Hi guys, i picked up sume junk a lot of time ago and i found a 2gb ddr2 memory module from the bin. It doesn't work. The problem is that there is a little ceramic capacitor missing on one side of the memory, and it can't be replaced because some shithead has tried replacing it with a soldering iron and pulled the contacts off the pcb.
I have an idea to fix this, but i am asking, that is it a good idea? My plan is to basicly remove everything from that side of the memory and have it work as a single sided 1gb stick. It should work, because i have seen a lot of single sided memory modules that have contacts on the other side to make it into a double sided memory, and i have even seen people do it, desolder all the chips from a memory module and then solder them on to the side of another identical memory module. My question is, that can i just "undo" this? Remove all the components from one side and still have it work?
The stick is an Adata AD2800002GOU DDR2 2G 800 2Gx16 - this means that it is a 2gb module divided into 16 chips, and i want to take it down to 8.
and i can just scratch off some of the coating to make a conection, but the positive goes through the module, but it is a very tiny conection on the other side, and scratching it would be VERY difficult. And i think why it doesn't work without a cap is that one of the chips is getting no power and due to that is reporting a problem, causing it not to work. And yes, i am going to try it
