CAPACITOR EXPLODED on RCA VCR VR501
  • lemite
    • Nov 2012
    • 4
    • Philippines
    Does anybody knows what is the value of C4 of the power supply module of RCA VCR Model number VR501? This unit was plugged to 220VAC and the big capacitor exploded.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: CAPACITOR EXPLODED on RCA VCR VR501
    Looks like C4 was what went off in there It'd be pretty hard to tell...that cap evaporated.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      I'd guess 330 or 470 microfarads 400 volt.. But it's only a guess. It will probably work with a 470 to be safe but I think the 330 probably will work too.
      I'm only guessing based on the facts:
      this appears to be a switching power supply
      this appears to be the mains filter capacitor
      only one mains capacitor
      220VAC
      estimate around 100 W PSU
      Does not look like like a heavy duty power supply like a PC
      not a tiny supply like a phone charger
      But this is merely a guess...
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        WOW!!!
        Woo, exploded capacitor carnage porn!
        I would say that it is an 82uF 400v cap, or maybe 100uF 400v.
        Check the bridge rectifier for shorts, and also the fuse will need replacing.
        Did you find the covering of the capacitor? that may give us a clue to it's ratings.
        Looks like ther was something blocking the top vent of it, and it just built up pressure. Must have been very loud!!!
        Muh-soggy-knee
        • lemite
          • Nov 2012
          • 4
          • Philippines
          Originally posted by ben7
          WOW!!!
          Looks like there was something blocking the top vent of it, and it just built up pressure. Must have been very loud!!!
          I forgot to inform everybody that this unit for 110volts AC was plugged to 220VAC. Yes indeed, it was a very loud explosion! Somebody forgot to use step-up transformer. Unfortunately, the covering was totally unrecognizable.
          • mariushm
            • May 2011
            • 3799
            The fuse seems to be gone as well.
            If it blew up from plugging at 220v, then the capacitor was probably only rated for 180-250v
            Based on the size of it, I would guess 200-330uF
            • smason
              • 1652
              Blowed up real good!
              • larrymoencurly
                • Oct 2004
                • 960
                In my old Panasonic VCR, designed for 120VAC, it was 120uF, 200V.
                • japlytic
                  • Oct 2005
                  • 2086
                  It took a fair amount of energy for this to happen... and a client of mine connected a 120VAC JVC AM/FM tuner to 240VAC - causing the primary of the power transformer to fail, but in this case, it did not damage anything outside the power supply board.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    I bet you that the vent was too close to the lid of the PSU, and it couldn't vent. So it exploded
                    Try a 120uF 200v cap in there, replace fuse, and see what happens
                    Muh-soggy-knee
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      being that this is a panasonic built unit the 120@200v is spot on.
                      so did c4 contain c4?
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Looks like it did
                        • MORETTIGIAN
                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                          by MORETTIGIAN
                          Title:
                          Description:
                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                          Procedure performed:
                          - Removed backplate
                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                          - Reapplied thermal compound
                          - Reassembled card
                          Observed behavior after reassembly:
                          - GPU powers on and operates normally under...
                          09-18-2025, 12:14 PM
                        • Agent24
                          Dick Smith Q-1760 linear power supply filter capacitor question
                          by Agent24
                          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                          It has at least one problem.
                          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                          I have already ordered a replacement potentiometer, so that's not an issue.
                          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                          All are CapXon...
                          10-21-2025, 05:39 PM
                        • chth96
                          What capacitor should I purchase for Power Supply of obsolete game consoles?
                          by chth96
                          hello.
                          I have Sega Saturn and 5 years ago, I recapped all of capacitor in the Power supply, Because At that time, It frequently freezed black screen after SEGA logo displayed.
                          It hardly ever freezed after I finished to recap all of caps in the power supply.
                          But Yesterday, It did not show any screen at all and its green power LED constantly blinked.
                          To my surprise I found that all of two NXH 10v 2200uf capacitors in the secondary area of Power supply have been bulged and It measured 57 mF and 75 mF capacitance.
                          It seems that quality...
                          10-01-2024, 08:14 AM
                        • r2digital
                          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                          by r2digital
                          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                          04-18-2024, 03:50 PM
