Thermal fuse AUPO P3-5A-F 250V testing
  • samtron786
    • Aug 2016
    • 170
    • germany
    Hello everyone, how can you test a thermal fuse?
    I don't have a sign of life as an ohm or diode
    Thank you​
  • samtron786
    • Aug 2016
    • 170
    • germany
    what do you recommend?
    • petehall347
      • Jan 2015
      • 4434
      a new one
        • 31161
        it's a fuse - if you cant meter it then it's tripped
        • samtron786
          • Aug 2016
          • 170
          • germany
          Thank you
          It's already done​
          • JupTec
            Thermal fuse for DeLonghi coffee machine EN 167.B
            by JupTec
            I would like to know the "thermal value" of the thermal fuse for the coffee machine "DeLonghi EN 167.B". This value is nor longer visible on the fuse itself (maby 167°C or 192°C or somethong similar ?).
            THANK YOU for your help!
            JupTec
            06-18-2024, 06:54 AM
          • Gadjet
            Looking for a Fuse T4AL/250V
            by Gadjet
            I've got a Monitor that's not showing any video, and I found this blown Fuse. As you can see from the photos, the board location has T4AL / 250V. Any assistance is greatly appreciated. Thanks!...
            06-15-2025, 09:16 AM
          • Francesc V.
            Help me to identify this Thermal fuse from my sister's mixer
            by Francesc V.
            Hi everyone:
            This is the second time I have my sister's mixer on the bench. First time I identified a blown tiristor......this time I guess it's the thermal fuse (reads open).
            My understanding is that it should be (NC) normally closed and open at 85C?????
            Could you help me to identify/get a good one? How many amps? I was about to buy a NC 10A, 85 celcius in Aliexpress. (ceramic one)......but I guess is too much.
            Wording in the back......... "limitor 16", "T160".
            Thanks in advance,
            Francesc....
            03-18-2025, 05:48 AM
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
