SATA power connector: which moron invented it?
  • reaper57
    • Sep 2014
    • 216
    • Norway
    #41
    Re: SATA power connector: which moron invented it?
    I agree that the molexes are better for some stuff, like testing with a dmm or giving power to something that is not supposed to be powered by an atx psu. I even managed to get an xbox 360 falcon (175W) to run off of one molex! But sata has its perks too. Like slimness. If desktop HDDs used only molex, then you wouldn't be able to connect 2.5" (laptop) drives to a desktop pc without an adapter. I'm fine with sata as long as my psu still has a few molexes.
    Keyboard not detected, press F1 to continue...
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      I don't think anyone is suggesting that SATA use molex connectors, just that SATA connections are not designed well at all.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        For SATA the drive activity LED is ported out on the power interface instead of data, unlike PATA. Getting the drive activity light info is kind of useful for me, I wish I had a source of the SATA power connectors that had that wire connected out.
        I still hate SATA connectors because I can't just put in my own connector there, they tend to be molded and thus you can't add your own pins....grr...
        • Behemot
          • 4845
          • CZ
          #44
          After all, they could've just used plain old Berg connectors. Being so ancient, it still is smaller, more robust and could carry twice as power per connector as SATA.
          That sounds like nonsense to me. Power goes directly to power supply, there is no way to get anything from that. You need to go the controller way.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Sounds like nonsense but it's the truth! Nothing is stranger than the truth!
            • mariushm
              • May 2011
              • 3799
              #46
              Specs:
              See page 259 and onwards (click picture to zoom).
              • Behemot
                • 4845
                • CZ
                #47
                But that's only relevant for backplanes, that means servers mostly, not that you connect a wire to pin 11 and go, you will read nothing as long as it is grounded. If you wanted to use that, you would have to place a board between the drive and power connector, and interrupt that pin 11 ground.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  #48
                  I like Sata, so much better than IDE.
                  Follow the white rabbit.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Regardless, yes this is for a hotswap backplane and can be applied to general purpose usage.
                    Here's someone with a minimalistic wiring for the power connector to have an activity light - and virtually it's the same for my 4-bay SATA hotswap backplane.
                    http://www.tooms.dk/forum/topic.asp?TOPIC_ID=280
                    I have one last singleton hotswap bay that does not port out the activity LED. I really wish this one did so I could see when this bay is actually being used or not.
                    • Behemot
                      • 4845
                      • CZ
                      #50
                      OK than it makes sense :-) But definitelly use some small transistor as suggested, even the spec says it has very low current and is not to drive LED directly.
                      • Behemot
                        • 4845
                        • CZ
                        #51
                        Guys I just received those female power connectors, solder-on-cable type. I'll take photos and list them later today.
                        From my last observation I am sttill the only seller on the planet you can buy those from. Anybody wants some let me know!
                        • ChaosLegionnaire
                          HC Overclocker
                          • Jul 2012
                          • 3264
                          • Singapore
                          #52
                          well both the sata and molex connectors have their pros, cons and shortcomings. the only constructive solution would be for one of us here to invent one universal connector to rule them all (lotr reference intended), then patent it and then retire early on all the royalty fees. mmhmmm~
                          • Behemot
                            • 4845
                            • CZ
                            #53
                            Basic price is 6.99 CZK a piece. Thats about US 28c according to current exchange rate.
                              You have good prcie.
                              28 cents is really good price compared to this guy in the US:
                              http://www.moddiy.com/products/SATA-...FYdbfgod80UPZw
                              http://nl.aliexpress.com/item/10pcs-...393632453.html
                              How do you crimp the wires?
                              • Behemot
                                • 4845
                                • CZ
                                #55
                                Dafuk, last time I checked two months ago and nobody else got it! Well, still the only one in Europe
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  #56
                                  How do you cap them?
                                  Would you mind posting a picture of how you solder it as well?
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #57
                                    Have not been informed about any cover, you just leave it…or insulate the solder side by a strip of heatshrink.
                                    First you press it using long-nose pliers and than solder preferably with microsolder pen. You've seen it already.
                                    • mockingbird
                                      • Dec 2008
                                      • 5484
                                      #58
                                      Thanks.
                                      I see those two little poles coming out the top, so I thought there has to be some sort of cover for it.
                                      edit: To be more specific, I'm thinking of how to mount that thing in a little plastic project box so that it should look nice from the outside. Any ideas?
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #59
                                        You get PCB solder version. I think they just took it - thats what those poles are for (they fit into holes in PCB) - and put different pins inside.
                                        These connectors are no way ideal, but they are the only one there are at the moment. And to want something custom, I'd need to order a milion or so.
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #60
                                          Well I increased the price a few cents (to 9.9 CZK incl. VAT, so you substract 21 %). Several ppl told me they are too cheap
                                          • DynaxSC
                                            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                            by DynaxSC
                                            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                            The board is generally working now, all PCIe ports are working, Windows installs normally.
                                            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                            03-10-2025, 12:27 PM
                                            HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
                                            This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-12-2024, 03:28 PM
                                          • clabr
                                            Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                            by clabr
                                            Need help to solve some problems with this laptop.
                                            After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                            After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                            Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                            Before this had happened I observed some other problems:
                                            When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                            12-02-2021, 08:09 AM
                                            Pegatron M2N78-LA (rev. 3.02) freezes on POST with SATA drives attached
                                            by momaka
                                            Like the title says, I have a Pegatron M2N78-LA (HP P/N: 513430-002) motherboard out of an HP Pavilion PC. The motherboard hard-locks during POST when it gets to the part of trying to detect the SATA devices *only* if there is a SATA device (be it HDD or optical drive) connected to any of the SATA ports. I cannot enter BIOS or do anything when this occurs. Pressing Ctrl+Alt+Del cannot restart the system either. In fact, the keyboard locks up too (Num Lock status LED cannot be toggled anymore.). However, if I disconnect everything from the motherboard's SATA ports, the motherboard can POST successfully...
                                            11-28-2020, 11:08 PM
                                          • playit
                                            psu sata power wires thinner - does it make a difference ?
                                            by playit
                                            hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
                                            i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
                                            any explanation on this ?? thank you ,soon i am planning to buy some branded...
                                            10-12-2023, 05:25 AM
