Identifying component Flyback? DC-DC?
This topic has been answered.
  • unimatrix93
    • Oct 2021
    • 360
    • Magyarország
    Can I ask you guys help me identify this godforsaken component?
    I'm tearing my hair out finding this component.
    The board is from an egg incubator.
    i got it with a "popped cap" while there are many damaged components on it, which got succesfully identified with one exception:
    And here is the board where it came from (U1/1):
    As you can see, the IC is badly damaged. Only a few characters are visible and a unknown by me manufacturer logo. Also it has 3 pin on the top side.
    Can you please help me find out what is it?
  • Answer selected by unimatrix93 at 05-10-2024, 01:20 AM.
    truclacicr
    • Apr 2019
    • 352
    • australia
    The manufacturer is Crystal Source Microelectronics.
    Datasheet for CSC7136D:
    https://dfsimg2.hqewimg.com/group1/M...vXAKmCs236.pdf
    • truclacicr
      • Apr 2019
      • 352
      • australia
      Try reposting your question here:
      https://www.eevblog.com/forum/repair/
      • petehall347
        • Jan 2015
        • 4445
        • United Kingdom
        st micro
        • redwire
          • 3912
          Why go to eevblog, they are a cranky bunch over there.
          These IC's are in-country copies of real parts. It's not ST, it could be "SC" or "STC" the S is for Shenzhen. Most SOP-7's have pin 3 missing but here it is pin 7 which narrows it down.
          Looking at the circuit, closest IC PN8370SSC matches pinout and primary-side voltage sensing but it's too much at 18W.
          OP's board the sense-resistor on pin 4 is also blown.
          • truclacicr
            • Apr 2019
            • 352
            • australia
            PN8366 is rated for 6W loads:
            • truclacicr
              • Apr 2019
              • 352
              • australia
              I hate this forum's software.
              I hope this URL works:
              https://voltatech.ir/wp-content/uploads/2021/11/آی-سی-PN8366-پکیج-SMD.pdf (PN8366, 6W)
              https://radioremont.com/wa-data/publ...nts/PN8360.pdf (PN8360, 12W)
              • R_J
                • 9607
                It could be this, CSC7136D seems to be the same pinout as the pn8360
                • truclacicr
                  • Apr 2019
                  • 352
                  • australia
                  • unimatrix93
                    • Oct 2021
                    • 360
                    • Magyarország
                    Thank you everyone for helping me out!
                    You are the best. 🤘
                    I was pulling my hair out identifiying this exploded sh˙t.
                    • redwire
                      • 3912
                      What about the blown sense-resistor at pin 4? Maybe "2R2" marking? gives 227mApk I think.
                      • unimatrix93
                        • Oct 2021
                        • 360
                        • Magyarország
                        Yes, its a 2K2.
                        Also have to replace:
                        - 2KV keramic 1nF cap.
                        - B1000S05 bridge rectifier
                        - 450V/6.8uF capactior
                        - An unkown cap next to it
                        - A BT131-600
                        - A microswitch
                        - And repair some track.
                        • R_J
                          • 9607
                          That resistor from CS to ground is likely a 2R2 (2.2Ω) resistor, not a 2K2 (2.2KΩ)
                          If the unknown cap is the vcc capacitor off D9, it is likely around 47µf/50v
                          • redwire
                            • 3912
                            Does it have a fuse anywhere? I would add one.
                            Or for all the blown parts from the power surge, consider just using another small DC power supply feeding this control board. It must output 5 or 9 or 12V at most 1A.
                            The triac is for the turntable motor? No light or heater?
                            • R_J
                              • 9607
                              The fuse is next to the plug in the heatshrink
                              • redwire
                                • 3912
                                What pic is that in? I can't see any heatshrink in the posted pics.
                                • CapLeaker
                                  Leaking Member
                                  • 8340
                                  redwire I think RJ means the first post second picture, very last plug on the bottom. Below it there is black something.
                                  • petehall347
                                    • Jan 2015
                                    • 4445
                                    • United Kingdom
                                    this was a fuse . Click image for larger version
Name:	Screenshot from 2024-06-04 22-48-51.png
                                    • redwire
                                      • 3912
                                      Melted copper traces, but nothing looking like an arc happened thought it should be black. Oh wait the trace she gone.
                                      I have issues with cheap chinese power supplies having no fuse, how do we allow this junk into our countries.
                                      • unimatrix93
                                        • Oct 2021
                                        • 360
                                        • Magyarország
                                        So after the IC arrived from China I repaired the damaged traces and proceeded to install the IC.
                                        The test resulted in a glorious explosion and the 2R2 resistor blew up also burning off the metal side of the ceramic capactor. The bridgerectifier (B1000S05) and the fuse (250V/10A) also died.
                                        The explosion happened after holding down the power button for a few seconds.
                                        What could cause this issue? I did not connect the other parts to the PCB like the motor and fan, only the main AC.
                                        • tony359
                                          Faulty CRT AKF12/Philips CM8500: bad flyback?
                                          by tony359
                                          I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                                          What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                                          There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                                          Can it be a short somewhere...
                                          08-22-2023, 04:39 PM
                                        • retrotechrestoration
                                          Looking for a flyback transformer for an Eizo TX-C7 MA-791 17" CRT
                                          by retrotechrestoration
                                          I just saved this magnificent RGB input Eizo Flexscan TX-C7 MA-791 from the local e-waste...good news, the tube works and the board looks great...the bad news, it sounds like the flyback is shorted. (Turns on...perfect picture...systemic high voltage crackling heard while the picture flickers...then it blows the 5A fuse in my isolated A/C power supply.)
                                          Anyone have any leads on possibly finding a replacement? (photo shows the flyback model numbers)​...
                                          03-22-2024, 06:50 AM
                                        • AustinCER
                                          Need Help Identifying this LCD FPC for Dell G3 15 3590 Gaming Laptop
                                          by AustinCER
                                          I am in search for some help in identifying the LCD FPC. It is a connector for a plug-able eDP cable.
                                          Attached is a photo of the FPC.
                                          Model: Dell G3 15 3590 Gaming Laptop
                                          ST: 79QYJT2
                                          Thank you very much in advanced....
                                          Yesterday, 02:55 PM
                                        • RetroComputingGrotto
                                          Need Help Identifying A Diode
                                          by RetroComputingGrotto
                                          I have an MSI 3PA1 monitor on my bench that wont power on. I have tested the 2 (what I believe to be Schottky Diodes) and both are shorted in both directions (a common faulty from what I can see on Google) but I'm not certain what the markings on the Diodes mean so I need some help in identifying which ones to order from Mouser please?
                                          I've done a search for 101C 5100C and all I can find are datasheets for 5100C which say they are 20-100V 5A Schottky Diodes but I'm not 100% sure if this is correct or not and what significance the 101C is.
                                          We...
                                          09-22-2025, 06:47 AM
                                        • Khoja
                                          Lenovo Ideapad Flex 5 14IAU7 (LC57-IAU MB 213062-1M) identifying elements
                                          by Khoja
                                          Hello friends, I have a Lenovo Ideapad Flex 5 14IAU7 laptop that doesn’t turn on. When I opened it, I found a burnt resistor on the motherboard. Since I couldn’t find a schematic for this model, I need help identifying the parameters of this resistor.
                                          • Model: Lenovo Ideapad Flex 5 14IAU7
                                          • SN: PW0AZK3W
                                          • Motherboard: LC57-IAU MB 213062-1M 448.0RH09.001M
                                          Any assistance would be greatly appreciated!...
                                          09-19-2025, 09:56 AM
