Identifying component Flyback? DC-DC?
This topic has been answered.
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    Can I ask you guys help me identify this godforsaken component?
    I'm tearing my hair out finding this component.
    The board is from an egg incubator.
    i got it with a "popped cap" while there are many damaged components on it, which got succesfully identified with one exception:
    And here is the board where it came from (U1/1):
    As you can see, the IC is badly damaged. Only a few characters are visible and a unknown by me manufacturer logo. Also it has 3 pin on the top side.
    Can you please help me find out what is it?
  • Answer selected by unimatrix93 at 05-10-2024, 01:20 AM.
    truclacicr
    • Apr 2019
    • 299
    • australia
    The manufacturer is Crystal Source Microelectronics.
    Datasheet for CSC7136D:
    https://dfsimg2.hqewimg.com/group1/M...vXAKmCs236.pdf
    • truclacicr
      • Apr 2019
      • 299
      • australia
      Try reposting your question here:
      https://www.eevblog.com/forum/repair/
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        st micro
        • redwire
          • 3906
          Why go to eevblog, they are a cranky bunch over there.
          These IC's are in-country copies of real parts. It's not ST, it could be "SC" or "STC" the S is for Shenzhen. Most SOP-7's have pin 3 missing but here it is pin 7 which narrows it down.
          Looking at the circuit, closest IC PN8370SSC matches pinout and primary-side voltage sensing but it's too much at 18W.
          OP's board the sense-resistor on pin 4 is also blown.
          • truclacicr
            • Apr 2019
            • 299
            • australia
            PN8366 is rated for 6W loads:
            • truclacicr
              • Apr 2019
              • 299
              • australia
              I hate this forum's software.
              I hope this URL works:
              https://voltatech.ir/wp-content/uploads/2021/11/آی-سی-PN8366-پکیج-SMD.pdf (PN8366, 6W)
              https://radioremont.com/wa-data/publ...nts/PN8360.pdf (PN8360, 12W)
              • R_J
                • 9535
                It could be this, CSC7136D seems to be the same pinout as the pn8360
                • truclacicr
                  • Apr 2019
                  • 299
                  • australia
                  • unimatrix93
                    • Oct 2021
                    • 343
                    • Magyarország
                    Thank you everyone for helping me out!
                    You are the best. 🤘
                    I was pulling my hair out identifiying this exploded sh˙t.
                    • redwire
                      • 3906
                      What about the blown sense-resistor at pin 4? Maybe "2R2" marking? gives 227mApk I think.
                      • unimatrix93
                        • Oct 2021
                        • 343
                        • Magyarország
                        Yes, its a 2K2.
                        Also have to replace:
                        - 2KV keramic 1nF cap.
                        - B1000S05 bridge rectifier
                        - 450V/6.8uF capactior
                        - An unkown cap next to it
                        - A BT131-600
                        - A microswitch
                        - And repair some track.
                        • R_J
                          • 9535
                          That resistor from CS to ground is likely a 2R2 (2.2Ω) resistor, not a 2K2 (2.2KΩ)
                          If the unknown cap is the vcc capacitor off D9, it is likely around 47µf/50v
                          • redwire
                            • 3906
                            Does it have a fuse anywhere? I would add one.
                            Or for all the blown parts from the power surge, consider just using another small DC power supply feeding this control board. It must output 5 or 9 or 12V at most 1A.
                            The triac is for the turntable motor? No light or heater?
                            • R_J
                              • 9535
                              The fuse is next to the plug in the heatshrink
                              • redwire
                                • 3906
                                What pic is that in? I can't see any heatshrink in the posted pics.
                                • CapLeaker
                                  Leaking Member
                                  • 8120
                                  redwire I think RJ means the first post second picture, very last plug on the bottom. Below it there is black something.
                                  • petehall347
                                    • Jan 2015
                                    • 4426
                                    • United Kingdom
                                    this was a fuse . Click image for larger version
Name:	Screenshot from 2024-06-04 22-48-51.png
                                    • redwire
                                      • 3906
                                      Melted copper traces, but nothing looking like an arc happened thought it should be black. Oh wait the trace she gone.
                                      I have issues with cheap chinese power supplies having no fuse, how do we allow this junk into our countries.
                                      • unimatrix93
                                        • Oct 2021
                                        • 343
                                        • Magyarország
                                        So after the IC arrived from China I repaired the damaged traces and proceeded to install the IC.
                                        The test resulted in a glorious explosion and the 2R2 resistor blew up also burning off the metal side of the ceramic capactor. The bridgerectifier (B1000S05) and the fuse (250V/10A) also died.
                                        The explosion happened after holding down the power button for a few seconds.
                                        What could cause this issue? I did not connect the other parts to the PCB like the motor and fan, only the main AC.
