newbie needs help with crystal oscillator broken
  • herita
    • Aug 2012
    • 17
    • France
    Hi everybody,
    Since i'm still a newbie in electronics and in our forum, i beg you pardon if i post a dummy question.
    recently, i have broken one crystal oscillator on one toshiba mainbroad : the 14.3hz but when i have soldered it physically, i can't get my mainbroad work again.
    So i ask you guys if there is any way i can test this thing to know if it still works or not ?
    Thank you
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: newbie needs help with crystal oscillator broken
    Are you saying you had one crystal which broke and you took it out and replaced it with a new one?
    If not can you re phrase what you are saying.
    How did you know the old one was broken?
    • Koda
      • Aug 2011
      • 317
      • Macedonia
      He's probably saying he broke/knocked off the crystal. Maybe the board traces are damaged of if the mobo was operating at the time maybe working without the crystal damaged another component or the new piece is not soldered correctly.
      Guns don't solve problems. I'll take 12
      • Duncanbest
        • Jul 2012
        • 81
        • Taiwan
        14.3HZ ??? WOW ! low frequency .....
          14.3HZ! No way. What number did you use to order the new one?
          I.E.
          • Jack Crow
            It's a CLASOB!
            • May 2008
            • 823
            Guys,
            His English is much better than my French.
            Be kind here.
            The French were nice to me even though I lacked the most basic language skills when the wife and I got to see Paris.
            Herita,
            Hi there.
            Couple of things.
            Those are fairly modern xtals.
            Might be able to find one on a similar scrap board.
            You might have to look long and hard to find one in a parts book.
            Used parts are quick and best of all cheap.
            Soldering them takes some work, so practice on the scrap board first with parts you do not care about. There are guys here who can give you details on what you need to un solder such a part.
            How to check if they are working?
            Do you have a portable short wave radio handy?
            Tune it to 14.3 mHz.
            Set the portable radio to tune in SSB mode.
            Turn on the circuit and you should hear something in the radio.
            A steady tone most likely. Adjust the tune on the radio, some of these xtals are better than others. If you do not get a tone, or have to tune more than 50khz out, then suspect the xtal of being bad.
            Most are within a few HZ of what is printed on the top.
            Tap the xtal case with a metal test probe.
            The signal on the receiver should change level (up) and most likely frequency (tone shift in an ssb receiver). Since with a metal tool your giving the xtal a little bit of antenna for signal radiating off the case, and loading it down will cause a frequency shift of the oscillator.
            I use a Sony 7600 shortwave radio for xtal spotting. Works great.
            Give that a try.
            Have fun
            Jack Crow
            Herndon Virginia USA
            "You are, what you do, when it counts"
            The Masso
            "Gravity, the quickest way down"
            Mayor John Almafi
            "You ever drop an egg, and on the floor you see it break?
            You go and get a mop so you can clean up your mistake.
            But did you ever stop to ponder why we know it's true?
            If you drop a broken egg you will not get an egg that's new?"
            MC Hawking
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              it probably 14.31818 mhz.
              • herita
                • Aug 2012
                • 17
                • France
                hi, thank you all for replies, sorry for my bad english (- omg, i hadn't thought that i did so much english mistakes) , and i guess you have had a nice holiday in Paris, Jack Crow
                uhm, yep, it is proably 14.31818 mhz, i think i have messed up a litle bit, thank you guys for corrections.
                ok then, i will try with a short wave radio which can be used in a single side mode, the one that i belive can be found in my closet
                but there is no kind of mutilmeter or multitester can check this xtals more quickly (i think that xtals can be tested with oscillator, right ?)
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  No - it needs special equipment or an oscilloscope.
                  They are fairly cheap to buy so most usually just replace.
                  Google - "how to test a crystal oscillator"
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    i did that very same test a while back at a friends place in ky.
                    it was a custom made card in a one off cnc.ttl osc was suspected to be dead.
                    used the ic-7000 in my workvan to verify.it was just above the low end of 15m.
                    lucky guy had extras from the design of the unit.yep it is a prototype.
                    • herita
                      • Aug 2012
                      • 17
                      • France
                      cool, you guys have a lot of experiences,
                      i have just googled and found people tried to make some interesting tester stuff:
                      and i got from google also this:
                      http://www.ehow.com/how_8728348_test...cillators.html
                      but, i dont think the guy on ehow.com told us the true story ....
                      • Jack Crow
                        It's a CLASOB!
                        • May 2008
                        • 823
                        H,
                        The idea is to 'read' the xtal in operation w/o loading it.
                        a scope probe offers some number of pF to ground, with a low level xtal oscillator that might be enough to pull the xtal off frequency or shut it down. If your reading the RF signal that comes off the case, no loading.
                        Keep it warm
                        Jack Crow
                        The Masso
                        Mayor John Almafi
                        MC Hawking
                        • Keshenatech1
                          Question on microprocessor crystal oscillator circuit
                          by Keshenatech1
                          I'm troubleshooting a reel controller board for an IGT slot machine. The digital section seems to be dead. There is no USB communication, PC or utility program for flashing firmware do not see it but they do see good/working boards. I noticed the waveform on the crystal is very erratic/asymmetrical/glitchy on the bad one compared to the nice even waveform on a good board. My question is would this most likely be caused by a bad crystal or something gone bad in the circuit loading it down? I'm attaching a couple pictures of my scope probing the good and bad boads.
                          02-26-2024, 11:05 AM
                        • pc_okay
                          Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
                          by pc_okay
                          Hello friends,
                          Its been a while, i wish you an happy new year 2025 !
                          I have this laptop doesn't start, power light up a second when pluging USB-C charger.
                          Laptop take 0.11A.
                          All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
                          I get no oscilation on XTAL 32.768 KHZ
                          Battery is not charging but charging led is here.
                          PCH heat at 30° approximatively. (with no heatsink)
                          I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
                          It's a 2 pins Crystal.
                          01-13-2025, 09:26 AM
                        • chth96
                          Is it possible bridging tiny broken trace
                          by chth96
                          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                          cutting tiny trace.
                          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                          12-03-2022, 11:32 PM
                        • Christos Tsiligiannis
                          Marian Trace Alpha sound card repair help
                          by Christos Tsiligiannis
                          Hello to the forum.
                          My name is Christos, I am new to the forum here and i am posting from Greece.
                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                          11-18-2024, 05:26 AM
                        • olane
                          Steam Deck Crystal Oscillator replacement part
                          by olane
                          Hi just wondering if anyone knew the part ID for the crystal Oscillator on the Steam Deck i've attached an image of the broken part on my board.
                          Thanks...
                          02-02-2024, 12:56 PM
