Hello, I'm having an issue determining the value for a 5-band resistor on my LG 42PJ350-ub power supply. The bands in order are: Orange, Blue, Silver, Gold, Black. Tested out of circuit returned .6 ohms. To my knowledge this color combination should not be valid; and I'm hoping someone more knowledgeable than myself may be able to decipher this code.
TV resistor not making any sense
Re: TV resistor not making any sense
What resistance do you get when you touch your meter probes together? about 0.3 Ohms, then that is correct 0.36 Ohms + 0.3 Ohms for the meter lead. This resistor when it failed, it will usually go open circuit.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
is looks more like inductor to me http://cdn.instructables.com/FRQ/J6V...NQFK.LARGE.gifComment
It's a 0.36 5% wirewound-resistor.
The marking color "BLACK" means manufacture's series .
Some for Nonflame type with BLACK marking ; or
non inductive wire wound resistors(無感繞線電阻) ---> GREEN
inductive wire wound resistors(有感繞線電阻) ----> BLACKAttached Filesif you find these attachements useful please consider making a small donation to the site
This resistor is probably for the Source pin of the MOSFET or fusible resistor for the B+.Never stop learning
by gica69I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
Resistor shows orange range silver gold and green lines.
Thanks in adv...4 Photos -
by BasteHello,
As the title says. I bought a cheap Asus ROG Strix 750-watt PSU, which was posted as defective. Cables are complete, and the entire PSU is in good condition, of course, aside from being faulty. Long story short, upon checking, there is no +5VSB. Looking at the components, I found a blown resistor. I swear, looking at the bands, the color is pink, pink, gold, gold. I dunno if I'm color blind or this is the way resistors are coded.
Please help, did I decode it correctly at 2.2 ohms (red, red, gold, gold), or what could a pink, pink, gold gold value be? I bought a... -
by jinu_jHi
4. D930 - Shorted Schottkey Diode...-
Hi.
Quick question.
I have a laptop that is completely dead. I opened it up and it looks like the current sense resistor is blown. However, because it's blown, the value printed on the top has disintegrated and there is no schematic available for this particular laptop (Dynabook Portege) so I'm not sure what to replace it with. -
by mikey5791Hi to all forum members,
Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... - Loading...
