Safe to replace G-Luxon HM with Panasonic TS-ED
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    A friend of mine got me to look at a 42inch lcd tv of his.
    It has no power, Main fuse was gone found the source of the short that was a MOSFET in the APFC circuit.
    This set has G-luxon everywhere so I put my capacitance meter on the cap after the APFC which is G-Luxon HM 180uf 450v General purpose cap with 2nf of capacity .
    And my question is can I replace the
    G-Luxon HM 180uF 450v 25x35 0.85 rc At 120HZ Actual size is
    With
    Panasonic TS-ED 220uF 450v 30x35 1.42 rc 0.603 ESR At 120HZ 0.271 At 10khz
    hope the Panasonic is not too tall.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • Blargh523
    • Dec 2012
    • 46
    Re: Safe to replace G-Luxon HM with Panasonic TS-ED
    The caps you listed look like they're the same height, but the Panasonic is fatter, which may or may not be a concern depending on where it has to fit.
    Panasonic has TS-ED 180uF 450V in two sizes:
    EET-ED2W181CA is 25mm x 40mm
    EET-ED2W181BA is 22mm x 50mm
    (part numbers are is for the Low ESR version)
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      The cap I am planing on using is EETED2W221DA (EET-ED2W221DA)
      My pc
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
        11-20-2024, 08:52 PM
      • AquaMan Ua
        by AquaMan Ua
        05-17-2025, 09:40 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • aa10aa10
        Panasonic Toughbook CF-33 mk1 BIOS repair
        by aa10aa10
        Good day,
        I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
        I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
        01-21-2025, 06:13 AM
