fuse questions
    fuse questions
    i have a blown fuse here from a phillips tv a client brought in to fix. its the cylindrical, ceramic type...the smaller one u see in atx power supplies a lot.
    it has a little logo on it that looks like LF but the F is inside the L
    and then it says right after the logo:
    T8AH250VP
    i know that this is an 8 amp, 250 volt fuse based on the markings.
    but what does the lf mean? is it just a logo?
    what does the H mean
    and what does the P mean?
    and how do i know if this is a slow blow or fast blow? are all ceramics slow blow?
    are there different grades of "slow" and "fast" ?
    just some general fuse questions.
    cant figure out how to word this stuff right to get a good answer on the google, figured someone in here knows better
    please, and thank you!
    Don't fear the repair...
    Re: fuse questions
    LF= Little fuse, the company name.
    T = Time delayed/SLO-BLO
    8 Amps
    250V.
    5x20mm ?? fuse, CERAMIC.
    http://ca.mouser.com/ProductDetail/L...bt0tLIYOtRI%3d
      Re: fuse questions
      ok thanks... but what is the H and the P for? i found another fuse to replace it with but it doesnt have the P at the end. just wondering what that meant... also the H
        Re: fuse questions
        Little spec sheet does not give the details on the numbering code as printed on the fuse.
        P is more likely for LEAD free.
        H is for high interrupt breaking capacity, hence CERAMIC body.
        Did you verify that it is 5x20mm dimension?
          Re: fuse questions
          yea thats what it is. so probably the replacement fuse is fine... but something else went wrong. im going to start a thread for this phillips tv now since replacing the fuse didnt solve it..and the setup in this tv is really strange
