates.
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      sealed lead acid battery use absorbed glass mat or gel they have no spill-able liquids.
                      You are thinking of automotive battery's that use flooded construction.
                      My pc
                      CPU : AMD PHENOM II x4 @ 3.5Ghz
                      MB : ASUS M4A89TD PRO USB3
                      RAM : Kingston ValueRAM 16gb DDR3
                      PSU : Cooler Master 850W Silent Pro
                      GPU : ATI Radeon HD 6850
                      • Lojix
                        Tech Enthusiast
                        • Mar 2015
                        • 24
                        Thanks guys. Somehow that little piece of pretty important information slipped by me.. So would over filling the batteries have an adverse affect and if so, should they be drained to the appropriate level?
                        I read somewhere that when the rubber cell caps are pulled inwardly at the cell opening, it means they need water.
                        • rhomanski
                          nowhere man
                          • 5157
                          • U S of A
                          Is this you? Or a relative?
                          sigpicThe Sky Is Falling
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            dilutes the electrolyte.and now cant remove excess without weakening it more.and if the cells vented with the battery hot when it cools you get a vacuum.says nothing about water loss.
                            • Lojix
                              Tech Enthusiast
                              • Mar 2015
                              • 24
                              Summed up perfectly
                              • Lojix
                                Tech Enthusiast
                                • Mar 2015
                                • 24
                                Me on a 'bad hair' day
                                • carrzkiss
                                  Cyberpower cps1500avr not charging batteries
                                  by carrzkiss
                                  Hello, all.
                                  Cyberpower Battery Backup Unit.
                                  I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                  When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                  In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                  Checking the voltage, it was down to 22v.
                                  I quickly removed everything...
                                  06-15-2024, 02:10 PM
                                • orientalsniper
                                  LA-L246P Not Charging Batteries
                                  by orientalsniper
                                  Hello all, I've tried multiple batteries, replaced the charging IC (ISL95522AHRZ) and updated the BIOS.
                                  It detects the power adapter (90W), so the DC IN jack is okay.
                                  It shows "IDLE" instead of "Charging", battery health shows "Excellent" on the BIOS.
                                  09-15-2025, 02:29 PM
                                • coasterghost
                                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                  by coasterghost
                                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                  System Hardware:
                                  Processor: AMD Ryzen 7 PRO 5850U
                                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                  09-08-2025, 10:46 PM
                                • Thomasraud
                                  Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                  by Thomasraud
                                  i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                  QUOTED
                                  -It works on charger (without battery connected-only charger)
                                  -It works on battery (without charger connected-only battery)
                                  -& it also works when plugged in battery & charger, but it's not charging the battery
                                  //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                  and..
                                  QUOTE
                                  The IC cannot maintain the input current level
                                  06-28-2022, 06:47 PM
                                • Scoff
                                  HP Probook 470 G4 - Power and Charging Problem
                                  by Scoff
                                  Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                  Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                  07-03-2023, 09:28 AM
