TAICON Main filtering cap LCD PSU
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    I got a VP211B monitor, completely dead. I took it apart and it has all nichicon PW wet lytic caps on PSU and and dry lytics on the signal board except for the main filtering cap. It's bulged on the vent and the cathode lead is pushed out. It's got some sort of yellow paper tape stuck on the cap, it's hard to remove. I managed to scrap enough of it away to see it's a 400v 150uf cap but I don't know what series it is.
    What cap should I replace it with?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: TAICON Main filtering cap LCD PSU
    Wow it almost exploded out the top and bottom! :O
    You need to give us the dimensions of it so we can find a good replacement.
    Muh-soggy-knee
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Yeah the bottom cap feels like cardboard/paper. Use high quality caps then plan obsolesce with cheap main cap. The only thing I'm worry about is this monitor is 8-10 years old, hasn't function in over 2 years. I'm wondering if those nichicon caps fall in the overfill years.
      AWWW SHAZBOT! I can't believe I forgot that.
      It looks like 7.5mm lead spacing, 35mm height and 18.5mm diameter.
      • c_hegge
        • Sep 2009
        • 5219
        If the Nichicons are PW series, then no, they didn't. PW were never affected. It was only HM and HN
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Yeah the bottom cap feels like cardboard/paper. Use high quality caps then plan obsolesce with cheap main cap. The only thing I'm worry about is this monitor is 8-10 years old. I'm wondering if those nichicon caps fall in the overfill years.
          NCC KXG 400v 150uF
          It will be about 5mm longer, but it should fit.
          Muh-soggy-knee
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            NCC KXG 400v 150uF
            40mm? It's going to sit on that small green cap and it may or may not hit the metal housing.
            • mariushm
              • May 2011
              • 3799
              I think you should be fine with 120uF there, in which case this will work:
              http://www.digikey.com/product-detai...377-ND/3134333
              http://www.newark.com/rubycon/450qxw...50v/dp/39T8969
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                Are you sure?
                I don't want this thing randomly powering off, or malfunctioning.
                But I don't think I have a choice.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  You might be able to fit the 40mm one by bending the leads closer to the bung.
                  Muh-soggy-knee
                  • Mad_Professor
                    A Mech Warrior
                    • Feb 2011
                    • 1587
                    Actually I'll buy both, the guy has two of these monitors, so it most likely the other one has died in a similar fashion.
                    • Mad_Professor
                      A Mech Warrior
                      • Feb 2011
                      • 1587
                      Well I got both, tried the rubycon first, no-go, then tried nichicon, no-go either.
                      Check the output only getting 4.2v, the board says I should be getting 18v.
                      So not sure what's wrong.
                      any ideas?
                      • Mad_Professor
                        A Mech Warrior
                        • Feb 2011
                        • 1587
                        Ok, so I've been searching the archives and came across this.
                        https://www.badcaps.net/forum/showpo...99&postcount=5
                        The problem is I have FC and FM caps which one to use to replace the nichicon PW cap? Or should I order another PW?
                        I think someone on here told me, it didn't matter for caps this small, but I want to be sure.
                        • PeteS in CA
                          • Aug 2005
                          • 3581
                          • USA, Unsure of Planet
                          FC and PW are pretty much direct crosses (and with UCC's LXZ).
                          PeteS in CA
                          • Mad_Professor
                            A Mech Warrior
                            • Feb 2011
                            • 1587
                            Well I finally got around to replacing c11 with a FC cap, but no-go, still 4.2v. If you remove power connection from signal board, it goes up to 17.7v.
                            On the board,
                            NEW:
                            Nichicon 400V 150uf KXG cap
                            22uf 50v FC cap.
                            Still on board:
                            TWO Nichicon PW 47uf 50v D:6xH:12 or 5x11 3.5mm holes
                            TWO Nichicon PW 680uf 25v D:12.5xH:15 most likely 5mm holes.
                            In another thread in the archives...
                            https://www.badcaps.net/forum/showpo...0&postcount=59
                            Plainbill said to replace the two Ltec caps, on this board they are PW, but the designs are identical including cap specs. Are the PW bad as in dried out? Unit was manufacturer in FEB of 2005. Or is something else going on?
                            I wish I had an ESR and capacitance meters right about now.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Given how much heat discolouration there is on the PCB, I wouldn't be surprised at all if the caps were dried out.
                              • selldoor
                                Slow Learner
                                • 7870
                                Off topic C hegge - see this? https://www.badcaps.net/forum/showth...066#post258066
                                • Mad_Professor
                                  A Mech Warrior
                                  • Feb 2011
                                  • 1587
                                  Recapped the board, and the monitor lives once again.
                                  When I pulled the 680uf PW caps they felt light, I picked up the new ones and they were a bit heavier.
                                  I don't know if you can tell bad ones from good ones just form weight, but I thought it was interesting.
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Even GOOD caps WILL go bad if subject to enough heat!
                                    Muh-soggy-knee
                                      Some time they dried out so bad , you can hear rattle when you shake it.
                                      • cheeky2
                                        by cheeky2
                                        05-25-2024, 03:27 AM
                                      • Dani_2024
                                        by Dani_2024
                                        10-28-2024, 05:06 PM
                                        HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio ProDesk 400 i5-6500 Specification for Upgrade or Repair
                                        This specification for the HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio boardview and ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                        09-12-2024, 03:28 PM
                                      • ygorsan
                                        by ygorsan
                                        🧩 Problem Summary:
                                        • I
                                        07-28-2025, 08:34 AM
                                      • Asraf Atb
                                        by Asraf Atb
                                        01-27-2025, 05:02 PM
