Couple questions about a Coffe Maker - No Power
  • caphair
    • Nov 2011
    • 1249
    Hi guys I have this digital coffee maker that uses a em78p163n microcontroller.
    Nothing happens when on button pressed, traced it to 1v on the base of the transistor that switches the relay and powering the heating element.
    Noticed if I ground this pin the heating element turns on.
    What I'm wondering is, does the microcontroller ground this pin enabling it on as I'm simulating manually?
    Another thing there's a power on indicator led in series with this pin that has 1.52v on its anode. It powers on with a multimeter on diode scale but if I try grounding the anode nothing happens. Maybe it needs more than 1.52v to turn on which makes me question if the microcontroller isn't outputting enough voltage? Am I wrong to assume that?
    If anyone can help me better understand exactly what's happening (during normal operation) when power switch is pressed I'd greatly appreciate it. Thanks!
    Re: Couple questions about a Coffe Maker - No Power
    So the transistor that drive the relay has 1V feeding the Base of the transistor, so you do have 0.6~0.7VDC between the Base and Emitter legs of the transistor? How is the relay coil connected to the Transistor and the Voltage source (VCC) for the relay coil?
    Pictures of the board and transistor/relay section?
    • caphair
      • Nov 2011
      • 1249
      I'll get some pics when I can. I was looking at the Datasheet for the microprocessor and it says it needs an operating voltage of 2.1-5.5v but I only measure 1.52v at the VDD pin.
      • fzabkar
        • Mar 2009
        • 772
        It definitely sounds like a problem with the supply. These appliances often derive a transformerless supply directly from the AC input via an 0.47uF 600V film capacitor or similar. Is there a zener diode at the VDD pin?
        What is the voltage spec for the relay?
        • caphair
          • Nov 2011
          • 1249
          Here's a pic of the power section. Unfortunately don't have access to a computer and my phone only uploads one pic at a time so excuse my posts just for pics
          • caphair
            • Nov 2011
            • 1249
            The top side
              • 31054
              resolder that 4pin connector.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Not just that. Look at the solder joints for the two zener diodes (ZD1 and ZD2) too - they look quite bad. And that's not surprising, because you can see they darkened the board a little. It's possible that the film cap could have gone leaky, letting more current in that necessary. Therefore, I would suggest to check all diodes for short-circuit and check all resistors for open-circuit. Those (probably no-name) electrolytic caps could be letting too much ripple too, if they have gone high-ESR or O/C.
                • caphair
                  • Nov 2011
                  • 1249
                  Yes those two zener diodes did darken the board around them. They tested fine in circuit, but one of the mains diodes outputs the low voltage 1.52v leading to the microcontroller VDD. I'm guessing this board uses zeners as voltage regulators?
                  • fzabkar
                    • Mar 2009
                    • 772
                    ZD2 regulates the supply for the microcontroller. I believe you should measure 5V across it.
                    ZD1 is the 24V supply for the relay.
                    I will upload a circuit diagram if you can first measure the resistors.
                    • caphair
                      • Nov 2011
                      • 1249
                      All of the resistors? Btw I measure 28v at ZD1 and 1.52 at ZD2
                        • 31054
                        desolder zd2 and see what's printed on it.
                        • caphair
                          • Nov 2011
                          • 1249
                          Actually the resistor above ZD2 with color band of 1k measures open in circuit
                          • fzabkar
                            • Mar 2009
                            • 772
                            That 1K resistor must be the culprit.
                            Code:
                                                    .-------+------> JP2-3
                                                   D |    |    brown
                                                    V   ---
                                                 ___  |    |
                                .---------------------------------|___|--+--|<---+-----.
                                |                      D     |
                                |  film                        |
                                | capacitor      bridge              |
                                |  ||    ___  .-----.  C2  ZD1    ZD2  |  black
                             A o--+-+--||---+---|___|---|~  +|------+---+--+--+---+--+--)-> JP2-1
                                | | ||  |    .--|~  -|--.  |+ | | |+ | | |  VDD
                                | | ___ |    | '-----' | === z | === z --- |
                                | '-|___|-'    |  D x 4  | --- A | --- A --- |
                                |         |      |  |  | | '---+--+--+-> JP2-2
                                |         |      |  |  | |   |     white
                             N o--)------------------+      |  |  | |   .-.    DGND
                                |         |      |  |  | |   | | 1K
                                |     Heating | |   |  |    | |
                                |     Element | |   |  |   === |
                                |         '-'   |  |   AGND |
                                |         |   |  |     |       relay
                                |  12A 250VAC  o  __|  | D5    |       control
                                |        \  ||(    V      >|  ___
                                |     Relay \. ||(    -    Q1  |--|___|---> JP2-4
                                |         o ||(__   |  2SA733 /|      red
                                |  24V 15mA coil |   |  |     |
                            https://cdn.badcaps-static.com/pdfs/...ba95df4f6d.pdf
                            • caphair
                              • Nov 2011
                              • 1249
                              Thanks for that fzabkar! I'm curious how that resistor being open causes low voltage? Bc it doesn't complete the zener's path to ground?
                              • fzabkar
                                • Mar 2009
                                • 772
                                There is an alternative path back to the active terminal.
                                BTW, I would replace ZD1. ZD2 normally carries around 20mA, so when the 1K resistor went O/C, ZD1 would have been called on to carry this additional load. At 28V, that's an additional 0.5W. Normally ZD1 would only be carrying the relay coil current (when the relay is off) plus a little extra.
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  Can you explain what you mean by there is an alternative path? Just trying to understand exactly how that resistor caused the issue, was it helping limit voltage?
                                  • fzabkar
                                    • Mar 2009
                                    • 772
                                    From JP2-2 go upwards and left. There is a diode and resistor going back toward A.
                                    ZD1 preregulates the supply to 28V (analogue). Then the digital supply is derived from the analogue supply by a traditional resistor/zener combination. The resistor limits the current to about 20mA before ZD2 begins to lose regulation.
                                      • 31054
                                      if you replace the zeners or that resistor, put them a few mm above the board to improve cooling
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        So with that resistor open it reroutes to JP2-3? What's this line for?
                                          20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                          by sam_sam_sam
                                          I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                          At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                          Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                          04-09-2023, 08:04 PM
                                        • magneh
                                          Behringer Eurolive B205D repair - help identifying transistor
                                          by magneh
                                          Hello
                                          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                                          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                                          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                                          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                                          Still, I need to replace this transistor....
                                          06-18-2025, 02:34 AM
                                        • elsomer
                                          help to identify transistor msi ms-15ck1
                                          by elsomer
                                          hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                                          02-17-2025, 05:30 PM
                                        • rddube
                                          Help with blowing transistor NAD T752 receiver
                                          by rddube
                                          I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                                          Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                                          I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                                          09-01-2022, 05:19 AM
                                        • amigo744
                                          xbox series x u82 5 pin transistor voltages ?
                                          by amigo744
                                          hello there,
                                          xbox series x hdmi u82 transistor 5 pin,
                                          can anybody tell me voltages of this transistor in standby and power on mode ???
                                          on which pin of this transistor are the voltages ?
                                          regards
                                          08-16-2023, 08:05 AM
