Resistor Scanner For Android
  • xboxhaxorz
    • Jan 2011
    • 196
    https://play.google.com/store/apps/d...esistorscanner
  • mmartell
    • Oct 2013
    • 3189
    Re: Resistor Scanner For Android
    "Your device isn't compatible with this version." Damn!
      • 31139
      saved you from the spyware
      just learn the 10.
      black
      brown
      red
      orange
      yellow
      green
      blue
      purple
      gray
      white
      • diif
        • Feb 2014
        • 6978
        • England
        No spyware. It only asks for access to the camera. I run CM 11 anyway
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Does the body color matter (metal film, carbon composite, etc.) ? Can it figure out a resistor versus an inductor?
          Does it figure out tolerances correctly? How about three significant digit resistors?
          Does it figure out burned up resistors? This may be the most useful app if it can do it. The others is just more spyware/adware...
            "Can it figure out a resistor versus an inductor?" unless you tell it what you are testing, same for the color band for the caps.
            Inductor color bands.
            http://www.vishay.com/inductors/color-code-calculator/
            "Does it figure out burned up resistors?" No way.
            The lights quality will also come into play since some time it is hard to the true color of the bands.
            Just learn the color codes.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Well, it was hoping that it could detect the body color and automatically tell if it was a resistor or inductor since they look so similar And hoping that it'd have some intelligence to detect burned resistors, who knows what can be done with image recognition...
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                What do you expect for the generation that can't add or subtract without a calculator. They need a spell and speak to scan cans and tell them it's full of peas...
                sigpicThe Sky Is Falling
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Well, even a well experienced person has troubled with burned colors. If the AI in the script can estimate the color shift based on discoloration of the body of the resistor and how it can translate to the individual bands... it could be more accurate than a human reading it.
                  Also the fact that since metal film resistors are blue, inductors can be green or tan (and potentially shaped slightly different), it could make a decent guess at which ones are inductors. It technically could also have a good guess if a resistor is a flame proof or not.
                  Don't know, I'd never use such program except perhaps for burned resistors. The color shift is hard to tell without some color processing which is better left for a computer. I've seen enough resistors and even with a lookup table that has long since been memorized, takes longer than just recalling the resistor value rote ...
                  Rote does not work for inductors for me yet, sadly. Have to still use memorized LUT and figure out the multiplier. Have not processed enough inductors...
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    My phone was struggling to focus on the resistor, it might be better with newer phones with better hardware.
                    • fzabkar
                      • Mar 2009
                      • 772
                      I'm a dichromat (red and green) and so are 5% of males. I have a hard time telling red and brown snooker balls apart, but traffic lights are no problem. Blue and purple are also difficult to distinguish, probably due to the red content. I invariably need to measure resistance values or ask a colour-sighted person to identify them for me. However, these "sighted" people often have a hard time, too.
                      If I wasn't such a rusted on Luddite, I might one day trade up from my silly phone and take advantage of this tool.
                      • jinu_j
                        by jinu_j
                        Hi
                        05-03-2025, 10:51 PM
                      • mikey5791
                        by mikey5791
                        Hi to all forum members,
                        12-26-2024, 04:55 AM
                        Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook 3 Specification for Upgrade or Repair
                        This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...
                        09-07-2024, 12:40 AM
                      • MidnightRoller
                        Can a resistor lose resistance after hot air?
                        by MidnightRoller
                        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                        02-02-2022, 11:46 PM
                      • artvandalai
                        What resistor ohm will work better to repair this waterpik?
                        by artvandalai
                        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                        01-05-2025, 04:10 PM
