Different between analog VOM with DVM on testing transistor or mosfet
  • senz_90
    • Aug 2013
    • 328
    • Indonesia
    I am still hesitant about this. I have read that some website said that DVM couldn't test transistor accurate because the voltage from DVM probes didn't enough, Jestine yong also said this. I have try to measure my DVM on diode test mode has 3VDC output compare with my analog VOM has 3VDC output too except x10k range(12V DC). on resistance mode (DVM) it has about 0.3VDC as measure. I know most of you use Fluke DVM and analog VOM didn't famous anymore. Is this true ? anyone have experience with this before where is the transistor tested good with DVM but tested bad with analog one?
    I am appreciated comment and glad to hear your sharing.
    "There is no shortcut to be successful. No pain, no gain."
    Best Regards
    Rudi
    Thank You
    Re: Different between analog VOM with DVM on testing transistor or mosfet
    3V will turn on most transistors (with the exception of power MOSFETs which are not logic-level/5V drive capable) and almost all diodes.
    Most modern DMM resistance ranges produce 0.2V to 0.3V. The reason for this is it won't turn on most diodes. Also, the voltage is often reverse polarity, (-0.2V to -0.3V) to allow you to test the "normal" way across a diode without turning it on, though it can create confusion.
    Because this voltage range is too low to test a diode, there is a dedicated diode test mode on most meters, which on mine can produce about 4V open circuit. This is quite useful because it is high enough to turn on a white LED (Vf=3~3.5V at low currents.) It is actually usually a constant current source (typical circuit is PNP transistor with two resistors) limited to a couple of mA which is ideal for testing diodes.
    On most cheap multimeters, there is no extra diode test range, instead it is just integrated into the 2000 or 20k ohm range. This is usually indicated by the diode symbol next to this range.... sometimes it is constant current but not always, so don't depend on it.
    • senz_90
      • Aug 2013
      • 328
      • Indonesia
      my cheap DVM like this. So the conclusion is 3V enough to test transistor and diode except power mosfet? I don't know that diode test mode have a constant current source, got a new knowledge again thanks . The suck thing from this DVM is 10A range probe didn't have any fuse just a thick wire on it..LOL
      on small Ampere probe it just have NTC if i am not wrong reading from manual.
      I have try to open it and it looks like small MOV on PC power supply with some number on it, and the thick SUCK wire.
      Best Regards
      Rudi
      Thank You
        The thick wire is the current shunt, it drops about 10mV per amp (0.01 ohm shunt.) Even expensive meters have this. But they are usually fused.
        Be very careful with unfused range. If you accidentally put that across the mains, an explosion is possible. That thick shunt can very quickly become an explosion of molten metal, if the building is not correctly protected against such faults. You would not want to be holding onto the meter if this happened.
        It's crazy really that they don't bother to fuse the 10A range. I have seen UNI-T recently using BS1363 fuses. This is a good idea IMHO, because the 13 amp ones are rated for high interrupt current and are suitable for mains use up to around 250V. Plus they're cheap, like less than £0.10 (~$0.15) each in quantity, so they don't add much to the meter's cost.
        I wouldn't use a BS1363 on a commercial circuit, but I wouldn't feel in danger if I were testing household mains. Luckily my meter uses HRC fuses.. but they cost about £5 each... I have been very careful not to blow any!
        • senz_90
          • Aug 2013
          • 328
          • Indonesia
          I don't wanna ever try to measure everything high current like 10A with this meter, it would kill myself and burn my house if something bad happened.
          I'm not frequently makes an experiment with high voltage, just troubleshoot SMPS, TV, or Monitor. It has caps range that suitable for measure CRT monitor flyback internal caps so this meter is enough for me, maybe I would get an autoranging decent meter (don't consider Fluke because just for hobby) after have some budget maybe on $30-60 range DVM.
          Best Regards
          Rudi
          Thank You
          • Agent24
            I see dead caps
            • Oct 2007
            • 5091
            • New Zealand
            Take a look https://www.youtube.com/watch?v=qM7_h8my8eA he also has a video on MOSFET testing
            Really, a transistor tester is probably a good idea, if you want to do it 'properly' - but it looks like this method would work most of the time.
            -David VanHorn
            • senz_90
              • Aug 2013
              • 328
              • Indonesia
              I am see one of norcal715 video, he explained and showed how to test mosfet with his fluke meter, but after read some site and jestine yong article, I am really hesitant about this so maybe one of you had experienced before. My internet quota is almost finished now so i'll try to see it later. thanks.
              Best Regards
              Rudi
              Thank You
              • senz_90
                • Aug 2013
                • 328
                • Indonesia
                Btw, what is resettable fuse? i have read the manual one again and it said this DVM has a resettable fuse. i don't know what it looks like?
                Best Regards
                Rudi
                Thank You
                  http://www.littelfuse.com/products/resettable-ptcs.aspx
                  • senz_90
                    • Aug 2013
                    • 328
                    • Indonesia
                    thank you budm.
                    Best Regards
                    Rudi
                    Thank You
                    • Longbow
                      • Jun 2011
                      • 623
                      The "diode test" function which is found on DVM's is designed to forward bias transistor and diode junctions. The meter will not damage the junction because it will limit the current applied to the junction to a safe level. They already thought of that. No reason to worry.
                      Is it plugged in?
