curious about capacitor checkers.
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    Ive been looking on ebay and found this one http://www.ebay.com/itm/New-M6013-Au...-/191042485217 I like how its auto range but it looks sorta cheap, which would be the best quality, it doesn't have to be super accurate but i would like a ballpark figuere.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
  • Agent24
    I see dead caps
    • Oct 2007
    • 5094
    • New Zealand
    Re: curious about capacitor checkers.
    Says on the website...
    Accuracy:
    0.01pF to 47.000nF 1%+2Digit
    47.00nF to 47.000uF 1%+1Digit
    47.00uF to 470.00mF 1 to 3%+1Digit (Larger capacitance will have larger error)
    Not very useful I suppose... but I'd say it's fine for most use, especially with big electrolytics.
    If you wanted to do some high accuracy check of pF size caps for RF work or something then I guess it wouldn't be good enough
    -David VanHorn
    • c_hegge
      • Sep 2009
      • 5219
      No ESR check function either it seems. I'd look elsewhere.
        1% is pretty good, lytic cap has +/- 20 % Tolerance, most small polyester has 5% (J), or 10 % (K) Tolerance.
        • AkumAone
          • Feb 2013
          • 23
          • Bosnia and Herzegovina
          $134 is too much; here it is for $27 including shipping:
          http://www.ebay.com/itm/M6013-V2-Aut...item4d0d329c0e
          But, it will only test capacitance, not ESR or anything else.
          If ~$120 is within your price range, take a look at DER EE DE-5000.
          • mariushm
            • May 2011
            • 3799
            If you want an all around good multimeter, you can't go wrong with this one:
            http://www.ebay.com/itm/UNI-T-UT-61E...item2ec6ac75bd
            The ebay seller is well known on eevblog (electronics forum) and you can trust that ebay store and guaranteed fast shipping and not dead on arrival (he checks every one before sending)
            It measures up to 220mF (220.000 uF), it's 22000 count meter so you get a fine resolution when measuring voltages, it has data logging, fast continuity etc etc and it's only 53$.
            It does not measure ESR ... for that you'll need an ESR meter.
            To fix stuff, an ESR meter is more important than a simple capacitance meter because the esr meter tests the cap at high frequency... there are lots of cases when capacitors still measure a good capacitance (value +/- a few percent) with a multimeter (because multimeters measure at 100-120 Hz) but when running at high frequency in circuit, the capacitance drops and capacitor fails.
            • SteveNielsen
              Retired Tech
              • 2327
              I know these are kind of frowned upon by some but I bought one of these Chinese transistor/ESR/inductance DIY knock-offs and it works surprisingly well and accurate enough for what I do. I mainly bought it for testing ESR and capacitance after shopping around for quite a while and this one seemed to be the best for the price for testing ESR. I've also found the diode and transistor testing to be helpful.
              http://www.amazon.com/dp/B00D6BNDWM/..._26725410_item
              I have another multimeter that measures capacitance but not ESR and is rated more accurate than the Chinese unit and so far all the caps measured agree between the two.
              • vinceroger69
                • Mar 2012
                • 6714
                i have one of these meters too and find it quite accurate too easy to use too well worth the money as i do this as a hobby its not worth me spending a lot on test equiptment just yet.
                • SteveNielsen
                  Retired Tech
                  • 2327
                  Exactly. The other meter I mentioned is a Mastech MS8264 when I was looking for a good temperature meter with probe and is another case of shopping for a particular function for a hobbyist price. I'm very pleased with it as well. I mainly use it on the temp function when calibrating my soldering station when changing or just checking tips, another cheap thing that actually works very well.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    yes just looked on ebay uk about £22.50 inc postage i dont have a temperature meter and probe so maybe worth getting one i guess its a handy meter to have.
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      I got mine for $35.50 usd under a promotional free shipping from Amazon. That's close to the same price.
                      • MORETTIGIAN
                        Capacitor detached from PCB – RTX 2070 Super Founders Edition
                        by MORETTIGIAN
                        Title:
                        Description:
                        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                        I did not notice it detaching, so I am unsure of its original location on the PCB.
                        Procedure performed:
                        - Removed backplate
                        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                        - Reapplied thermal compound
                        - Reassembled card
                        Observed behavior after reassembly:
                        - GPU powers on and operates normally under...
                        09-18-2025, 12:14 PM
                      • Prolog
                        RTX 3080 FE Identifying capacitor
                        by Prolog
                        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                        I hope these photos make it clear which component I am referring to:
                        (yes, the soldering is a bit botched from removing the blown one, I know)
                        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                        12-01-2024, 08:27 PM
                      • Agent24
                        Dick Smith Q-1760 linear power supply filter capacitor question
                        by Agent24
                        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                        It has at least one problem.
                        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                        I have already ordered a replacement potentiometer, so that's not an issue.
                        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                        All are CapXon...
                        10-21-2025, 05:39 PM
                      • chth96
                        If I replace with inferior capacitor, Is it No harm to other IC components at all?
                        by chth96
                        I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                        Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                        It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                        So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                        I know that these capacitor will not last as long as nichicon capacitor...
                        12-22-2023, 04:34 AM
                      • chth96
                        How can I test non-polarized capacitor?
                        by chth96
                        I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                        I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                        And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                        I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                        06-02-2024, 07:31 PM
