7c9l17-18l regulator?
  • aortiz
    • Feb 2014
    • 120
    • mexico
    what is this component? i searched the web and can not find its description.
    its on the logic/main board for a viewsonic 2030wm monitor that goes off at high resolution.
    please help
  • T30M31
    • Feb 2014
    • 58
    Re: 7c9l17-18l regulator?
    Can you post a picture of this component and the board it is on?
    I found a schematic for a VG2030m that may help if it is close to the model you have.
      1.8V LDO regulator?
      • aortiz
        • Feb 2014
        • 120
        • mexico
        its on the main/logic board( thats what i call it)its probably a different name.
        but here are some pictures of it ,bud suggested a 1.8 v regulator.
        i do appreciate both of your's efforts.
        • aortiz
          • Feb 2014
          • 120
          • mexico
          here its the picture of the board
          • T30M31
            • Feb 2014
            • 58
            I located and attached the service manual for a ViewSonic VG2030wm monitor.
            The main board has a 1.8 volt LDO regulator which is labeled I102. Is that the component you are looking for? It is located on page 43 of the attached PDF file.
            The schematic labels I102 as AP1117CY_1.8 and I did find voltage regulators by searching "1117CY".
            Edit: The bill of materials list I102 as an AIC1117A-18PY.
            • aortiz
              • Feb 2014
              • 120
              • mexico
              thank you t30m31,
              not wonder i couldnt find it !!
              that 7c9l17 number its what's printed on the component.
              and its totally different from ap1117cy.
              is this what a lot of you guys call the 1117 series?
              i am going to go over the squematic and try to find what and how was this ckt affected by the caps.
              thanks for your help and effort,its well appreciated.
                Yes, 1117 series. See post 6 for calculator and 7, 8 if you need them from Digikey.
                https://www.badcaps.net/forum/showth...999#post300999
                • aortiz
                  • Feb 2014
                  • 120
                  • mexico
                  thank you bud,good info ,i finally know what LDO means.
                  low drop output right? please correct me if i am wrong ,it says low dropout on the data sheets,so i ASSume they just kind of simplify it .
                  another dumb question:am i suppost to delete the posts of the items i fixed and if yes how do i do it?
                  • aortiz
                    • Feb 2014
                    • 120
                    • mexico
                    hey bud,
                    take a look at the service manual t30m31 sent me .
                    i think it has some more info then the one we got before,you tell me,but all info its welcome.
                    who knows you may have a use for it someday.
                    i guess viewsonic has a few different mods on the 2030 model,i dont know.
                      That is the same one I have. I have service manuals for 2 VG2030WM-1, VG2030M-1.
                      • aortiz
                        • Feb 2014
                        • 120
                        • mexico
                        i forgot where i got mine ,but its missing some info that this one has,i think i got it from viewsonic ,but they must to have sent me a different revision or something.
                        • disorder
                          HP 2311 display, 3.3v regulator fried, need help to replace
                          by disorder
                          hello,
                          i have a hp display 2311 to repair, totaly dead
                          on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                          i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                          thank you
                          07-27-2025, 04:34 AM
                        • bilux
                          uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
                          by bilux
                          I want to find a replacement for uP0109 8pins, and i found this parts:
                          uP0109 is "2A Ultra Low Dropout Linear Regulator"
                          RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
                          FP6137C is "2A BUS TERMINATION REGULATOR"
                          can replace uP0109​ by RT9199 or FP6137C ?
                          11-01-2024, 12:00 PM
                        • lostone
                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                          by lostone
                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                          05-19-2024, 11:40 AM
                        • playit
                          diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
                          by playit
                          hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
                          and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
                          for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
                          02-26-2025, 05:39 AM
                          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                          Based on Intersil's Robust Ripple Regulator...
                          11-05-2024, 03:24 PM
