Fluke 179 won't tun on
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this meter, in decent condition for $20.
    It seems like, it is completely dead.
    Fuses and battery are good.
    After opening, I have found some transistors looking components that are shorted, but not completely. At one of them, it seems like the green paint came off at one leg and in the same spot, seems like the trace has a damage as well(maybe missing transistor leg, hard to tell).
    I'm not sure what they are actually to properly test them.
    They have a JC marking on them, thy could be some kind of diodes?
    I can't find schematic for this meter anywhere.
    I have also noticed, that the two PCB trace circles(buzzer contacts) are missing, even the traces leading to these two pads are not reaching the circles.
    Another thing that I have noticed, that one of the traces that goes through a via to one of the LCD LEDs is missing. Between resistor and LED.
    What could have happened here?
    I have not taken any pictures yet, but I have found some picture at the eevblog.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Fluke 179 won't tun on
    I may have found the JC component, it seems like it's a fast switching diode, that looks like a transistor. SOT323, pin #1 not connected. BAL74W.
      • 31012
      your comparison photo's:
      left image is gold plated, right photo is oxidised copper - both have pads.
      got a complete parts side foto?
      • retiredcaps
        • Apr 2010
        • 9271
        There are at least 3 internal revisions of the 179. Each have significant changes.
        Trying to remote troubleshoot using other people's pictures is like asking a surgeon to operate on you using your brother's x-rays. Post clear focused pictures of your own 179 (both sides) with the lcd removed.
        There are no schematics of the 179 publicly available. I suggest you see if the oscillator/clock is running as a start.
        --- begin sig file ---
        --- end sig file ---
        • tibimakai
          • Jan 2012
          • 3680
          I know, that it's not easy to diagnose something, from the distance.
          I will take some pictures, when I get home.
          Those pads may be oxidized, but mine are not even there.
          I have to check, if the buzzer is actually there, I don't remember.
          • tibimakai
            • Jan 2012
            • 3680
            Buzzer is missing from the back cover.
            Here are the pictures, taken with my phone.
            Hopefully, they are clean enough. If they are not adequate, I will take new ones with my camera.
            I will recheck those JC diodes.
            Actually, the trace and via is not missing from the LED, it is missing from a resistor, next to the Texas Instruments IC(left upper corner).
              • 31012
              look at the earthing ring around the central screw hole - it shows the same difference.
              nice foto - check the crystal and check for power across the tantalum smoothing caps.
              • tibimakai
                • Jan 2012
                • 3680
                Do you mean the brown color?
                  • 31012
                  forget the brown for now.
                  btw, on looking at the second image - broken solder joints on the vertical ceramic board where it's soldered to the main board.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I'm not sure, which one you are referring too.
                      • 31012
                      white ceramic board on the right about halfway up needs resoldering
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        There looks to be a break in this copper trace right at the 9V + connector (circled in red). If yes, there will obviously be no power to the microcontroller/processor.
                        The meter can also benefit from a thorough IPA bath and careful inspection via 10x jeweler's loupe. See
                        http://mrmodemhead.com/blog/fluke-77...per-corrosion/
                        PS. The picture can be clearer. If I can't clearly read the writing on the pcb, it is not good enough.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I will clean it and take a good picture. Then I will check the traces.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            That vertical trace, it was indeed broken.
                            Unfortunately joining it, did not help.
                            I have ran thin copper wires, through the via where the resistor goes to the top LED and where it was interrupted the trace. But still a no go.
                            I have made some indoor pictures, because outside is way to hot. Hopefully they are good enough.
                            The quartz does not show oscillation, only some millivolts.
                            The digital main IC is a Texas Instrument M430F437.
                            If I understand correctly, pin #1 should have the input voltage and there is 0V.
                            https://cdn.badcaps-static.com/pdfs/...487e34355c.pdf
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              I have circled places on the board that had been either dinged or rework other than what you did. The run seems to go through the LEDs. Have you check to see if one is bad? One place on the front in the upper left hand corner on a run I have circle going to what appears to be a transistor may be broken at the transistor. I have not traced out the output of that transistor to tell were it goes.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Both LEDs turn on, when I check with the meter.
                                Actually I have attempted those repairs. The first two are actually not important, because after connecting them, I have realized, that they go to the buzzer.
                                The transistor(which seems to be a diode though) repair, may not be good. To me, it seems like that leg is completely missing. The solder, may still touch that broken leg,, because when I measure it, shows as the others. If we manage to repair it, I will replace that diode.
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  That diode has three legs? To me it looks like the run that comes into the middle of the "diode?" has got a break in it near the "diode?"
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    It has two legs.
                                    • keeney123
                                      Lauren
                                      • Sep 2014
                                      • 2536
                                      So the run going to the middle of it goes somewhere else? The run on the left side of the diode.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        There are see, only diode sign.
                                        • chth96
                                          Is it possible bridging tiny broken trace
                                          by chth96
                                          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                          cutting tiny trace.
                                          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                          12-03-2022, 11:32 PM
                                        • re-atari
                                          Gigabyte GA-H110-D3A schematic/boardview needed
                                          by re-atari
                                          Hello all,
                                          Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                                          This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                                          02-24-2025, 06:45 PM
                                        • ugamazing
                                          820-02020 PPBUS_AON missing
                                          by ugamazing
                                          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                          02-05-2025, 04:21 PM
                                        • jpreza
                                          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                          by jpreza
                                          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                          Looking at the card, it appears to be missing the following:
                                          1x 1.0uH inductor - orange square
                                          2x...
                                          11-01-2024, 10:54 PM
                                        • gurj1979
                                          Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                          by gurj1979
                                          Hey guys.
                                          Need help with this one.
                                          Fan not spinning due to missing PWN Fan signal.
                                          Also 5 seconds from powering up it freezes, unless in BIOS.
                                          But as soon as Windows starts to load, it will freeze.
                                          CPU is COLD / Room temp when it freezes.
                                          I've replaced the CPU, same problem.
                                          Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                          Replaced fan - same problem.
                                          Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                          Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                          08-19-2024, 05:22 PM
