Safe to replace G-Luxon HM with Panasonic TS-ED
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    A friend of mine got me to look at a 42inch lcd tv of his.
    It has no power, Main fuse was gone found the source of the short that was a MOSFET in the APFC circuit.
    This set has G-luxon everywhere so I put my capacitance meter on the cap after the APFC which is G-Luxon HM 180uf 450v General purpose cap with 2nf of capacity .
    And my question is can I replace the
    G-Luxon HM 180uF 450v 25x35 0.85 rc At 120HZ Actual size is
    With
    Panasonic TS-ED 220uF 450v 30x35 1.42 rc 0.603 ESR At 120HZ 0.271 At 10khz
    hope the Panasonic is not too tall.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • Blargh523
    • Dec 2012
    • 46
    Re: Safe to replace G-Luxon HM with Panasonic TS-ED
    The caps you listed look like they're the same height, but the Panasonic is fatter, which may or may not be a concern depending on where it has to fit.
    Panasonic has TS-ED 180uF 450V in two sizes:
    EET-ED2W181CA is 25mm x 40mm
    EET-ED2W181BA is 22mm x 50mm
    (part numbers are is for the Low ESR version)
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      The cap I am planing on using is EETED2W221DA (EET-ED2W221DA)
      My pc
      • Andre Gilbert
        by Andre Gilbert
        11-20-2024, 08:52 PM
      • AquaMan Ua
        Problem with PANASONIC CF53 laptop after changing BIOS settings
        by AquaMan Ua
        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
        05-17-2025, 09:40 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        I happened several times, in the search for help from the web, to consult this very interesting forum.
        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
        Having said that I come to the gist of my post on the forum as the title suggests.
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • aa10aa10
        Panasonic Toughbook CF-33 mk1 BIOS repair
        by aa10aa10
        Good day,
        I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
        I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
        01-21-2025, 06:13 AM
      • Mnawar27
        Panasonic CF-H2AU24EF3 bios locked
        by Mnawar27
        Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
        I need help to remove it,
        thankyou all.
        SN; 2FKCA26876...
        11-16-2024, 08:00 AM
