I was opening a 2WIRE power supply to check the voltages as the gateway wasn't too stable lately. However, after I opened, it wouldn't work at all. The 2WIRE would power on for a second or so and display a red power light and then turn off. I checked the voltages with a multimeter and the voltage would be about 6v when the light was on and almost 3v when the light was off. Any ideas as to what would cause this?
2WIRE 3600hgv power suply
Re: 2WIRE 3600hgv power suply
Check for cold joints and replace the two small caps with quality caps.
VERY CAREFULLY check the voltage at the BIG CAP. Meter on DC600v
Please update your profile with country and mains voltage.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
I want to wait until I have a bigger list of capacitors to buy as the shipping costs for just two or three capacitors is a bit high compared to the price of the capacitors themselves. The voltage on the big cap fluctuates from 166.4v-167.4v. I can't tell if any of the joints are cold because it was made using leadless solder.Comment
OK - let us know how it goes, Actually I have a similar PS to fix -I dont need it so never seem to get round to it.
http://www.badcaps.net/forum/showthread.php?t=39740Comment
What fluctuation - voltage on the big cap or the 3 -6 on the output?Please upload pictures using attachment function when ask for help on the repair
the psu uses the primary filter cap as storage of mains voltage when the psu try's to start the caps voltage will drop then return to the peak voltage of the mains supply.
The output voltage fluctuation is a result of the psu trying to start.My pc
CPU : AMD PHENOM II x4 @ 3.5Ghz
MB : ASUS M4A89TD PRO USB3
RAM : Kingston ValueRAM 16gb DDR3
PSU : Cooler Master 850W Silent Pro
GPU : ATI Radeon HD 6850Comment
Does it put out the correct (12V?) with no load? It's normal to see a volt or two fluctuation on the input filter cap, as powerline voltage moves up and down.
Check the bridge rectifier, I've seen an open diode make a power supply weak and go into UVLO (under-voltage shutdown) when loaded down. The bridge is on the heatsink, with 4 diodes to test.
Otherwise I've seen bad capacitors (the smaller ones) cause a supply to go unstable. Some of the solder joints look poor and I would touch them up too.Comment
As you are getting fully rectified voltage at the Big Cap it is unlikely to be a problem with the Bridge rectifier - they tend to work or not work.
Have you tried the supply on anything else - could it be a fault on the 3600hgv. A 12v car sidelamp is handy to have for testing.Please upload pictures using attachment function when ask for help on the repair
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by ipatchhello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
by russpallHi there,
I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
...2 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samSee pictures for type of laptop computer
I checked switching power supply brick 19.2 volts multi meter only
No booting without switching power supply connected
Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
What the heck is going on here...-
- Loading...
