LED power supply
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LED power supply
    Just looking at the photos it looks like its barely even touching the chassis, it needs to be firmly pressed against it to cool.
    • michael dranfield
      • Jan 2016
      • 232
      • England
      Here are mine stuck to the ceiling on pvc trunking, you will notice the fluorescent light on the ceiling, as my place is 1700 sq ft I dont have them on any more the whole place is lit with LED s put 12 volt to each end of your strip because if you dont the voltage will be lower at one end and the led s wont be as bright due to voltage drop , my first psu blew as the main reservoir cap dried out so I would replace this as well.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Nice shop there
        • diif
          • Feb 2014
          • 6978
          • England
          It was securely pressed up against the heatsink with paste and a clamp and the solder was fine.
          Does this look like a suitable replacement ?
          http://uk.rs-online.com/web/p/mosfet...stors/7192822/
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Yeah maybe get a higher current one ? Also replace primary caps too as well as the resistor, diodes and possibly controller.
            • diif
              • Feb 2014
              • 6978
              • England
              #26
              Those two Dongbaohe ?
              Could you suggest a better replacement ?
              Yeah, nice shop Michael, look at all those storage drawers
                • 31032
                btw, that carbon resistor is not rated for a high enough voltage, you need a 400v+ rated part there
                • michael dranfield
                  • Jan 2016
                  • 232
                  • England
                  #28
                  What you see is just a tiny part , I can park 3 cars inside , 4 if I tidied up a bit !
                  Got more semis than a component wholesaler, the back room has no place left on the walls for any more draws !
                  I will post some pics tomorrow .
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #29
                    Thanks, I'm guessing you men the one that isn't there any more ?
                    Oh wow, i always get a nice warm glow when i have the components to hand and don't have to order. Must be cool to have just about everything you'll ever need....and more
                    Might be easier to drive to you than RS in future lol.
                      • 31032
                      yes, but i cant make out the colour-codes from the first batch of foto's
                      you need to use a 500v metal oxide job because it's connected to the rectified mains.
                      it looks like it's(was) acting as a sort of pullup/down resistor on the gate/base
                      if it had too low a resistance the current when the device was on could have slowly done it in.
                      without it the transistor could have jammed on and blown.
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        I got an LM317 regulator smoking one day powering up a string of 8 LEDs taken from a small flashlight. I guess it's time for a better heatsink and new paste
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #32
                          Brown, Black, Orange, Gold. 10kohms
                          http://uk.farnell.com/panasonic-elec...tedCategoryId=
                            • 31032
                            i wonder how much current that could pass at 360v?
                            it was a 1/4w carbon job.
                            • SteveNielsen
                              Retired Tech
                              • 2327
                              Ohm's law says 12.96 watts. A 1/4w ain't gonna cut it.
                                • 31032
                                that could explain the failure then!
                                it's pulsed, but the fact that standard carbon resistors arent rated for that voltage dont help!
                                • michael dranfield
                                  • Jan 2016
                                  • 232
                                  • England
                                  #36
                                  Take a look at this , I have to stand on a chair to get to the draws next to the ceiling !
                                  • michael dranfield
                                    • Jan 2016
                                    • 232
                                    • England
                                    #37
                                    Car in for a service as well !
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      #38
                                      Wow, very nice indeed. Impressive stuff.
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        #39
                                        Now that's just showing off and taking the p*** lol
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • CMCM
                                          Russound CA4 Power Supply Repair
                                          by CMCM
                                          Hello Everybody,
                                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                          The outputs marked 12v and 20v are all measuring only 1v.
                                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                          The capacitors physically look clean (no bludgesor leaks) and...
                                          07-03-2025, 01:12 PM
