aeg 12v lithium battery broken
  • mentholflash
    • Mar 2013
    • 36
    • Western Australia
    hi all
    i am new to this forum and have many questions about quite a few things and intend to learn a lot
    but yesterday my thithium battery stopped charging and charger indicates broken battery
    i opened the battery to see if i could replace the cells with with a bigger ah
    i tested each cell to find that they read 4.13 4.15 and 4.11 this seemed about right so i investigated further to find that the strap from 1 battery to the other had broken so i solered a whire across the twothought this would be the fix
    it was notthere are 3 cappasitors 1 temperature sensor and somthing on the side that i havent uncovered yet as i think 1 of the cappasitors has a ground fault
    my quesion is how do i identify the offending object
    thanks for reading and dont be to harsh if ive got it wrong altogether
    i have attached a pic to help
    cheers
  • mentholflash
    • Mar 2013
    • 36
    • Western Australia
    Re: aeg 12v lithium battery broken
    hi all
    can anyone help with this battery it is showing as broken in the charger and i could do with it for work
    thanks
      • Jul 2011
      • 6040
      Who make this battery pack
      If this is Milwaukee M12 battery pack
      There is something you should know about these battery pack if the voltage
      different between cells more than ( [0.25 ] volts it will not charge this is not a misprint )
      Battery Load.................>>>
      You need to test these batteries one at a time you need a 12 volt 50 watt bulb and a volt meter
      Each battery need to read about the same voltage and different can not be more than more than ( [0.25 ] volts between cells
      if it is more than that then these cells are weak
        • Jul 2011
        • 6040
        Do you have a spare battery that shows good to know if the charger is working right
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          it seems to be a bit out of balance.
          i bet the broken joint caused the management chip in the pack to shut down.
          some can be reset.
          • mentholflash
            • Mar 2013
            • 36
            • Western Australia
            thanks for the replys
            the battery is made by aeg witch is somthing to do with Milwaukee i think
            i do have another battery and the charger is working fine
            it was a broken connection that stopped it working but i have soldered a bridge across the breakage
            i will check the voltages of the batteries
            just throwing this in there how about if i attach a small fan and wait till all batteries are dead then do you think they will recharge
            thanks again for your help
            cheers
              • Jul 2011
              • 6040
              Maybe but do not count on it....> "do you think they will recharge"
              " wait till all batteries are dead then ".....> This is not a good idea you need to only discharge them to a voltage of 2.8 volts and no lower than that
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • emeskay
                Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                by emeskay
                We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                08-06-2024, 07:13 AM
              • mkdj
                ASUS X571 no power : battery issue?
                by mkdj
                Mark and model: ASUS X571
                Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                Tests already made:
                - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                - I have removed...
                07-14-2025, 09:16 AM
              • techfreak9356
                Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                by techfreak9356
                I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                09-14-2023, 11:10 PM
                NVDC charger configuration...
                11-05-2024, 03:28 PM
