smoothing out voltage spikes and dips?
  • scampo77
    • 233
    Re: smoothing out voltage spikes and dips?
    before this gets to far along it needs to be said that i will need to build a second one of these things that operates identically to the first. i was hoping to steal ref voltages and power supply voltages,
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      I added a transistor into the circuit to amplify the Vref current capability, and added a diode so C3 won't discharge through the potentiometer.
      R3 is what discharges the capacitor, but the capacitor still could charge up almost right away, so it only solves half of the problem.
      I don't know if there should be a resistor to limit the base current on Q1, but I am thinking you could use a 2N3904 as Q1.
      The voltage across the potentiometer equals Vref-Q1vbe (I think)
      Could someone point out if I am going in the right direction or not?
      Muh-soggy-knee
      • scampo77
        • 233
        i have worked on this and to no avail. i am slowly adding caps and changing things but im still not 100% clear what i should be changing and doing.
        the diode?
        the 9.35v?
        do i change all my resistor values to match up with Ben7's diagram even though i cant change the 100 ohm float?
        i have re done my schematic (please be kind its my first time) it is easier to see what i have done and what i was thinking, with the colors.
        • scampo77
          • 233
          is this new diagram based on me keeping the Rsensor as a 0-100ohm float? and it is empty (one bulb lit up) at 5 ohm? and full (all 10 bulbs) at 85 ohm?
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Yes it is based on the 100ohm potentiometer. it should be like this: 1 bar-10ohm, 2 bar-20ohm, etc... the display is a 10 bar display so the readout shows approx. 10ohm per bar
            D1-D3 can be 1N4148, 1N4001, etc... just any regular diode
            D1 drops about 0.65v from the 10v source, making roughly 9.35v, that connects to the Vdd of the LM3914. The 9.35v is smoothed out by filter cap C2.
            For C3, use a 100uF capacitor, and for R3, use a 10k resistor, and see how it works.
            Muh-soggy-knee
              Hi Ben, what is the calculated Vref? 6V?
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Yeah, its still ~6v. I haven't changed the values of R1 and R2 yet
                Muh-soggy-knee
                  The transistor is hooked up as an Emitter follower, that means the Ib will be about 60mA if it does not have Base current limiter, just think of the Vref of the IC is a 6V regulator, if you have the Base connected directly to the out put of the regulator, the E-B junction and the 100 Ohms pot will be the load.
                  The pot that he is using based on the way his diagram is drawn, it looks like 2-pin pot, if that is the case, it means that the load will be varying from 0 ohm to 100 Ohms if it is not the 3-pin pot that allow you to tap the output at the wiper.
                  I am still not convinced on the accuracy of his wiring diagram to the actual unit.
                  • ReverendJones
                    Resurgam
                    • May 2010
                    • 49
                    #29
                    I would like to point out that the 100 ohm sender used is also the value used in a lot of automobile fuel tanks.
                    Gauges of this style are available from $10 - http://www.ebay.com/itm/200773320938
                    There are also plenty of circuits on the net showing how to use a LM3914 with a 100 ohm sender for a fuel gauge. The one below includes trimmers for setting the high & low readings.
                    Machina improba! Vel mihi ede potum vel mihi redde nummos meos!
                      It does not make sense to have PIN2 (Ground) IC tied to B+ with 180 Ohms 5W resistor (wasted power, that 180 Ohms will have 10V on it when pot is at 0 ohm) and return to ground through ground through the variable 100 Ohm pots (the pot will dissipate power also), all the LED return current will also be flowing through pin2 of the IC. The SIG input pin is just looking for the Voltage input to compare it the the resistor string of the comparator ICs. Using the 100 Ohms or any value is not the problem.
                      I wonder if that circuit was actually built and tested.
                      When ALL LEDs are on, there will be about 100mA flowing out pin 2, and there will be voltage drop on that pot which will vary and depends on how many LEDs are on so the the Rhi value will keep on changing so as the the trip points of each comparator, it looks like a mess with pin2 ground connection like that.
                      The SIGNAL pin is also being fed by voltage that is set by the TRIM POT instead of sensing the variable voltage from the sensor signal.
                        Hi Ben,
                        What program do you use to draw the diagram? I hate launching my ALTIUM just to draw the simple diagram.
                        • scampo77
                          • 233
                          #32
                          reverendjones. have had the worst luck with these gauges i have been through 3 so far and they just keep failing. i have bigger plans once i get both of these gauges working which is to design a auto leveling system so i dont have one tank run dry while the other is full.
                          plus it is exciting to have an excuse to ask these questions and understand the results.
                            So is the sensing pot a 2-leg or 3-leg device?
                            "these gauges i have been through 3 so far and they just keep failing" are they the circuits you had posted, or they are other design?
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Hi Ben,
                              Probably wont be of much help, but I use ExpressSCH (its free). I take a screenshot, then open up a paint program and clip away the extra bits...
                              Would a 1k5 resistor work well as a Ib current limiter for Q1?
                              Muh-soggy-knee
                                Not sure if that setup will work yet since we still need to find out how that 100 sensor resistor work, if it has two pins and its value is varied from 0 to 100 Ohms, or it has three pins with the wiper as an output so it will be like voltage divider, the load on the Emitter will always be 100 Ohms, if it is two pins variable resistor then the Emitter resistor can be 0 ohm when fully close which may damage the transistor.
                                I will see if I can build and verify what he needs base on his sensor.
                                  Another question is how much current the sender/sensor resistor can handle without damaging it.
                                  • scampo77
                                    • 233
                                    #37
                                    it is 2 pins and never goes to 0 ohm i think empty is around 5 ohm. i am hoping to build just a simple voltage divider to get a more accurate range of the gauge. before i install my new contraption i am building here. but when i tried i had the same problem was that the voltage shot all over the place not sitting still for even a second and it is why i started this thread.
                                    then i got side tracked with new diagrams and now i am just wiring up the new way.
                                    • scampo77
                                      • 233
                                      #38
                                      again i am very very new to this and would like just a bit of reassurance that what im not putting the diodes in the wrong direction or the transistor in upside down
                                      i drew on this picture the way i understood it
                                      • scampo77
                                        • 233
                                        #39
                                        where does pin 4 RLO go to?
                                          Well that circuit will not work with your Rsensor since it is just a variable resistor not a 3-pin voltage divider type. Pin 4 Rlo is connected to ground.
                                          That is why I ask if the Rsensor is 2-pin or 3-pin type.
                                          May I ask what kind of setup you have before, before you want to use this LM3914 circuit.
                                          • harp
                                            high voltage high resistance marking resistor
                                            by harp
                                            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                                            08-26-2024, 01:42 PM
                                          • jinu_j
                                            by jinu_j
                                            Hi
                                            05-03-2025, 10:51 PM
                                          • mikey5791
                                            Need help to replace burned resistor in 350w atx psu
                                            by mikey5791
                                            Hi to all forum members,
                                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                            12-26-2024, 04:55 AM
                                          • rddube
                                            Lenovo L490 Ram voltage circuit malfunction
                                            by rddube
                                            Hello friends,
                                            Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                            I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                            07-15-2025, 04:41 PM
                                          • Fernon@Repair
                                            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                            by Fernon@Repair
                                            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                            VCCIO voltage ok
                                            VCCSA Voltage OK
                                            VCCPLL Voltage OK
                                            Ram Voltage ok
                                            RamVTT OK
                                            VPP 2.5 OK
                                            But No Core Voltage
                                            and i want to this vrm ic datasheet or pinout (ISL69269)
                                            anyone have this ic pinout voltages?...
                                            06-25-2025, 07:19 AM
