How to bypass an auto shut off?
  • Regent
    Computer Tech
    • Dec 2011
    • 32
    I have an electric blanket that as an auto shut off after an hour! I want to use the blanket to warm up my flower seedling and I need it to always be on.
    Can anyone tell me if the auto shut off is on the circuit board or in the blanket itself? And can I bypass this annoying problem?
  • Regent
    Computer Tech
    • Dec 2011
    • 32
    Re: How to bypass an auto shut off?
    I did some research & I found that on the circuit board (as shown in the photo) there is a 3 pin ZTT 4.00MG ceramic resonator (blue) & they sometime can be use as a timer. Can someone confirm if this is where the one hour auto shut off is?
    By the way, the reason why this company (coz-e) as an auto shut off after an hour is in case you fall asleep. It as nothing to do with temperature control.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      I don't see why or how a resonator could be used in a temp control circuit.
      it is safe to assume that will either stop the auto shutdown or stop the unit from coming on at all.
      Follow the white rabbit.
      • Longbow
        • Jun 2011
        • 623
        If the blanket is controlled by a uPC, the 4 MHz resonator is the main clock. Many processors will also use a secondary 32KHz clock crystal to time the serial bus and for real time displays, etc. I doubt if a blanket is that complex. Slowing one or both of the crystals might delay the shut-off depending upon the circuit, but the auto shut off itself will still happen because it is programmed into the software.
        Even though it is tempting to use an electric blanket, it is a bad choice for use around water (plants) and you have very little control over the heat. Have a look a silicone heating strips. This solution is ideal for use around water and the control requirements are modest.
        http://www.watlow.com/products/heate...ne-heaters.cfm
        Is it plugged in?
        • Regent
          Computer Tech
          • Dec 2011
          • 32
          "the auto shut off itself will still happen because it is programmed into the software."
          Thank You very much Longbow for your excellent explanation!!!! I will be looking for another option like a silicone heating strips!
            There should be a device called TRIAC on the board which is used as a switch to supply power to the heater, it is turn on by the micro controller, so if you want to have the heater on all the time, then you have to bypass the TRIAC,
            On the left side you can see HI (HOT IN), NI (NEUTRAL IN), and SI (SWITCH IN), the Neutral IN is fed to a fuse F1 which is connected to N where one wire of the heater is connected to, the other wire of the heater is connected to L which is the output side of the TRIAC.
            • Regent
              Computer Tech
              • Dec 2011
              • 32
              Thanks budm for your reply. I assume your talking about Triac Z0405MF? There are two of them. I attach two pics, one from the back of the ic board & the other one the front.
              Could please you explain which one needs to be bypass & how I should do it?
              Circuit boards are not my specialty! Sorry about that! But I do want to learn.
              Last edited by Regent; 02-15-2014, 11:14 PM. Reason: The back of the ic board the triac are circle with a black marker.
                This controller looks like my Sunbeam thrown blanket, now I see the ON/OFF switch on the LED side of the board, that means the SI is not the switch but the sensor to detect how hot the blanket gets, if you bypass the circuit, the heater may just keep on heating and can over heat, I think that is one of the safety it has, so I do not feel safe for you to bypass the circuit, you can have big fire instead.
                • Regent
                  Computer Tech
                  • Dec 2011
                  • 32
                  Thanks for your help & advice budm!
                  • Regent
                    Computer Tech
                    • Dec 2011
                    • 32
                    If I keep the ON/OFF switch ON by holding it there with an elastic it will default to the low setting after the one hour auto shut off kicks in!
                    There are three settings low, medium & high. Every time you press the ON/OFF switch it bring you to the higher setting but if you hold the button while on the high setting it will default to the low setting after an hour.
                    My question is how can I bypass the low & medium and go directly to the high setting from the IC board?
                      • Jul 2011
                      • 6037
                      Here is what I would do use all parts there are except the controller board and built my own controller using what mirco controller you can program
                        Jump HI to L (do it at your own risk), then you will have full power to the heater, the only way to tun off is to unplug it, otherwise you'll need to re program the controller to do what you want to do.
                        You can also make a box with switch that will put a diode in series with the heater (50% power) or can be bypass with a switch to give full power. You need to know the current draw of the heater to get the correct size Diode.
                        If the heater is less than 300W, then you can use this:
                        http://www.westsidewholesale.com/lut...300nlh-wh.html
                        • Regent
                          Computer Tech
                          • Dec 2011
                          • 32
                          Thanks for your help.
                            That dimmer controller may work. Let us know what you end up with.
                            • Regent
                              Computer Tech
                              • Dec 2011
                              • 32
                              I also believe that a bypass from HI to L and the Dimmer Switch might very well work! The specs on the blanket says 60 watts. Again thanks for your help.
                                Only 60W, must be smaller blanket than mine, at HI it uses about 160W on my blanket. That dimmer should work just fine and will allow you to adjust the power as well to suit your need.
                                • shouri
                                  Dell latitude e5490 auto restart
                                  by shouri
                                  Hi guys, can someone help me?
                                  I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                                  Board model is dm70 la-f401p rev:1.0 2017-09-20.
                                  At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                                  After a few days test, is seems ok.
                                  Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                                  12-10-2024, 09:27 PM
                                • Spudgun
                                  Why doesn't current just bypass faulty capacitors.
                                  by Spudgun
                                  Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                                  04-01-2025, 10:33 AM
                                • classicandy
                                  Lenovo G50-80 Auto Power On when AC is detected
                                  by classicandy
                                  Hi Everyone,
                                  I have a Lenovo G50-80 that auto powers On when AC (Charger) is connected. I have checked the BIOS settings and there is no option to turn On or Off that feature as it is in some HP EliteBooks. I did update the BIOS and still same.
                                  I then flashed the BIOS with a different bin file I downloaded here, It worked (didn't auto power on) for some time (after testing up to 5 times) but has now started again to auto power on when AC is connected.
                                  The CMOS battery voltage is 3v. I have also tested with two main batteries as well. I would be glad if anyone...
                                  03-21-2024, 05:48 AM
                                • corrize
                                  Resonator - quartz broken - how to find the same (same frequency) ?
                                  by corrize
                                  Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
                                  I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
                                  I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
                                  I'm searching another one for compare…
                                  Do you have an idea or another way for find the frequency of this resonator please ?
                                  (I did not found the manufacturer of this component ? And I did not found the...
                                  03-27-2025, 09:20 PM
                                • Arshad alam4659
                                  a1466 smc bypass
                                  by Arshad alam4659
                                  what is smc bypass and how does it work and how to bypass it i want to know can anyone tell me about it
                                  11-09-2024, 08:22 AM
