Cheap ESR meters on fleaBay, what do you think?
Re: Cheap ESR meters on fleaBay, what do you think?
ill tell Y, cuz i am not gonna travel with it and i thinks its the best way to just remove the battery and this way is the best(-:
this is just my opinion
well if you get one in a case, you can do it tidy by fitting a 2.1mm socket on the case.
without case:
http://www.ebay.co.uk/itm/251518131978
with case:
http://www.ebay.co.uk/itm/261466455456
big price jump unfortunatly.
Ha! I am pretty dumb, but I have picked that up. It would just be nice to know which ones are bad, and which ones are still fine when I'm recapping, instead of replacing everything.Comment
I didn't mean to imply what you wrote, but many ESR meters are being advertised as being able to provide in circuit readings (that is, you don't have to desolder the capacitor).
There are very few cases where you can measure a capacitor in circuit and get a reliable reading, but for the majority of the cases, you need to desolder them. If that is the case, quality capacitors are cheap enough that it makes the investment in a good ESR meter questionable for a hobbyist.
For the professional technician, an ESR meter is probably a requirement.--- begin sig file ---
--- end sig file ---Comment
I will say to all that is definably a requirement when you are following the correct pattern about conducting capacitors testing.
Capacitors datasheets are the ones which setting the requirements about the technical specifications that an LCR meter should have for Low-ESR measurements & capacitor evaluation according to their manufacturer.
Therefore the final selection of a tool is not according it price or personal likes.Comment
Ok, I ordered this one cause it shipped quickly. Build quality is ok. On button is a little fiddly, doesn't always work. Also, never sure what testing slots to use. I often get "no, damaged or unknow" reading and move the pins to different slots a few times before I get a reading. I also get different, sometimes very much so, readings if I move pins to different slots.
EDIT- The above issues seem to have improved after a few dozen on/off cycles.
Not sure what I'm looking at when I test a cap
Took a brand new Nichicon 1000uf 16v cap and get a Vloss reading of 0.8%
a C reading of 933.1uf and an ESR reading of 0.0 ohms
I then take a bulged capxon 220uf 25v cap and get a Vloss of 6.5% (or 0.0 sometimes), a C=40.97uf (or up into the mid 50s) and an ESR of 10ish.
Sometimes I don't even get an ESR rating on some bulged caps.
For good caps am I looking for low Vloss and low ESR? Is a bad cap indicated by either of the two or a C value drastically different from what's labeled?
What's acceptable Vloss and what's acceptable ESR?
Thanks for helping out this dummy,
Cheers,
AlexLast edited by withalligators; 08-06-2014, 06:36 PM.Comment
probably, the slots are marked 1, 2, and 3. Should caps be one pin in slot 1 and the other in slot 2?Comment
no idea
you may get usefull info here
http://www.mikrocontroller.net/artic...ansistortesterComment
I dont understand from this site, can u update the softwar version or not?Comment
by H34TORecently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...06-17-2025, 07:17 AM
by eccerr0r"Caseless Cheap Chinese electronic tools" I mean things you get from banggood, ali, fleabay, Am-Zon, etc. like AVR-Transistortester, miscellaneous signal generators, frequency counters, (variable) power supplies, oscilloscopes, low resistance meters, etc., etc. that comes optionally with a case, or comes only with a cheap piece of plastic that barely provides protection to the PCB.
Just wondering what of these (generally flimsy) tools you actually find use (almost) everyday and find indispensable for the price, compared to buying a Fluke or whatnot, if there is an expensive... -
by evilkittyMy Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...-
by aaronkatriniHi all,
- Autorange
- DC volts up to 30V
- Accurate Resistance
- Diode test (Beep mode)
- Frequency up to 200MHz
- Capacitanze up to 5000uF
- as cheap as possible
Other functions are not needed but those which are needed... -
by Dan81Just as the title states. Two cheap SiS machines, surprisingly stable.
What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
CPU - P3 1100MHz Coppermine...-
- Loading...
I don't understand anything on that site.
