Is this resistor toast?
  • mikay786
    • Aug 2014
    • 765
    Is the below resistor toast? I had my brother in law look at cb radio as he's into them and he says it is just a dummy resistor and its normal.
    But looking at it, it looks badly charred, don't want to mess with it if its ok and looks a pain to remove board and the radio works fine.
    • 31165
    Re: Is this resistor toast?
    that's done.
    what make / model radio is it?
    • mikay786
      • Aug 2014
      • 765
      found a pic of resistor
      blue grey gold gold
      can I measure it in circuit board?
      • mikay786
        • Aug 2014
        • 765
        Yaesu FT-290R MK2
        • SteveNielsen
          Retired Tech
          • 2327
          I've seen toasted resistors like that still be within tolerance and keep working but it raises the question of why did it overheat like that in the first place. Look for THAT problem. It needs to be replaced regardless but it is not a dummy load resistor, it's only a 1/2 watt.
          • mikay786
            • Aug 2014
            • 765
            Is it possible to measure inline?
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              dummy load on a CB, the antenna did not have a proper loading coil would be my guess.
              Follow the white rabbit.
                • 31165
                6.8ohm 5% probably about 1w and it should be non-inductive.
                  • 31165
                  top-left on the 3rd schem.
                  6.8ohm .5w
                  • mikay786
                    • Aug 2014
                    • 765
                    Thanks STJ, I'm probably just going to leave it as the unit is functioning perfectly. My brother in law used for about a week with no issues.
                    Its a bit outside my comfort zone, replacing it isn't an issue but taking the unit apart and putting it back together.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      what frequency is the CB band in the UK? Same as the US (11m)?
                      • mikay786
                        • Aug 2014
                        • 765
                        2m
                          • 31165
                          depends if you mean the legal one!
                          there are actually about 4.
                          and they arent 2m - that's a HAM band.
                            • 31165
                            http://ukspec.tripod.com/rf/handheld.html
                            one thing you wont see mentioned,
                            a lot of people in Europe are (mis)using the PMR band using modified radio's or ham radio's to transmit 16 channels of 5w power on the 8 channel 500mw band!
                            • SteveNielsen
                              Retired Tech
                              • 2327
                              It's on the 4th schematic, not the 3rd, and it is not a dummy load resistor. It is inline with +13.8v supply. Something shorted. Possibly a cap downstream connected to chassis gnd shorted then opened internally, like c34. The radio would probably still work without c34 but probably noisier audio and/or less stable than with it since that's audio output section.
                              • mikay786
                                • Aug 2014
                                • 765
                                I know it should be changed but my brother in law told me to leave it alone. If it ain't broke, don't fix it he says. Anyhow will see, just working on that Sony HiFi at moment.
                                • rhomanski
                                  nowhere man
                                  • 5157
                                  • U S of A
                                  Is my toast resistive?
                                  sigpicThe Sky Is Falling
                                  • goontron
                                    5000!
                                    • Dec 2011
                                    • 4108
                                    • US
                                    i don't know about yours, but mine is. I like a nice layer of carbon on the outside
                                      • 31165
                                      if you burn it enough it will be!
                                      • rhomanski
                                        nowhere man
                                        • 5157
                                        • U S of A
                                        Will the butter make it short?
                                        • shelby5041
                                          clock radio / radio lifespan?
                                          by shelby5041
                                          hi
                                          ive got a modern digital clock radio approx 15yrs old
                                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                          it uses very little power just a few watts i would imagine that may have something...
                                          09-14-2024, 03:30 AM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • UserXP
                                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                                          by UserXP
                                          Dear all,
                                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                          My question is, do you know of this brand of capacitors and how bad are...
                                          07-21-2025, 08:35 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
