Replacing a Current Sense Resistor
  • Darren Hibbert
    • 114
    Hi.
    Quick question.
    I have a laptop that is completely dead. I opened it up and it looks like the current sense resistor is blown. However, because it's blown, the value printed on the top has disintegrated and there is no schematic available for this particular laptop (Dynabook Portege) so I'm not sure what to replace it with.
  • Darren Hibbert
    • 114
    Anyone?
    • mon2
      • 14306
      Locate the charger ic and then a reference schematic that uses the same controller. This board most likely will use the same current sense resistor. Design engineers like to follow proven reference designs.
      Have to say that it is rare for the current sense resistor to burn out.
        Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
        The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
        The bq24745 features dynamic power management...
        10-23-2024, 02:50 AM
      • Ancient1
        Need help changing (single board TV) LED Driver's Current ( FB Resistor )
        by Ancient1
        Elco (?) 50" Smart TV. Backlight ( BL) issue.
        Single Board : TP.SK708D.PC821
        I bought new BL set . - OK
        Power up : Blip . Protection.
        Led Tester shows current at 34.2 mA , Previously it was 42.1 mA
        Solution : Change current output .
        The BL IC is marked on the photo and datasheet is QOB33535 Datasheet(PDF) - Schneider Electric (alldatasheet.com)
        Calculating according to the datasheet - see attached photo :
        With ILed = 34.2mA , equation #1 is RFb = 400mV / 34.2 = 11.7 Ohm , and with 42.1 mA we get 9.50 Ohm . i.e I should look for 9.5 Ohm...
        06-09-2024, 12:25 PM
      • unimatrix93
        Which resistor should I remove/replace to decrease current to backlight leds?
        by unimatrix93
        Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
        However I need some help identifying the resistor I need to replace to achieve this.
        Thank you!
        11-29-2024, 05:05 AM
      • DadBuk
        What is a good current sense reading
        by DadBuk
        Hi, have searched high and low for some info on what a good current sense reading is as it applies to MacBooks. On a MacBook there are many isense signals and it seems logical that the higher the voltage of that signal then the more current is flowing through that rail. What I have not been able to determine from the schematics or from searching the forums is the voltage range of a current that is in spec versus one that is out of spec and therefore causes the MacBook to take some action. I see in the schematics there are values for the max current on a rail but nothing that looks to be the voltage...
        01-24-2022, 05:40 AM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
