smoothing out voltage spikes and dips?
+ More Options
Posts
  • harp
    high voltage high resistance marking resistor
    by harp
    Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
    08-26-2024, 01:42 PM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • mikey5791
    by mikey5791
    Hi to all forum members,
    12-26-2024, 04:55 AM
  • MidnightRoller
    Can a resistor lose resistance after hot air?
    by MidnightRoller
    I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
    I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
    02-02-2022, 11:46 PM
  • Fernon@Repair
    Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
    by Fernon@Repair
    i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
    VCCIO voltage ok
    VCCSA Voltage OK
    VCCPLL Voltage OK
    Ram Voltage ok
    RamVTT OK
    VPP 2.5 OK
    But No Core Voltage
    and i want to this vrm ic datasheet or pinout (ISL69269)
    anyone have this ic pinout voltages?...
    06-25-2025, 07:19 AM
