I moved to a new apartment for next semester in college. It’s actually a duplex in a house built in the 50’s or 60’s. What’s bugging me, though, is the apartment has mostly 2-prong outlets (with the exception for two in the kitchen, one in the bathroom, and one for the window AC unit in the living room – these are GFCI, though I don’t know if they have any ground). As you all somewhat know me, I prefer to use my desktop computer if I can. Of course, this is now getting in the way because both my desktop and its accompanying CRT monitor have 3-prong cords (as does my printer too, actually). I also have other 3-prong equipment.
Before I begin, let me state that, YES, I know it is probably illegal for me to do any electrical work - especially since I am only renting the place. But before my lease ends, I intend to return everything back the same way it was before. Also, this is not the first time I have done electrical work. I wired all of the high power outlets in my friends shop. Most of his machines pull several kW @ 208V. I’m not really bragging, as I know my skills are nowhere near professional. But I do everything carefully and try to use common sense when doing any electrical work. And ouf course, tight connections everywhere.
Back on topic…
So I was thinking of just changing the outlets with 3-pronged ones. However, there is no grounding wire in the outlets. Correct me if I am wrong, but after a bit of reading online, it was suggested that the only “up to code” way that I can install 3-prong outlets without ground is if they are GFCI and if there is a clear indication on each outlet’s cover, “No Equipment Ground”.
I already have two GFCI outlets ready at my disposal. The only thing I am not sure of is there is enough space in the existing outlet boxes to fit the new GFCI outlets. In case there isn’t (and I rather not tare up the existing boxes as I am renting the place), I was thinking to install just regular 3-prong outlets. This is where my main question is:
If I install 3-prong outlets where no grounding is available, should I leave the ground on each 3-prong outlet unconnected to anything, or should I tie it to Neutral?
From what I gather, neither of these solutions are up to code. But, again, that’s not my concern here, as this “fix” is for myself only and I will be returning everything back to its original state before my lease expires. I’m only interested to know which of these solutions is safer. I know many old buildings in Eastern Europe tie Ground to Neutral in each outlet if only 2-wire is available. Of course, I’ve also seen plenty of cases where the ground on the outlet was left unconnected.
As far as where I would like to change these outlets – just one or two in the living room and one or two in the bedroom. The house has hardwood floors and is raised about a foot off of the ground (there is no concrete under the floor). Last I checked, neither of these outlets I wanted to change are near any grounded conductor (such as a sink faucet, etc.). So if the GFCI 3-prong outlets don’t fit, I am thinking I might just get away with 3-prong non-GFCI and leaving ground unconnected.
I don’t know, what do you all think?
I certainly want to avoid those stupid, cheap 2-prong to 3-prong adapters. IMO, that’s probably the most unsafe option.
Any other suggestions?
Back on topic…
