Do these motor brushes need replaced?
+ More Options
Posts
  • juergenb
    Nescafe Aeroccino, still fails with new Motor (red flashes only once)
    by juergenb
    i am asking for some Help.
    I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
    The Motor didnยดt start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
    So i got a few of these from Banggood.
    I swapped the motor and now i have a new fault condition.
    In a working Frother you would press the start button, it will light red and work for a few minutes.
    If you press longer it will light blue and just mixup the milk.
    With the new Motor it just starts...
    03-23-2021, 11:24 AM
  • Per Hansson
    Motor run capacitor physical size vs voltage rating & measurements?
    by Per Hansson
    (TL;DR skip the first paragraph)
    I encountered my first dead motor run capacitor at a customer this week.
    For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
    (Unless a servo motor makes more sense that is).
    But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
    The pump would run but sometimes trip the 10A breaker.
    I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
    Then it could...
    09-20-2020, 06:32 AM
  • mikey5791
    Help identify this motor
    by mikey5791
    Hi all forum members,
    Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
    Correct me if i am wrong on the initial test.
    Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
    11-24-2023, 07:54 PM
  • notallbad
    Rockworth breaker burning out motor
    by notallbad
    Got given this breaker to fix, armature had failed so replaced and the same thing happened.
    Its a 240v heavy duty breaker as opposed to site 110v.
    The 1st armature was bought from aliexpress and advertised as 240v but burnt out within 2 minutes light use taking the 13amp fuse with it and the 2nd bought from ebay (german seller) started to get very hot and begin to smoke so hopefully saved it by shutting it off quick at the first sign of smoke but have now tested the x2 safety cap and its not reading 0.22uf, much lower.
    Theres very little to it really on the...
    08-16-2024, 04:46 AM
  • cjard
    A motor controller is a power supply, right?
    by cjard
    Hoping someone here will be able to provide a few pointers with this. I've got a motor controller board for a device that moves a caravan. A DC motor on each wheel is supplied with 12v DC or -12V DC depending on whether the remote control is pushed in "forward" or "backward" mode. The control is arranged by having 2 relays per motor that, at rest, are all connected to the negative.. If the motor is to go forwards, then relay 1 activates meaning the motor sees "positive negative" on its terminals 1 and 2. If the motor is to go backwards then relay 2 activates meaning...
    10-14-2020, 01:24 PM
