Sorry if this is in the wrong section. I'm interested in UV reactive PCBs and making a UV Exposure box. Essentially, you print your boards traces / pads on a transparent / semi-transparent paper, put it over a UV reactive PCB (I think they're called Photoresist PCBs) and then shine UV light on them for a certain amount of time.
I'm interested in hearing from people who have experience with this. I'm working on building a unit but I'm not 100% sure on the type of LED to use. I do want to use LEDs as well. I'm pretty stuck on that idea. I do NOT want to use a bulb.
The question is what's the different outcomes from the different UV LED's wavelengths? On e-Bay, I can purchase 100 UV LEDs with a wavelength of 390 - 395nm for 3.30$. Or I can purchase 100 with a wavelength of 365nm for 49.50$. I've seen how-to's that say to buy ones that have wavelengths around 400nm - 405nm. I've seen howto's that say you need the 365nm's. I'm assuming the more expensive shorter wavelengths mean less exposure time?
Also, to get a nice even exposure, I planned on building a diffusion filter. I've seen some UV LEDs with wide viewing angles (the ones I'm thinking of purchasing have only 20 degrees) but some out there have 120 degree! If I went for LEDs with an ultra-wide viewing angle, would I still need the diffusion filter to disperse the UV light and make it all even like on the PCB? Thanks and again, sorry if this is in the wrong spot!
Spork
Spork
