mikrotik routerboard
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    got a rb2011uas-2hnd-in model router from mikrotik, anyone knows what value is for Q1 (8 pin chip),or does someone have a service shematic ...
    thx
  • fzabkar
    • Mar 2009
    • 772
    Re: mikrotik routerboard
    Upload a photo and someone will probably be able to work it out.
    • nbdy
      • Aug 2015
      • 162
      • Croatia
      Here is the photo
        • 31283
        try agani - use the attach option.
        • clearchris
          • Dec 2013
          • 687
          In my experience with routers, not much goes wrong except the caps. I like to put a heatsink on the cpu, and you can run these things for years, I still run an ancient asus wl500gp with openwrt.
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            it looks to be a mosfet
            My pc
            CPU : AMD PHENOM II x4 @ 3.5Ghz
            MB : ASUS M4A89TD PRO USB3
            RAM : Kingston ValueRAM 16gb DDR3
            PSU : Cooler Master 850W Silent Pro
            GPU : ATI Radeon HD 6850
              +1
              • nbdy
                • Aug 2015
                • 162
                • Croatia
                I have got a reply from mikrotik,that i short the upper and lower pins from mosfet,and if it
                turns on it is on him,if not its somthing else ...
                No luck,it will not tur on ...
                thx for trying to help
                greetz
                  The MOSFET was blown up that bad which meas the circuit was heavily over load so you need to check for low resistance of the load to that circuit.
                  Check the 4 pins on the top row against GND, then the 3 pins on the bottom row against GND to see what you get.
                  BTW, how about uploading the pictures of the whole board top side and the bottom side?
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    I agree.
                    However, routers generally come with pretty small power adapters capable of no more than 10-15 Watts output. That's enough to short a MOSFET... but to blow it like that takes a lot more energy, IMO.
                    Do you have any history of why the router failed? Left on during a storm perhaps? (i.e. damaged by lightning strike.) Or maybe the wrong adapter was used?
                    It would also help if you post a picture of the entire router board, both from the top and the bottom. That way, we might be able to figure out what that MOSFET is powering.
                      • 31283
                      arent those like the Ubiquiti units and capable of 500mw+
                      • joshnz
                        • Feb 2011
                        • 969
                        • New Zealand
                        1000mW dual chain 2.4Ghz
                        My pc
