Looking to replace Capxon with Panasonic...
  • drex79
    • Mar 2015
    • 5
    Could the following list of CapXon KF Vent capacitors;
    Code:
    Brand		Model		Capacitance	Voltage 	Width		Height
    CapXon		C638		1000uf		10V		10mm		16mm
    CapXon		C638		2.2uf		50V		5mm		11mm
    CapXon		C636		22uf		50V		6mm		11mm
    CapXon		C636		470uf		10V		8mm		12mm
    CapXon		C638		470uf		16V		8mm		16mm
    CapXon		C638		470uf		25V		10mm		15mm
    ... be replaced with the following Panasonic FC capacitors (from digikey) ;
    Code:
    Manufacturer Part Number	Manufacturer	Description				Capacitance	Tolerance	Voltage Rating	Ripple Current	Impedance
    EEU-FC1A102			Panasonic	CAP ALUM 1000UF 10V 20% RADIAL		1000uF		±20%		10V		787.5mA	68 mOhm
    EEU-FC1H2R2			Panasonic	CAP ALUM 2.2UF 50V 20% RADIAL		2.2uF		±20%		50V		29.25mA	1.8 Ohm
    EEU-FC1H220			Panasonic	CAP ALUM 22UF 50V 20% RADIAL		22uF		±20%		50V		100.8mA	1.3 Ohm
    EEU-FC1A471			Panasonic	CAP ALUM 470UF 10V 20% RADIAL		470uF		±20%		10V		416.2mA	117 mOhm
    EEU-FC1C471L			Panasonic	CAP ALUM 470UF 16V 20% RADIAL		470uF		±20%		16V		547.5mA	85 mOhm
    EEU-FC1E471L			Panasonic	CAP ALUM 470UF 25V 20% RADIAL		470uF		±20%		25V		746.2mA	65 mOhm
    Any other required information, let me know.
    Thanks!
  • jetadm123
    • 2169
    Re: Looking to replace Capxon with Panasonic...
    Those will work fine. The Panasonic FR and FM series are also good choices and may actually be cheaper.
    • drex79
      • Mar 2015
      • 5
      Excellent, thanks!
        Panasonic caps:
        https://www.badcaps.net/forum/showpo...2&postcount=65
        • BigPete
          Panasonic Heatpump Dryer Repair
          by BigPete
          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
          Unfortunately the whole machine has to come apart to fix it.
          I have...
          11-01-2025, 06:40 PM
        • Agent24
          Dick Smith Q-1760 linear power supply filter capacitor question
          by Agent24
          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
          It has at least one problem.
          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
          I have already ordered a replacement potentiometer, so that's not an issue.
          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
          All are CapXon...
          10-21-2025, 05:39 PM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
