SATA power connector: which moron invented it?
  • reaper57
    • Sep 2014
    • 216
    • Norway
    #41
    Re: SATA power connector: which moron invented it?
    I agree that the molexes are better for some stuff, like testing with a dmm or giving power to something that is not supposed to be powered by an atx psu. I even managed to get an xbox 360 falcon (175W) to run off of one molex! But sata has its perks too. Like slimness. If desktop HDDs used only molex, then you wouldn't be able to connect 2.5" (laptop) drives to a desktop pc without an adapter. I'm fine with sata as long as my psu still has a few molexes.
    Keyboard not detected, press F1 to continue...
    • SteveNielsen
      Retired Tech
      • 2327
      I don't think anyone is suggesting that SATA use molex connectors, just that SATA connections are not designed well at all.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        For SATA the drive activity LED is ported out on the power interface instead of data, unlike PATA. Getting the drive activity light info is kind of useful for me, I wish I had a source of the SATA power connectors that had that wire connected out.
        I still hate SATA connectors because I can't just put in my own connector there, they tend to be molded and thus you can't add your own pins....grr...
        • Behemot
          • 4845
          • CZ
          #44
          After all, they could've just used plain old Berg connectors. Being so ancient, it still is smaller, more robust and could carry twice as power per connector as SATA.
          That sounds like nonsense to me. Power goes directly to power supply, there is no way to get anything from that. You need to go the controller way.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            Sounds like nonsense but it's the truth! Nothing is stranger than the truth!
            • mariushm
              • May 2011
              • 3799
              #46
              Specs:
              See page 259 and onwards (click picture to zoom).
              • Behemot
                • 4845
                • CZ
                #47
                But that's only relevant for backplanes, that means servers mostly, not that you connect a wire to pin 11 and go, you will read nothing as long as it is grounded. If you wanted to use that, you would have to place a board between the drive and power connector, and interrupt that pin 11 ground.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  #48
                  I like Sata, so much better than IDE.
                  Follow the white rabbit.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8716
                    Regardless, yes this is for a hotswap backplane and can be applied to general purpose usage.
                    Here's someone with a minimalistic wiring for the power connector to have an activity light - and virtually it's the same for my 4-bay SATA hotswap backplane.
                    http://www.tooms.dk/forum/topic.asp?TOPIC_ID=280
                    I have one last singleton hotswap bay that does not port out the activity LED. I really wish this one did so I could see when this bay is actually being used or not.
                    • Behemot
                      • 4845
                      • CZ
                      #50
                      OK than it makes sense :-) But definitelly use some small transistor as suggested, even the spec says it has very low current and is not to drive LED directly.
                      • Behemot
                        • 4845
                        • CZ
                        #51
                        Guys I just received those female power connectors, solder-on-cable type. I'll take photos and list them later today.
                        From my last observation I am sttill the only seller on the planet you can buy those from. Anybody wants some let me know!
                        • ChaosLegionnaire
                          HC Overclocker
                          • Jul 2012
                          • 3266
                          • Singapore
                          #52
                          well both the sata and molex connectors have their pros, cons and shortcomings. the only constructive solution would be for one of us here to invent one universal connector to rule them all (lotr reference intended), then patent it and then retire early on all the royalty fees. mmhmmm~
                          • Behemot
                            • 4845
                            • CZ
                            #53
                            Basic price is 6.99 CZK a piece. Thats about US 28c according to current exchange rate.
                              You have good prcie.
                              28 cents is really good price compared to this guy in the US:
                              http://www.moddiy.com/products/SATA-...FYdbfgod80UPZw
                              http://nl.aliexpress.com/item/10pcs-...393632453.html
                              How do you crimp the wires?
                              • Behemot
                                • 4845
                                • CZ
                                #55
                                Dafuk, last time I checked two months ago and nobody else got it! Well, still the only one in Europe
                                • mockingbird
                                  • Dec 2008
                                  • 5488
                                  #56
                                  How do you cap them?
                                  Would you mind posting a picture of how you solder it as well?
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #57
                                    Have not been informed about any cover, you just leave it…or insulate the solder side by a strip of heatshrink.
                                    First you press it using long-nose pliers and than solder preferably with microsolder pen. You've seen it already.
                                    • mockingbird
                                      • Dec 2008
                                      • 5488
                                      #58
                                      Thanks.
                                      I see those two little poles coming out the top, so I thought there has to be some sort of cover for it.
                                      edit: To be more specific, I'm thinking of how to mount that thing in a little plastic project box so that it should look nice from the outside. Any ideas?
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #59
                                        You get PCB solder version. I think they just took it - thats what those poles are for (they fit into holes in PCB) - and put different pins inside.
                                        These connectors are no way ideal, but they are the only one there are at the moment. And to want something custom, I'd need to order a milion or so.
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #60
                                          Well I increased the price a few cents (to 9.9 CZK incl. VAT, so you substract 21 %). Several ppl told me they are too cheap
                                          • coinwizx
                                            Burned out PSU Corsiar HX1200 and NZXT C850, connected to wrong Molex/Sata cable from EVGA.
                                            by coinwizx
                                            Anybody has experience repair PSU burned out due to connect to EVGA molex/sata cables. I know the cable is not compatible (i got them mixed up), but I though i can connect it and use a PSU tested to find out which is the wrong sata/molex cables. As soo as I pluged in the powered molex cable to the PSU tester, the power supply short out, and will not turn on anymore. After the incident, the PSUs (both HX1200 and C850) try to power on and shut itself off immediately. The ATX PSU tester survice the short circult, still working perfectly. Anybody know if it's an easy fix or know which parts...
                                            09-09-2025, 03:11 PM
                                          • DynaxSC
                                            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                            by DynaxSC
                                            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                            The board is generally working now, all PCIe ports are working, Windows installs normally.
                                            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                            03-10-2025, 12:27 PM
                                          • Tomylee
                                            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                                            by Tomylee
                                            Sorry for the person who’s going to read all this !
                                            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                                            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                                            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                                            07-11-2025, 11:52 AM
                                          • 5mall5nail5
                                            Help identifying connector for ASUS 4090 Strix RGB LED connector
                                            by 5mall5nail5
                                            Hi All -
                                            I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                                            Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                                            05-04-2025, 07:47 AM
                                          • mosfetratus
                                            identify sata connector
                                            by mosfetratus
                                            What type of sata connector is this? From normal use, pins connecting to the board broke. Looking for replacement.
                                            I have spare xbox 360 sata connectors, tried to solder it. 5v to 5v, but drive won't spin. Just faint ding ant that's it....
                                            07-09-2022, 05:04 AM
