Questions about PicKit 3.
  • mariushm
    • May 2011
    • 3799
    #81
    Re: Questions about PicKit 3.
    Yes, you can do that.
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      #82
      Thanks Mariushm. I think because the questions I have now are more programming questions rather than hardware, maybe they're best suited to the Microchip Forums. My account finally got approved so I can post there now. Not 100% what forum topic I should be posting in though. There's a lot of time! I was thinking maybe the 14-Bit Core (instructions, reset, WDT, specifications...) PIC12F6xx, PIC16Fxxx, PIC16F6x, PIC16F7x topic. They got a section for the XC8 compiler that I'm using as well. Maybe I should post in there instead. Thanks for all the help! I think I'm finally getting this stuff figured out. Once I get the program finished, if you want a copy, so you can look it over, maybe provide some tips or something, I'd be more than happy to post it here for you guys.
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      • tommy1331
        hp envy 15t k000 debugging
        by tommy1331
        Hi, I'm quite new to this, I am trying to debug a faulty motherboard (DAY31AMB6C0). There was a fault in the DC input circuit with a faulty TVS diode after the first MOSFET shorting the VAD rail to ground. I was able to clear that fault by removing the diode and now the input section seems to be working correctly and I get the V3PCU power rail.
        But trying to start the board still fails, I put some RAM in it and shorted the power button to start it up but it only blinks the power LED in the DC jack assembly 3 times. Maybe the AC detect circuit is broken? Or is this more likely to be...
        04-28-2025, 08:12 AM
      • Ihandyrepair
        ID smd 6pin chip - GM2 for electric scooter display
        by Ihandyrepair
        Hi
        working on a not turning on Wheelspeed WS1 scooter.
        diagnosed - issue is the display/power button
        on the board, with the multimeter I noticed there is a short to ground. as the red wire has 0 ohm to ground.
        with infrared camera, this chip (photo circled) would heat up if I push power button on.
        but I can't find any replacement or online info of this chip.
        on the chip you can see it has a label GM2H, I have another good working display with the same chip but it has label GM2C
        could anyone help me id this chip and guide me to...
        05-08-2024, 06:59 PM
      • seppde
        Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
        by seppde
        I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
        ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
        The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
        In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
        02-09-2024, 05:19 AM
      • belalmondeo
        Car code scanner OBD1 adapter enquiry
        by belalmondeo
        Hello everyone there
        If You do remember me then I am Belal who posted an issue of his J2534 pass-thru Multi-Diag 2015 OBD II device a while ago and aside from my thanks that show my gratitude to all of those who have given me help with my issue I just wanted to go straight into my question which is whether using the OBD II to OBD I adapter to diagnose an older model vehicle like a GM 12 adapter safe enough and not gonna cause any catastrophic failure to my device and if it still can perform scanning with no issues?
        there's a link for the adapter: https://ebay.to/2UCWDDx
        04-05-2019, 06:00 PM
      • thrinrot
        Zotac GTX 960 2GB- 6pin PCIE Power not recognized
        by thrinrot
        Hi all!
        A friend of mine brought me a defective Zotac GTX 960 with a failing power detection.
        Even though the 6 pin PCIe power cable is plugged in, the card says "Plugin PCIe power cable and reboot".
        Since I have no schematics it is hard to find out the NVVDD_PGOOD trace.
        I checked if the Controller (NCP81174) sends a Power good signal and the signal VR_RDY at pin 3 is high. So I assume the controller is not sending a bad signal (?).
        I appreciate your help! :-)
        09-25-2021, 12:29 PM