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8710
                        Weird... I just measured my analog meter in resistance mode:
                        Rx1 - measuring 0 ohms, it passes about 120mA (uses D-cell only)
                        Rx100- measuring 0 ohms, it passes about 1.2mA (also uses D-cell only)
                        Rx10K - measured around 65 microamperes?!?! (uses D-cell and 4xAA)
                        Trying to measure a 1W LED, only the Rx10K (expectedly) was able to light the LED. And I'm surprised the probes are actually correct (though resistance doesn't matter, measuring diodes it would be nice if the red probe is the current source and black the sink, when measuring resistance, just to know which is which.
                        I've only seen one analog meter so far that was hooked up backwards...
                        • senz_90
                          • Aug 2013
                          • 328
                          • Indonesia
                          As I know, analog VOM is common to have reverse polarity probes. red is negative and black is positive. Rx10k is supply 12VDC as I know, but I never measure the current. From my VOM label, didn't Rx1 have a greater current than Rx10k?
                          Btw anyone ever use this tester?
                          http://www.electronickits.com/kit/co...eas/dt100k.htm
                          is this good?
                          Best Regards
                          Rudi
                          Thank You
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8710
                            is this good?
                            Yes, 120mA in Rx1 is three orders of magnitude larger than the 65uA used in Rx10k.
                            I haven't had way too many analog VOMs to check, I remember my dad's VOM was wired in reverse as well as my AW-Sperry miniature analog VOM (that uses a single AA battery for its lone Rx1K mode). The Eico 555 is actually correct for whatever reason.
                            What kind of battery supplies 12VDC in your analog VOM? The Eico uses a D-cell and four AAAs. I suspect the AAA's will die drying out before its energy expended at 65uA.
                            • senz_90
                              • Aug 2013
                              • 328
                              • Indonesia
                              For big VOM is use PP3 9V battery and 2 AA (each 1.5V). Rx1, Rx10, Rx1k produce 3VDC output and Rx10k is 12VDC. Anyone using this analog VOM on my town and it is popural here.
                              For the small one it is just use a single AA battery inside.
                              Maybe I will try to measure the current. I think my VOM couldn't make a motor run when set to Rx10k instead Rx1.
                              Best Regards
                              Rudi
                              Thank You
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8710
                                The current pass seems very in line with my 50-year old Eico 555 with only 3 resistance modes. At Rx1 stage I think both of these analog meters should be able to turn a small hobby motor. I was just wondering how it got 12V, but 9V+2x1.5V is pretty normal. Reason why I asked is my dad's VOM had a custom battery in it, and I don't recall what it was. It apparently was also the sole battery in the design for Rx1 to Rx10K unlike the Eico that uses different batteries for different modes.
                                I think my small VOM is probably the same or a clone of the one you have... Not sure who was the OEM though, probably a lot of clones floating around.
                                • SM-Piyes90
                                  • Feb 2014
                                  • 120
                                  • Morocco
                                  The original brand is SANWA ( japanese brand ) , replica is sunwa like senz's one .
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8710
                                    The small one I have is an AW Sperry brand SP-5A. I never thought of it as a clone of something else but it could be, no clue. Other than its size and limited scales, it works fine... just need better probes...
                                    • SM-Piyes90
                                      • Feb 2014
                                      • 120
                                      • Morocco
                                      Just an advice , don't measure high voltages or currents , as this will degrade your VOM's lifetime.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8710
                                        Why is that a problem? Aren't things made to be used?
                                        I doubt I'd use it or the Eico that often anyway, my DMMs are quite a bit more convenient. However it is nice that analog VOMs can be attached to monitor a voltage or current without worrying about battery life...
                                        • vikivng
                                          guys..i need help with this lcd display used on ebikes pls.
                                          by vikivng
                                          This is an lcd display used on ebikes.
                                          long story short, there was condensation inside the unit.
                                          I opened it and thoroughly cleaned the pcb with isopryl.
                                          The board had no visible corosion.
                                          It powered on fine and was tested for an hour or so.
                                          However when connected to the bike,,it did not power on at all.
                                          I took it home and reopened it to take a look. There are no shorts based on MY testing.
                                          However,,when I probe the transistor and the mosfet gate in diode mode or contuinity mode, (one probe on transistor collector and one probe on mosfet gate}the unit...
                                          09-16-2025, 12:56 PM
                                        • Scruit
                                          MOSFET testing question
                                          by Scruit
                                          I am testing an NPD603AL (N-Channel Logic Level Enhancement Mode Field Effect Transformer) from an old Comapq Proliant 1500 CPU daughterboard. Symptoms are no post / no video, with only the psu / blackplane / cpu daughterboard and CPU in place.
                                          First question: This is not explicitly listed in the datasheet title as a MOSFET, however in the description it states it uses D-MOS technology. I assume this means it's just a MOSFET, and the "logic level" means it only needs 5v gate-source charge instead of 10v. Is that correct?
                                          I am testing this because...
                                          04-10-2022, 07:50 AM
                                        • Nooy
                                          VGA MOSfet permanently shorted and loss of MOSfet pad
                                          by Nooy
                                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                          02-14-2024, 02:26 AM
                                        • redbaron1007
                                          Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                                          by redbaron1007
                                          I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                                          Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                                          09-09-2025, 11:10 AM
                                        • AppleLover123
                                          Asus X712EA 3 volts after the first mosfet
                                          by AppleLover123
                                          Hey guys,
                                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                          Now i thought something...
                                          12-15-2024, 07:49 AM
