Lenovo E14 replaced ddr4 memory module resulting in no boot
  • ongobongo
    • May 2023
    • 58
    I am still working on an Lenovo e14 AMD notebook with some problems. The laptop booted normally but had a ton of problems with the soldered ddr4 memory. I tried deactivating the memory via bios, but that didn't work.
    As i have a matching donor here, I decided to change the module i suspect to be faulty and exchange it with one of the donors.
    Did so, but now the laptop won't boot anymore.
    Anyone here who already did that and can comfirn, that exchangeing one module alone would work? Or do I need to exchange all 4 of them to make it work?
  • alexfts20
    • Jun 2023
    • 30
    • Kyrgyzstan
    ongobongo Could you please provide the model name from the board? For example, (NM-C771).
    • ongobongo
      • May 2023
      • 58
      sure, it is actually GE420/GE520 NM-C771 Rev: 1.0
      Both models use the exact same memory modules from Samsung: k4aag165wa-bcwe
      • Sephir0th
        • Oct 2020
        • 1283
        Sounds to me more like bad replacement part or part not correctly soldered. Or, the faulty Chip finally died because of the heat.
        FairRepair on YouTube
        • ongobongo
          • May 2023
          • 58
          Yah, that was is my thinking as well. This is the first time I had to deal with underfil and i could easily used too much heat to get rid of it.
          Just thouhgt I ask if this is kind of module change needs to be done for all of them or if one is just fine.
          • alexfts20
            • Jun 2023
            • 30
            • Kyrgyzstan
            ongobongo Try disabling the onboard RAM by moving the board ID resistors as shown in the attached photos:
            • Sephir0th
              • Oct 2020
              • 1283
              It is enough to replace the faulty chip(s).
              • ongobongo
                • May 2023
                • 58
                alexfts20, you my hero of the day. I had already looked at the memory configuration via resistors before, but as there was no option for deactiving the onboard memory, i didn't bother to dig any further. Now, with your feedback, I gave it a try and changed the config to one of the reserved ones (111) which actually disables the onboard modules :-)
                Thanks a million
                ongo
                • alexfts20
                  • Jun 2023
                  • 30
                  • Kyrgyzstan
                  ongobongo You’re welcome, ongo! I’m thrilled to hear that the solution worked and your problem is resolved. 😊
                  • eaf
                    • Aug 2020
                    • 5
                    Thanks a million
                    ongo
                    Hi ongobongo and alexfts20 , I have the same issue and I'm new here. could you explain a little what you did? thanks,
                    • ongobongo
                      • May 2023
                      • 58
                      This Board has 6 six positions for resistors (RC110-RC115) that define the internal board id and, with it, the type and size of on-board memory, see picture attached. Three of those 6 positions are populated with a 10K resistor each.
                      Depending on the combination of the populated resistors, you define a board id. If you have a similar board you will have one of the first six combination from the list attached. I changed my combination to one of the two "reserved" states.
                      To be more precise you need to make sure that the positions RC110, RC112 and RC114 are populated with a 10K resistor, while the others (RC111, RC113, RC115) are open and not populated.
                      Then you are in a reserved state that doesn't define any on-board memory. You must use a stick of memory to get it to boot.
                      • eaf
                        • Aug 2020
                        • 5
                        Thank you ongobongo. that's very helpful.
                        • eaf
                          • Aug 2020
                          • 5
                          Hello ongobongo, alexfts20 I finally followed this and fixed my E14. Thank you! you are my hero of the day
                          • Max029
                            Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                            by Max029
                            I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                            I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                            TY,
                            08-18-2024, 08:28 PM
                          • q2v5
                            Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                            by q2v5
                            Lenovo T480s
                            Model 20L8-S3TE00
                            Board ET481-U10
                            Chip MX25L12873F
                            Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                            2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                            The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                            08-15-2024, 10:40 PM
                          • keropi
                            Lenovo M92p TINY 3238 lost ability to boot after BIOS update
                            by keropi
                            Hello!
                            yesterday I received from eBay a Lenovo M92p TINY model 3238 system with 4GB of RAM and a 500GB mechanical HDD.
                            I tested it and it worked fine, it booted to a fresh Win10 x64 French OS .
                            The plan was to replace the mechanical HDD with an SDD one and upgrade RAM to the max 16GB since I had 2x 8GB SODIMM modules.
                            I noticed that there was an update on the Lenovo support site so I thought I'd do that first and then proceed with the upgrades and installation of new OS.
                            The windows BIOS update completed successfully and the system booted to a bios-like...
                            12-17-2021, 09:36 AM
                          • gsmtim
                            Lenovo X1 Yoga Gen5 Accidentally MEC1663 FW Erase Can't Boot
                            by gsmtim
                            Hi guy's anyOne Have full backup for Lenovo X1 Yoga Gen5 MEC1663 because i accidentally Erase the main FW and EEPRom. i only have backup the Main FW , but i try to Rewrite the 256MB and 288MB but the machine Can't boot, only Charging Indicator and 3blink to power button
                            Model # : Lenovo ThinkPad X1 Yoga Gen 5
                            Board # : GX4A0/GYG50 NM-C881 REV 1.0
                            Serial # : PF-2W2P5H
                            Type # :20UC-S1L21H
                            06-05-2025, 07:22 AM
                          • Paulaziz
                            Lenovo L13 Yoga Gen 2 won't boot
                            by Paulaziz
                            My Lenovo L13 Gen 2 was working perfectly until two days a when it refused to boot after previous used.
                            When I press the power button, the power led will lit and goes off immediately with the CPU fan concomitantly spinning for few seconds and then stop.
                            The reset button did not help to resolve the issue. I have also performed hard reset by:
                            1. Disconnected the battery
                            2. Unplug the adapter
                            3. Hold down the power button for 15sec. Then increased to 30sec, 45sec and finally to 1m.
                            4. Then plug the adapter.
                            Is it corrupt bios?​...
                            02-17-2025, 04:29 PM
