Water on TV
  • glen4cindy
    • Dec 2012
    • 52
    Water on TV
    This isn't a "Bad Cap" question, but, one that I could use some input on.
    We had a water pipe rupture in our basement on Sunday 6/15/14. We were filling our pool, so the sound of water running didn't concern us. Little did we know, our anti-freeze spigot had frozen during the winter, and when we opened the line to fill the pool, a section of the line inside the basement ruptured.
    For about 3 hours or more, water cascaded into the ceiling of the basement, soaking our tiles, falling down to whatever be below, which was the TV, VCR, a DVD player, DVD Recorder, DirecTv Receiver, LaserDisc Player, and Surround Sound unit.
    All of these got wet to some degree. The TV was about 1/2 in the stream of splashing water and being the highest probably got the most splashing, though the main rupture was to the right of it.
    Knowing that there is always power running through at least some of the circuitry of the various units, what should be my next step? They call this a "Level 1" since it was clean fresh sanitary water, and not storm water, sewage, or runoff.
    Once everything is good and dry, is it safe to plug in and power on for a test, or should I do something else first?
    Looking for helpful advice here. Also, if it works today, what are the chances for longevity? In all likelihood, will it have the same lifespan as it would have had having never taken a shower? (I know, no one can predict the future, but, just wondering.)
    Thanks in advance.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Water on TV
    pictures are a good starting place.
    Follow the white rabbit.
    • selldoor
      Slow Learner
      • 7870
      Re: Water on TV
      Home insurance not cover accidental damage?
      I wouldnt switch it on without taking the back off an having a look to see if it really is dry.
      Chances are its not unless of course you took the back off to dry it - in a small warm room with heating and a dehumidifier would have been best.
      I dont know about plasma but if its an LCD and water has got into it it wont have dried
      and probably never will - it just moves around condensing and evaporating leaving patches. Even clean water is likely to cause corrosion to any circuit boards to some extent so I think you can expect shorter life.
      This is just my opinion - I have no personal experiance of such an event.
      If you have some electronic skills you could try and wire it up with a 75watt old type
      filament bulb in series with the mains + input - if there is a short the bulb will light bright and stay bright and to some extent would prevent further damage.
      • glen4cindy
        • Dec 2012
        • 52
        Re: Water on TV
        Yes, homeowners will pay, but, some items are old enough that depreciation will likely evaporate much of the value.
        I planned on pulling the back off and seeing what I could find.....
        Thanks.
          Re: Water on TV
          Anything with optics in it - laserdisc/DVD etc. be very careful as water can cause a lot of problems for the optics.
          LCD TVs will get water in the diffuser films - there will be no avoiding this and it will be a pain in the arse to get out. Plasma TVs will generally be OK but due to the high voltages a complete drying is definitely a requirement. If powered up during the water damage, then it is probably ruined regardless of the technology.
          The surround amplifier might be the only thing that survives if it's predominantly analog.
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            Re: Water on TV
            Surprisingly, there are few components that are damaged by brief water exposure. Like he mentioned before, the corrosion and oxidation is the worse part if not dried out fast. The most affected parts, to me, are transformers. It's hard to get water out of those unless you have something that can create a true vacuum in which water will boil away - even at room temp.
            We used wash flux off of circuit boards of all types, put them into a drying oven, and sometimes put them into a vacuum chamber if they had transformers on them.
            I got a TV in my basement now that has had some moisture damage but now works.
              20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
              by sam_sam_sam
              I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
              At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
              Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
              04-09-2023, 08:04 PM
            • Ugur87
              MacBook Air M4 A3240 Brand New Water Damage no Image
              by Ugur87
              I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
              08-28-2025, 01:09 PM
            • edugimeno
              Stagg sms12p audio amp has water damage
              by edugimeno
              Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
              I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
              There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
              There is only one signal wire connecting the first boards...
              05-24-2025, 06:00 AM
            • RetroComputingGrotto
              Water Damaged Toshiba 48L1435DB
              by RetroComputingGrotto
              I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
              The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
              10-07-2024, 08:23 AM
            • x_orange90_x
              Samsung UN65AU8000FF fried by water
              by x_orange90_x
              I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
              10-16-2025, 08:40 PM
