HP 840 G1 laptop wont start due to memory module issue
  • Kocane
    • Nov 2023
    • Denmark
    I have this EliteBook 840 G1 laptop that won't start - it blinks on the caps- and numlock buttons 3 times which indicate issue with the memory modules. On one of the memory slots of the motherboard, I can see some corrosion (?) and my guess is that it's creating a short. At first I figured I could just omit using this slot but it wont start either way - also tried other RAM sticks of course.
    I've tried to see if I could clean it up, but the laptop remains unbootable. Can it be because it has caused issue elsewhere or because it's still shorting in the memory module?
    This is how it looked before and this is how it looks after my attempt to clean it.
    Maybe I made it worse?
  • Sephir0th
    • Oct 2020
    • 1289
    Re: HP 840 G1 laptop wont start due to memory module issue
    You need better tools to a) visualize the problem and b) check yourself.
    From the second picture you shared, nobody can assume anything. With a multimeter you can perform simple checks, as Resistance to GND of the pins in question and Short circuit between the pins (in continuity mode). Then you could clarify which pins are affected exactly, since the module slots have all the same pinout (you can find out with random schematics of same RAM technology).
    We can not perform your own homework here. Something you need to do by yourself.
    FairRepair on YouTube
      Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
      by sam_sam_sam
      This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
      Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
      07-07-2024, 02:34 PM
    • Mirenia
      Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
      by Mirenia
      got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
      The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
      If this happened once, then the laptop only runs for a few minutes until restart.
      This happens regardless while staying in windows or uefi or in a linux environment.
      At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
      01-05-2025, 05:15 PM
    • yaya3gmax
      Laptop Power Issue – Works on Battery, Fails on Adapter Load
      by yaya3gmax
      Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
      Symptoms:
      • Laptop works normally on a pre-charged battery.
      • Battery does not charge when adapter is connected.
      • Without battery:
        • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
        • Speakers “pop” when power cut occurs indicating harsh sutdown.
        • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
      08-21-2025, 07:16 AM
      Microsoft Surface Laptop Surface Laptop Notebook Specification for Upgrade or Repair
      This specification for the Microsoft Surface Laptop Surface Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop boardview and Surface Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
      09-06-2024, 10:20 PM
    • ahmarzo
      Acer laptop battery draining issue
      by ahmarzo
      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
      08-02-2025, 06:39 AM
