Different between analog VOM with DVM on testing transistor or mosfet
  • senz_90
    • Aug 2013
    • 328
    • Indonesia
    Re: Different between analog VOM with DVM on testing transistor or mosfet
    That small VOM is looks fragile. I don't like use it to measure high voltage or current, I am using the big one. If I were you I don't want to try it. If I remember correctly, the small one haven't fuse at all.
    Yes, the pros is we could measure voltage and current without fear of dying battery. The original brand is SANWA japanese brand and SM-Piyes90 were right, the others are clone. it seems the small one just have a 1.5V and hard to turn on the small motor, i haven't test it yet. that small one is just my beginning experience about electronic and now I am very rare to use it so I couldn't tell much.
    "There is no shortcut to be successful. No pain, no gain."
    Best Regards
    Rudi
    Thank You
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8709
      The small one I have can only measure 250mA and 500V (which is not quite as high as the YX1000A) so it's not like I'm going to measure that high a voltage. However I have measured mains voltage with it, shouldn't be a problem except that the probe wires were replaced with sub quality cables (hookup wire instead of probe wire since I don't have any on hand).
      My small one with the Rx1K will only source less than 1mA of current so it could not turn a motor. The larger meters with Rx1 that supply over 100mA should be able to drive tiny motors.
      I now have a small DMM (Mastech M300) that I use instead of the small analog VOM. Unfortunately it uses those A23 cells and it's real easy to kill the battery by leaving it on... sigh.
      • SM-Piyes90
        • Feb 2014
        • 120
        • Morocco
        Hi senz , i have found a cheap ( 5 USD ) chinese DMM using ICL7106 according to some sources , but is core is placed under some sort of silicon drop , do you have a way to track DT830D DMM's Microcontroller pin numbers ??
        • Agent24
          I see dead caps
          • Oct 2007
          • 5091
          • New Zealand
          Check ICL7106 datasheet and reference schematics, compare with which components are connected to which pins on the COB. You *might* figure it out.
          If you're trying to turn it into an ESR meter, I would say use it in conjunction with this: http://circuit-zone.com/?electronic_project=484
          -David VanHorn
          • SM-Piyes90
            • Feb 2014
            • 120
            • Morocco
            Nice one Agent , this makes thing real easy .
            Edit : in witch range should i read the ESR value ? 200 OHM rang by any chance ??
            • Agent24
              I see dead caps
              • Oct 2007
              • 5091
              • New Zealand
              #26
              Probably 200mV range actually.
              Easy to find out by testing by measuring a low ohm resistor. That is the same way we calibrate the Blue ESR meter from Bob Parker anyway.
              -David VanHorn
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8709
                I think that $5 meter is another rebadge of the Mastech M830, and yes I think it does use the die of an ICL7106-clone (according to schematics). It's not a microcontroller and doesn't have many special features.
                Usually the range used on the "ESR converters" are using one of the volts ranges and not resistance ranges. Staring at the schematic, it looks like it should output a higher voltage as the resistance increases. I was also wondering how it got AC needed and now see that it uses a dual rail +/- 5V supply to get the AC voltage needed.
                • senz_90
                  • Aug 2013
                  • 328
                  • Indonesia
                  #28
                  Yes, this cheap DMM were sold about $4 on my town. I don't have it so I couldn't see what's inside. But is this really have ICL7106/7 in there? I would like to buy it if it has, and when this failed I would scrap it around
                  Best Regards
                  Rudi
                  Thank You
                  • SM-Piyes90
                    • Feb 2014
                    • 120
                    • Morocco
                    #29
                    This one is an old dt830d model i guess new ones Are SMD based and use different IC package
                    Here is a picture of the old model's ICL solder holes
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8709
                      I haven't seen many DMMs with actual 7106 DIP in them anymore, most are surface mount dies with some sort of covering. Finding a 7107 is even more rare - I do have one in an old panel mount digital meter (200mV) but the two LED DMM's I have use the older LD110/LD111 chipset.
                      The last DMM I've ever seen with an actual 7106 40-DIP in it was a kit I bought decades ago, I gave it to a friend. Otherwise all these cheap meters, despite it still being a 7106 die, is just a die - and probably can't be removed from the circuit board.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5091
                        • New Zealand
                        #31
                        It's called COB - Chip On Board. Bare IC die connected to pads and covered with epoxy. You could take it off but it would be hard to do anything with.
                        Cutting out the piece of board it's on might be usable.
                        You can also buy full ICL710x chips on eBay quite cheaply.
                        -David VanHorn
                        • senz_90
                          • Aug 2013
                          • 328
                          • Indonesia
                          #32
                          maybe it is quite rare to find any ICL7106 chip on this DMM. Mine DMM also didn't have any IC on them just a black circular chip like those, maybe I have to choose the other option. thank you.
                          Best Regards
                          Rudi
                          Thank You
                          • vikivng
                            guys..i need help with this lcd display used on ebikes pls.
                            by vikivng
                            This is an lcd display used on ebikes.
                            long story short, there was condensation inside the unit.
                            I opened it and thoroughly cleaned the pcb with isopryl.
                            The board had no visible corosion.
                            It powered on fine and was tested for an hour or so.
                            However when connected to the bike,,it did not power on at all.
                            I took it home and reopened it to take a look. There are no shorts based on MY testing.
                            However,,when I probe the transistor and the mosfet gate in diode mode or contuinity mode, (one probe on transistor collector and one probe on mosfet gate}the unit...
                            09-16-2025, 12:56 PM
                          • Scruit
                            MOSFET testing question
                            by Scruit
                            I am testing an NPD603AL (N-Channel Logic Level Enhancement Mode Field Effect Transformer) from an old Comapq Proliant 1500 CPU daughterboard. Symptoms are no post / no video, with only the psu / blackplane / cpu daughterboard and CPU in place.
                            First question: This is not explicitly listed in the datasheet title as a MOSFET, however in the description it states it uses D-MOS technology. I assume this means it's just a MOSFET, and the "logic level" means it only needs 5v gate-source charge instead of 10v. Is that correct?
                            I am testing this because...
                            04-10-2022, 07:50 AM
                          • Nooy
                            VGA MOSfet permanently shorted and loss of MOSfet pad
                            by Nooy
                            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                            02-14-2024, 02:26 AM
                          • redbaron1007
                            Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                            by redbaron1007
                            I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                            Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                            09-09-2025, 11:10 AM
                          • AppleLover123
                            Asus X712EA 3 volts after the first mosfet
                            by AppleLover123
                            Hey guys,
                            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                            Now i thought something...
                            12-15-2024, 07:49 AM
