2WIRE 3600hgv power suply
  • ravenor
    • Sep 2011
    • 27
    I was opening a 2WIRE power supply to check the voltages as the gateway wasn't too stable lately. However, after I opened, it wouldn't work at all. The 2WIRE would power on for a second or so and display a red power light and then turn off. I checked the voltages with a multimeter and the voltage would be about 6v when the light was on and almost 3v when the light was off. Any ideas as to what would cause this?
  • selldoor
    Slow Learner
    • 7870
    Re: 2WIRE 3600hgv power suply
    Check for cold joints and replace the two small caps with quality caps.
    VERY CAREFULLY check the voltage at the BIG CAP. Meter on DC600v
    Please update your profile with country and mains voltage.
    • ravenor
      • Sep 2011
      • 27
      I want to wait until I have a bigger list of capacitors to buy as the shipping costs for just two or three capacitors is a bit high compared to the price of the capacitors themselves. The voltage on the big cap fluctuates from 166.4v-167.4v. I can't tell if any of the joints are cold because it was made using leadless solder.
      • selldoor
        Slow Learner
        • 7870
        OK - let us know how it goes, Actually I have a similar PS to fix -I dont need it so never seem to get round to it.
        • ravenor
          • Sep 2011
          • 27
          Is there anything I can do or test without buying new equipment? What are the possible causes for this fluctuation. Also, when the voltage fluctuates, there's a tiny click from the power supply but I'm not sure where.
          • selldoor
            Slow Learner
            • 7870
            What fluctuation - voltage on the big cap or the 3 -6 on the output?
            • ravenor
              • Sep 2011
              • 27
              Actually, the fluctuation in the output coincides with the fluctuation on the big cap.
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                the psu uses the primary filter cap as storage of mains voltage when the psu try's to start the caps voltage will drop then return to the peak voltage of the mains supply.
                The output voltage fluctuation is a result of the psu trying to start.
                My pc
                CPU : AMD PHENOM II x4 @ 3.5Ghz
                MB : ASUS M4A89TD PRO USB3
                RAM : Kingston ValueRAM 16gb DDR3
                PSU : Cooler Master 850W Silent Pro
                GPU : ATI Radeon HD 6850
                • ravenor
                  • Sep 2011
                  • 27
                  What would cause the psu to be unable to start?
                  • redwire
                    • 3912
                    Does it put out the correct (12V?) with no load? It's normal to see a volt or two fluctuation on the input filter cap, as powerline voltage moves up and down.
                    Check the bridge rectifier, I've seen an open diode make a power supply weak and go into UVLO (under-voltage shutdown) when loaded down. The bridge is on the heatsink, with 4 diodes to test.
                    Otherwise I've seen bad capacitors (the smaller ones) cause a supply to go unstable. Some of the solder joints look poor and I would touch them up too.
                    • ravenor
                      • Sep 2011
                      • 27
                      It outputs about 11.5v-12v with no load. How would I check the bridge rectifier? Sorry, I'm pretty new to this. What solder joints would you recommend I reflow?
                      • selldoor
                        Slow Learner
                        • 7870
                        As you are getting fully rectified voltage at the Big Cap it is unlikely to be a problem with the Bridge rectifier - they tend to work or not work.
                        Have you tried the supply on anything else - could it be a fault on the 3600hgv. A 12v car sidelamp is handy to have for testing.
                        • ravenor
                          • Sep 2011
                          • 27
                          Actually, the 3600hgv works fine with another 12v power supply.
                          • jetadm123
                            • 2169
                            I almost willing to bet my lunch money it's one of the two filter caps (green and black ones on the right side) has gone bad. Is one of them a 1000uf 10v cap?
                            • ravenor
                              • Sep 2011
                              • 27
                              Well, the blue one is a Taicon 1000uf 25v cap while the black one is a 330uf 25v Ltec.
                              • ravenor
                                • Sep 2011
                                • 27
                                Is the 1000uf cap likely to fail?
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  05-29-2024, 02:01 PM
                                • lapfix
                                  HP OMEN NO power no light
                                  by lapfix
                                  HP OMEN : DAG35DMBAD0
                                  NO power ,no short ,no corrusion
                                  Consumption : when charger plg in = 0.004 amp
                                  Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                                  when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                                  No light at power button led
                                  All coils resistances :
                                  Pl 2001 =3v measured with kohm.
                                  pl 2004 = 5v measured with kohm
                                  pl 6001 = 49.7ohm
                                  pl 4012 = vccsa = 24.4 ohm
                                  pl 3001 =...
                                  11-03-2025, 07:48 AM
                                • ipatch
                                  troubleshooting microsoft surface pro 4 no power no led charge light
                                  by ipatch
                                  hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                  10-05-2023, 11:59 AM
                                • russpall
                                  LG 39ln540v - red light flashes twice, no power to LED driver?
                                  by russpall
                                  Hi there,
                                  I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                  The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                  08-27-2024, 01:07 PM
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
