Building an ESR meter, some help and someone to check my PCB layout
  • garry7263
    • Feb 2013
    • 105
    I decided to build an ESR meter. I wanted a hybrid that didn't use 4 AA batteries and uses a 9 volt so there would not be a voltage drop and need constant adjusting. This is the original schematic and board layout.
  • garry7263
    • Feb 2013
    • 105
    Re: Building an ESR meter, some help and someone to check my PCB layout
    Schematic
    • garry7263
      • Feb 2013
      • 105
      Using the power supply off of this schematic
      • garry7263
        • Feb 2013
        • 105
        This is the circuit, and the PCB minus a dpdt switch and LED to show power on and to turn it on.
        • garry7263
          • Feb 2013
          • 105
          Question about the meter to be used. The original schematic calls for a 50uA meter but all I can find is a 200uA. In line with the potentiometer is a 10k resistor. Should I reduce that to maybe 1k, or remove it all together to get full deflection from the meter?
          If anyone can double check my PCB layout and make sure I have it layed out right I would appreciate the help.
          • barry wilkins
            • Aug 2009
            • 172
            I built this circuit over a year ago ,if you dont use a 50uA meter it will not work because of sensitivity , I had to make a few mods the circuit can drift with temperature.
            It does show caps with poor ESR from 100uF upwards ,below this value the reactance of the cap overrides the readings.
            Barry Wilkins
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              I want to build something like this, but my knowledge of designing electronics is very limited.
              • redwire
                • 3912
                Just a note, I feel this ESR tester is for older radio gear and hard to discern many failing caps in SMPS applications. It's rated 90% meter deflection for 1 ohm... I think this is the original design, the PCB files are here too.
                I built a few simple ESR meters and did not have great results. I took my bucket of dead electrolytics and retested them and for most ESR meter circuits, their problem is resolution, i.e. the meter needle moves a hair between 0.01 and 0.2ohm and I find that is essential to diagnose a weak or dud cap. There's other threads here about building a more sensitive unit.
                If you would like feedback on the PCB layout, I would fatten the traces to 35-100 thou as space permits, for anything leading in/out around the 10 ohm resistors and the ground traces. Copper is free on a PCB. But if you look at the original breadboarded ESR meter, it's not that critical. You have the wrong value for R10, it should be 25K not 24R. A 78L05 is enough to power this and a reverse-battery protection diode is good to include. I don't see a need for the massive 0.47uF/400V series cap- if you are testing with live DC present, and reverse the leads by accident there will be smoke, so I wouldn't do it.
                This is an interesting source: ESR Meter Repository
                Another popular ESR meter (Ludens) but it didn't perform unless modified, and I never quite finished the mods...
                • garry7263
                  • Feb 2013
                  • 105
                  Thank you for your input. I redrew the board layout and thickened the traces to .032. I rerouted a few things and tightened them up. I did leave the one trace that cuts through pins 6-7 at .024 for a tad more clearance, but still thicker than the original .016. The value for the one resistor should have been 24k, the original calls for 25k but that shouldn't be that critical. If it really makes a difference then I will have to run a 1k in series to make up the difference as the 24k was all I could find.
                  • garry7263
                    • Feb 2013
                    • 105
                    I believe the large cap is there to soak up the power just in case you accidentally test a charged capacitor, though that cap would be discharged through the resistor. I dont really plan on testing a charged cap to begin with.
                    I need this mostly to test electrolytic caps on a power supply, and maybe to help troubleshoot some other boards. If something is questionable, I would just replace it. Just not wanting to unsolder every component to test it. I don't have a scope. Go figure, the one thing my father never owned was a scope and he had worked as a electrical technician all his life for GE, and Eastman Kodak.
                    • Kiriakos GR
                      Banned
                      • May 2012
                      • 940
                      • Greece
                      In this case it is time for the son to do the big step ahead.
                      • garry7263
                        • Feb 2013
                        • 105
                        Don't know if I can afford to spend for a scope being out of work at the moment but I have been contemplating it when I get some cash flow. I have some PA amplifiers and other audio gear that needs some attention.
