smoothing out voltage spikes and dips?
  • scampo77
    • 233
    #141
    Re: smoothing out voltage spikes and dips?
    The relay locked closed. So now when I am driving at night I have to put my hat on the dashboard cause it is so bright, it will not go into dot mode.
      OK, it is the relay failure not the IC failure, thanks. By the way, can we see the pictures of this finished project? I thought you had given up since we were having so much problem during the prototype wiring, and did you have to change any component values on my circuit?
        • 31047
        you dont need to go digging into the headlight wiring,
        you can use the GI (general ilumination) wire on the dashboard lights.
        you can also get this from the light on the cigarette lighter socket.
        • scampo77
          • 233
          #144
          I am having problems with this light design.
          I tried putting 10k ohm resistor from vcc to pin 9. It will not activate the circuit. if I reduce the resistor all the way down to 1k ohm them it activates the circuit. when I try to energize the transistor the power supply gets hot and it starts smoking.
          Any ideas?
            Can you draw up to show how you have it hooked up, pictures also?
            • scampo77
              • 233
              #146
              the far left pin is connected to ground on the other side of the board.
              transistor used is a 2N 3904
              the other side of the 1000 ohm resistor is attached to the same 10v VCC that all of the LEDS are attached to.
              • scampo77
                • 233
                #147
                Guys don't bust your brain, I wired in a relay again. This time I ran it to an external female socket so I can just pop an automotive bosch relay if it ever fails again. I would be shocked if it fails again this one is a monster rated at 40A
                  The Collector connection does not look right at all. Can we see the whole board? I see on the IC has pin 9 connected the VCC pin3, the second IC i do not see how you get the voltage to VCC pin3 of the second IC. Do you have the diagram of this circuit with two ICs?
                  Where is it on this board layout that you provided has that new transistor and resistor connected to?
                  I think I see hwy it smoked.
                  BTW, the second IC on the bottom corner orientation of pin 1 looks wrong to me.
                    The regulator feedback network resistors for this LM317 are also not right.
                    Looks to be lots of error on the board layout.
                    • scampo77
                      • 233
                      #150
                      Please bear with me, this was my first attempt at a circuit board. there was a lot of solder bridges and bits of wire soldered in place to make things work properly. I do have 10.00VDC for my VCC and both gauges are/were working. I will get some photos up soon of the actual board but right now it looks like a train wreck of wire and copper and solder.
                      I think the external relay was the way to go, I only need to take 2 light gauge wires out of the board. the ground and the 12v headlight signal can come from some other place. it seems like an acceptable repair and it is much more serviceable., I just wanted to be able to figure out how to use a transistor, it didn't happen this time.
                      when I layed out the IC (the bottom one) I didn't realize I had it completely upside down. so that has all been changed, I will see if I can find the pdf layout I actually made and post it.
                      I will get some photos up as soon as I can
                      • scampo77
                        • 233
                        #151
                        If you need a clearer picture of a more specific area let me know or if you need explanation or voltage measurements.
                        • scampo77
                          • 233
                          #152
                          Here is a more accurate update.
                          I am not saying this is 100% but it is close, I am speeding through trying to get you guys info.
                          • scampo77
                            • 233
                            #153
                            Here is a photo of the dash back together. It looks pretty good!!
                              The collector of the transistor should be connected to pin 9, I cannot tell from the picture as to what it is connected to. I looks like it is connected to the same pad with orange wire connected to also.
                              • harp
                                high voltage high resistance marking resistor
                                by harp
                                Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                                08-26-2024, 01:42 PM
                              • jinu_j
                                by jinu_j
                                Hi
                                05-03-2025, 10:51 PM
                              • mikey5791
                                Need help to replace burned resistor in 350w atx psu
                                by mikey5791
                                Hi to all forum members,
                                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                12-26-2024, 04:55 AM
                              • Fernon@Repair
                                Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                by Fernon@Repair
                                i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                VCCIO voltage ok
                                VCCSA Voltage OK
                                VCCPLL Voltage OK
                                Ram Voltage ok
                                RamVTT OK
                                VPP 2.5 OK
                                But No Core Voltage
                                and i want to this vrm ic datasheet or pinout (ISL69269)
                                anyone have this ic pinout voltages?...
                                06-25-2025, 07:19 AM
                              • MidnightRoller
                                Can a resistor lose resistance after hot air?
                                by MidnightRoller
                                I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                02-02-2022, 11:46 PM
