1.6AL 250V Fuse Alternative
  • xboxhaxorz
    • Jan 2011
    • 196
    My bosch charger stopped working and i found this blown fuse inside
    I was wondering which fuse i could use that radio shack might have
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: 1.6AL 250V Fuse Alternative
    You've got bigger problems than the fuse, like shorted power semis.
    Hint- they don't die, they're "murdered."
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • xboxhaxorz
      • Jan 2011
      • 196
      How did come to that conclusion
      I thought fuses are used to prevent damage to critical components
        If the circuit is drawing too much current due to failed components then before putting in the new fuse and causes more damages you should at least check out the circuit first or you can take a chance and install a new fuse.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5085
          • New Zealand
          No, the most critical (and expensive) components are there to protect fuses.
          Sometimes a fuse will protect other parts that haven't blown, sometimes not.
          Fuses are mostly there to try to stop everything going up in flames when really bad things happen.
          Photos would be a good start
          -David VanHorn
            • 31278
            cant answer the question without knowing the physical size & shape anyway.
            • Gadjet
              Looking for a Fuse T4AL/250V
              by Gadjet
              I've got a Monitor that's not showing any video, and I found this blown Fuse. As you can see from the photos, the board location has T4AL / 250V. Any assistance is greatly appreciated. Thanks!...
              06-15-2025, 09:16 AM
            • corrize
              A funny fuse story – Lumix LX100 II
              by corrize
              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
              10-19-2023, 09:58 AM
            • samtron786
              Thermal fuse AUPO P3-5A-F 250V testing
              by samtron786
              Hello everyone, how can you test a thermal fuse?
              I don't have a sign of life as an ohm or diode
              Thank you​
              11-28-2023, 08:39 AM
            • otoluk
              Bosch AL 1830 CV(AL1830CV) blown fuse
              by otoluk
              Another victim of planned obsolescence.
              BOSCH battery charger from year 2018.
              PCB
              1 607 503 091-C
              PCB4040 Rev0.4 CEM-1 1.6T 10Z
              2016-04-19
              Fuse blew with nice sound effects. Seems need to replace fuse and resistor. No schematic is available.
              Not sure what have caused this will try to replace 400v cap, resistor and fuse....
              06-07-2021, 06:50 AM
            • jesterace
              Samsung UE46ES8000 Blown fuse but no other signs of short
              by jesterace
              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
              09-11-2024, 03:14 PM
