Capacitors in CFL's
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Capacitors in CFL's
    Originally posted by stj
    it's a gray fuseable resistor, not a regular smoke&flame type.
    Yeah but they still take time to go O/C, and they get very hot ... they can set things on fire, even though they themselves don't burn xD
    i'm thinking your not seeing electrolytics bursting because your only 115v,
    try Europe where we have to use 400v electrolytics in these things.
    usually 1.8 or 2.2uf
    Why do you say that?
    I've seen bad ones caused by using the CFL on a dimmer :P
    Including failed (bulged) nichicon and NCC caps, lol.
    Muh-soggy-knee
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      Of all the CFLs that have failed on me and I was able to crack the case, the failure mode tends to be the filament going OC and will no longer start with the built in starter.
      The outliers:
      1 failed due to corrosion on the tube wires
      2 failed due to overheating coil, probably due to semiconductor failure due to heat.
      Not one bad cap yet, oddly enough. I didn't put any CFLs on a dimmer or at least never tried dimming a non-dimmable CFL on a dimmer. Then again that "big" visible capacitor in most CFLs is equivalent to that big capacitor in computer PSUs... and those don't usually fail either...
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Incandescent lightbulbs aren't illegal.
        The worst that will happen is that they are sold as a specialty bulb, which alone can be good news!
        They're more likely to last longer instead of being the dreaded "1000" rating. At least compared to the large quantities of the past.
        Even the mercury vapor lightbulbs of the same type that the street lights used were still being made recently!
        (I thought I wouldn't see any with a manufacturing year later than 2008!)
        (Looks like the only thing that changed is that all new ballasts are required to be metal halide-compatible or HPS-compatible)
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
          http://www.homedepot.com/p/EcoSmart-...7?N=5yc1vZbmg5
          This is what I can get in California to replace regular incandescent 100W lamp.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            I bought a halogen A19 bulb for kicks, curious of lighting. It seemed very similar to regular incandescent but slightly higher color temperature. I am a bit disappointed by the lifetime which is no better than a regular incandescent, but perhaps that's how it got the 25% power savings...
            Plus at $1.25-$1.50/bulb they are no longer cost effective. Buy if you like or need the heat. I'm not sure what the kids will do to fix their E-Z-Bake ovens...
            • Capybara
              • Mar 2015
              • 7
              I am also one who feels that CFL life is over-rated. I tried to be an early adopter and bought some for a server room. On all the time. But they died within 12 months.
              I also hate the inconsistent colour spectrum they put out. As a camera hobbyist, I can't get the white balance of pictures to look right. And as human, food doesn't look as appetizing and people don't look as nice under CFL lighting.
              And then there's the toxic waste situation created when you break one. My aging parents broke one and I had to leap into action because they were either going to just sweep up the fragments or (worse) use a vacuum cleaner.
              I swear there must be a CFL lobby out there influencing the government. No reasonable person with any technical background would think these bulbs are a good idea.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Originally posted by ben7
                We have no choice, because the incandescent bulbs we'd need are illegal now (yes, ILLEGAL).
                Bullshit!! I recommend that you get Osram Sylvania 40W incandescents.
                Arc A770 16 GB
                  • 31278
                  for people in Europe, pearl/frosted are banned, but clear are not.
                  i dont know if the same rule is gobal.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    WTF. That's weird!
                    Also, two 40W bulbs aren't bright enough for the bathroom...
                    EDIT: Crap, double posted somehow... :S
                    Muh-soggy-knee
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      WTF. That's weird!
                      Also, two 40W bulbs aren't bright enough for the bathroom... that's why I said "...because the incandescent bulbs we'd need... "
                      Muh-soggy-knee
                        • 31278
                        clear bulbs bypassed the ban because the appearance is needed in some types of glass fitting that you cant get from a cfl.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8706
                          I think in the US, the clear bulbs are also banned from commercial sale now, but then the "specialty" bulbs (usually long life, which are even less efficient than regular) are still OK to sell.
                          Recently I went through my bathrooms' vanity bulbs, and they all use the G25 shaped bulbs. As I only have 8 clear G25 incandescent bulbs left, I put them in the two 4-lamp vanity fixtures. The 6-bulb vanity fixture I have a hodgepodge of bulbs because that's what I have... two 5000K CFLs, two 2700K bulbs of one brand, one 2700K of another brand, and one last frosted incandescent bulb. Looks kind of weird when they're on but when they're off, it's not too noticeable...
                          Not sure what I'll do when the next bulb burns out, especially if it's one of the clear ones... Fortunately the G25 bulbs count as specialty and thus are still available for purchase.
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            #33
                            this means no lights of america (lights of china).
                            they are pure shit!
                            Originally posted by japlytic
                            Reports from defrauded consumers (including myself) clearly show that using substandard energy saving lamps can cost you money.
                            Why waste your money on energy saving lamps which don't last as claimed?
                            To avoid this kind of a problem, insist on energy saving lamps with a warranty, ideally not requiring proof of purchase.
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              #34
                              btw i had a cfl start buzzing and strobing a while back.i opened it up and the cap was popped.a replacement fixed it.am i the only one who would recap a cfl?
                              btw its a ge 23w and the cap was an aishi?
                              since its was a bridge rather than a doubler i used a 200v cap i have a bunch of.
                              these things get hot enough inside to darken the board!
                                • 31278
                                i have recapped lots.
                                all the failed ones i have had either had a bad cap or open heater.
                                the open heater ones went in the bin,
                                the bad cap ones, i use panasonic NHG series.
                                  I stocked up on a ton of 150W bulbs for my series light bulb tester
                                  (I use LED bulbs in 95% of the house. A couple of infrequently used lights are CFLs, and the bathroom uses halogens with an electronic transformer.)
                                  So far, zero failures (but I found CFLs to be OK, just had a few that would buzz or flicker)
                                    • 31278
                                    what cfl's are you using?
                                    my standard base ones are phillips,
                                    the candles are "morrisons" own re-brand.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8706
                                      I think these are the CFL brands I've used and their rating from my opinion of each brand based on how long they've lasted:
                                      Commercial Electric - Works as expected, most hours logged
                                      GE - not enough data yet
                                      Greenlite - So far so good (alas I bought these *cheaaaap*)
                                      Feit - so far so good, but not as much info as Greenlite and Commercial Electric
                                      Lights of America - Crappy
                                      Phillips - Not enough data yet, but so far so good.
                                      Sunbeam - Acceptable but not great
                                      • dragon3x
                                        by dragon3x
                                        power on.
                                        Here are some examples :
                                        switching supply area).
                                        than 6.3 V.)
                                        03-21-2025, 02:46 PM
                                      • slybunda
                                        AA and AAA battery charger capacitors?
                                        by slybunda
                                        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                        it has inside:
                                        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                        2 x 470uf 16v LZ105c branded as G.Luxon
                                        not heard of these brands are they any good?
                                        iv attached photos of the charger and the board inside for an idea on the type of...
                                        12-24-2023, 04:41 AM
                                        After all of...
                                        07-13-2024, 08:14 PM
                                      • Cama
                                        Solar Inverter - SMH-II - 2 missing capacitors
                                        by Cama
                                        I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                        My model is : EASUN SMH-II 7 KW
                                        Mother Board : P/N 18947-002401250250
                                        Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                        Thank you...
                                        09-12-2025, 02:50 AM
                                      • Ady2017
                                        Are there any datasheets available for Elna RJG capacitors?
                                        by Ady2017
                                        I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                        05-25-2025, 02:19 PM
