LED light issue
  • ntec
    • Jun 2020
    • 55
    LED light issue
    Hi, I'm trying to fix my buddies rechargeable led work light made by olight and the model is odiance. For some reason now after a couple years of no issue, when powered off now, the led is faintly lit on 3 of the orange rows but as you can see from the first pic that's not where the leds are. The part that is faintly lit is beside the leds? Anyone know how that is possible? Is there small voltage still coming in somehow? The third pic is with the cover off.
    • 31199
    interesting, so it has 2 colour modes.
    white and something else - red?
    the resistors on the led panel look like they arent properly soldered.
    that doesnt explain it not turning off though!
    • ntec
      • Jun 2020
      • 55
      Sorry I’m mistaken, there are led’s where the orange lines are. There’s a knob that lets you adjust the light to a white/orange color as it turns on both the white and dim orange leds. But yeah I don’t know why when powered off the orange ones are still lit on 3 of the rows.
        • 31199
        maybe it has 2 problems.
        not turning off fully could be a leaky fet or a bad resistor on the fet,
        lets see the boards
        the other thing is the leds not all lighting together - it could be uneven leds but i would resolder those smd resistors
        • ntec
          • Jun 2020
          • 55
          lets see the boards
          here is a picture of the board.
          • ntec
            • Jun 2020
            • 55
            lets see the boards
            I did reflow the resister solder joints but issue is still there.
              • 31199
              i see it has 2 boost convertors to drive the leds,
              they must be powered by fets but that fucking black soldermask makes it impossible to see the tracks
              • ntec
                • Jun 2020
                • 55
                I know can't see the tracks with the black. It's weird cause how come only 3 of the rows of leds are dimly lit when off and not the rest.
                • truclacicr
                  • Apr 2019
                  • 343
                  • australia
                  Datasheets ...
                  https://energo-shop.com/content/file...t-24915618.pdf (IP5389)
                  https://www.monolithicpower.com/en/d...cument_id/1189 (MP3429)
                  https://socmcu.com/en/files_down.php?id=44 (SC92F7423X)
                  https://op1.0ps.us/pdf/opplanet-olig...manual-pdf.pdf (user manual)
                  I can't see how the intensity of the LEDs is controlled. Perhaps I've identified the wrong converters?
                  • ntec
                    • Jun 2020
                    • 55
                    Originally posted by truclacicr
                    Datasheets ...
                    Those chip numbers are the correct numbers shown on my chips. I also have 6 chips on the board labeled pan3030p as shown in pic below.
                    • truclacicr
                      • Apr 2019
                      • 343
                      • australia
                      PAN3030P would be the MOSFETs in the battery charger circuit.
                      http://www.jg-semi.cn/uploads/admin/...6/PAN3030P.pdf
                      Are there any components on the underside of the PCB or anywhere else? I would think that there must be a MOSFET switch, or physical switch, between the battery's positive terminal and the Vin pins of each of the MP3429 boost converters, otherwise the battery would drain through the LED strings.
                      Perhaps the two MOSFETs at the USB ports are configured as ideal diodes to prevent the battery from back-feeding into the ports? In fact they appear in the simplified application schematic on page 2 of the datasheet.
                      • ntec
                        • Jun 2020
                        • 55
                        Here are pics of the back and chips.
                        • truclacicr
                          • Apr 2019
                          • 343
                          • australia
                          Si24R1 is a wireless transceiver.
                          http://www.szczkjgs.com/UploadFiles/...652/Si24R1.pdf (Si24R1 datasheet)
                          https://www.easy-core.com/file-download-530-left.html (module)
                          Those two SOT23-5 ICs look promising, but I haven't been able to identify them. Is the marking "|128" or "|12B"?
                          Edit:
                          Nope, "12B" is an op amp.
                          https://www.ti.com/lit/ds/symlink/tlv333.pdf (TLV333IDCKR datasheet)
                          https://pt.aliexpress.com/item/1005007900820691.html (photo)
                          I'm stumped.
                            • 31199
                            maybe the 2 sot23's on the front are fets,
                            why does it have a stripline antenna?
                            is it bluetooth controlled or something?
                            • ntec
                              • Jun 2020
                              • 55
                              There's no bluetooth but the lights come with a small remote to control lights.
                              • truclacicr
                                • Apr 2019
                                • 343
                                • australia
                                I would start by measuring the voltage between the battery terminals. Then measure the voltage between the LEDW+ and LEDW- terminals, and between the LEDC+ and LEDC- terminals. Do this when the light is on and off.
                                • R_J
                                  • 9588
                                  Are there any components on the back side of the led panel?
                                  • ntec
                                    • Jun 2020
                                    • 55
                                    Lights off ledc- and ledc+ 7.89v
                                    Lights off ledw- and ledw+ 7.78v
                                    Lights on ledc- and ledc+ 10.3v at lowest brightness and max brightness 11.37v
                                    Lights on ledw- and ledw+ 7.83v at lowest brightness and max brightness 7.6v
                                    • truclacicr
                                      • Apr 2019
                                      • 343
                                      • australia
                                      Doesn't this mean that the white and yellow LED strings are always on and that the 7.2V (?) battery is being continually drained?
                                      Doesn't this also mean that the light has been configured for yellow light mode? Do you get different readings in white light mode?
                                      If 11V is the supply voltage for each LED string at max brightness, how many LEDs are in each string?
                                        • 31199
                                        a buck/boost converter will pass current even if it doesnt run, so you need to actually cut the feed to one and not just use the enable pin.
                                        i think thats what is happening - one of the boost convertors is passing the battery voltage to the leds when the controller is disabled.
