Wiper motor 12Vcc - how to reduce speed
  • Bushcat
    Pioneer PL-X9 motor speed control wobble
    by Bushcat
    I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
    Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
    BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
    05-24-2023, 03:36 AM
  • Dannyx
    AC Fan motor speed control ideas
    by Dannyx
    Good day folks. What I'm trying to achieve may seem pretty simple and although I found lots of discussions on the topic, it's hard for me to settle on a definitive answer, so I thought I'd ask for more opinions.
    I have a small inline duct fan which looks like this, which I want to slow down, the reason being overall noise. I have no idea what type of motor this is, because I can't exactly take it apart to inspect it without ruining it, but perhaps we can work it out by examining its behavior.
    Two things I've tried: a variac and a cheap light dimmer (triac+diac inside...
    06-17-2021, 10:44 AM
  • CptChronic
    Carpet overlocker motor gradually increases speed by itself
    by CptChronic
    I have an overlocker for stitching carpets and once I turn it on and leave it on the slowest setting, the speed will slowly increase by itself. When this happens, the voltage between the speed increase potentiometer, increases by 0.001V. I've stripped the thing down and the circuit board looks fine. Could this be a faulty potentiometer? Or something else? There is some soot inside the housing near the transformer and drive belts
    Pictures here: https://imgur.com/a/sUjRJrU
    12-19-2022, 06:34 AM
  • juergenb
    Nescafe Aeroccino, still fails with new Motor (red flashes only once)
    by juergenb
    i am asking for some Help.
    I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
    The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
    So i got a few of these from Banggood.
    I swapped the motor and now i have a new fault condition.
    In a working Frother you would press the start button, it will light red and work for a few minutes.
    If you press longer it will light blue and just mixup the milk.
    With the new Motor it just starts...
    03-23-2021, 11:24 AM
  • sbt123
    charnwood w821 mini wood lathe motor problem
    by sbt123
    hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
    10-27-2024, 03:43 AM
