another ESR meter thread
  • jasonbay13
    • Jul 2014
    • 185
    • usa
    i'm wanting to buy the blue esr meter, but at $100 its abit much. though can anything of the same quality be had for under 50?
    and does fluke or someone make a dmm with esr capabilities? because my dmm is really quite terrible. 20vdc range quit working and its not a true rms. so i'd rather spend $250 on a dmm with esr than $250 on admm eventually and $100 on an esr meter
    and about them 15$ cheap ebay ones, are they effective and work in-circuit?
  • Spitz
    • Oct 2010
    • 95
    Re: another ESR meter thread
    I bought one of the ebay cheap ones and it works great for me. I don't use it in-circuit. I recycle caps from motherboards and it gave me a quick check if they are any good. I don't need exact measurements, just whether it is good or bad.
      This one works well so far:
      https://www.badcaps.net/forum/showth...888#post443888
      • chth96
        by chth96
        03-09-2024, 10:03 PM
        12-31-2023, 06:04 AM
      • jorpec
        by jorpec
        Hi
        Thnaks
        01-23-2023, 10:37 AM
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
      • Stephan Mathers
        EDMI ATLAS MK10 Electronic Meter Discussion
        by Stephan Mathers
        Greetings, new guy here but always interested in the crazy universe of modding
        We just finished construction of around 25 vacation houses, all inside the same private area.
        Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
        The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
        Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
        05-20-2025, 09:09 AM