                        • redwire
                          • 3912
                          That pcb looks much better. If you are home etching the pcb, a jumper instead of the trace between pins 6-7 might be easier.
                          I find the zero-potentiometer is usually adjusted each time you use the meter, to null out test lead resistance, so it might be panel-mounted.
                          If you use Schottky meter-rectifier diodes, that helps the low-end sensitivity quite a bit (1.4V drop vs 0.6V). Use say 1N5817,18,19 instead of 1N4148's. They have fatter leads.
                            You can add an Emitter bypass cap in parallel with R12 (for the Amplifier Transistor T1) to get more gain, cap can be 0.47uf 25~50V Polyester type.
                            This is whatI built using 555:
                            http://s807.photobucket.com/user/bud...83297498167691
                            https://www.badcaps.net/forum/showth...highlight=acer
                            • garry7263
                              • Feb 2013
                              • 105
                              Could I solder the cap to the back? I can leave the leads a little bit longer on R12to solder to. Then possibly change values to adjust?
                              I could order a 50uA meter later if I really needed to.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                I might make something like this, but instead have an arduino monitor the rectified voltage, and display it on a screen. This way I will easily be able to see the slight differences in the ESR.
                                Muh-soggy-knee
                                • Mad_Professor
                                  A Mech Warrior
                                  • Feb 2011
                                  • 1587
                                  Hey, I have a spare atmega168 chip laying here, if you do proceed to build something like that, may I have a copy of that schematic and code, please?
                                  • magistertc
                                    • Feb 2006
                                    • 25
                                    @Garry:
                                    I built this a while back, used with a Simpson model 313 meter which has 100uA input. I increased R11 on the transistor to 3R3 and added 0.1uF cap parallel to R12. Substituted a 5K pot (instead of 25K) in series with the meter. Bought the IC, rest of the parts came from my spares bin. Resolution is good above 100uF and good enough down to 2uF to spot a high-ESR cap.
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Oh yeah, I'm not planning on making it proprietary
                                      Muh-soggy-knee
                                      • garry7263
                                        • Feb 2013
                                        • 105
                                        Here is the board layout I will go with. I added a few pads to place a cap parallel to R12 and enlarged all the pads. All the traces are .032 and in place of just one jumper I ran 2 short jumpers to keep it neat and away from the IC (instead of running the trace between 6 & 7).
                                        I will look to see if I have any 1N581x diodes, but this might be something I will have to substitute later, as well as finding a 50uA meter. I may try to find a smaller value variable resistor if I need to. I can play with the 10k resistor as well if needed. I am planning to use the transparency/iron on method to make the PCB, but may end up drawing it by hand if I need to. If I do draw it by hand I will mate a template for the tabs first by putting two layers of plastic tape on a printout of the PCB, then using sharpened brass tubing, make holes for the tabs and peel off the top as a template for the pads and then just draw the traces with sharpie and a ruler. Hope the transparency trick works because it will save a lot of time.
                                        I will get the transparencies this afternoon. I think I can fit 12 on one sheet so I will be able to play with heat a little and practice before making the final.
                                        I guess take plenty of pics and do a build on this thread as well for anyone interested in seeing the progress. Should go really quick once the PCB is etched.
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                        • jorpec
                                          Changing the scale of an analog meter
                                          by jorpec
                                          Hi
                                          I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                          I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                          by sam_sam_sam
                                          About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                          Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • ksysa
                                          Board Layout of iPad Pro 10.5 (Model : A1709)
                                          by ksysa
                                          Good day, everyone! Can anyone please share a board layout (complete with components, test points, etc.) of iPad Pro 10.5 (Model : A1709)? There is already a schematic diagram of iPad Pro 10.5 here but somehow it lacks the complete board layout. I need to know where the specific Test Points (TP) are on the motherboard. I hope someone can help me.
                                          07-16-2025, 02:36 AM
